pulsair(at)mindspring.com Guest
Posted: Mon Aug 14, 2006 11:17 am Post subject: Spark Plug Wires |
I'm doing my annual inspection. It has been ten years since I have had my Classic IV certified. I'm replacing everything. I called Lockwood today and gave them the part number for new spark plug wires. They said they sell it by the MM. Anyone know how much to order? I have a 912UL. Thanks, Jeff Classic IV
ppeerenbo(at)charter.net Guest
Posted: Mon Aug 14, 2006 3:57 pm Post subject: Spark Plug Wires |
I am also looking for wire information. It appears that the original wire I have (the blue wires) have a metal shielding. The new wires do not have the shielding. I have the "big metal ignition box behind the instrument panel. I am concern with noise. Any help out there.
Paul
barry(at)pgtc.com Guest
Posted: Tue Aug 15, 2006 3:19 am Post subject: Spark Plug Wires |
Jeff, this doesn't sound right. I am not looking at my wires right now but I think they are all molded together and into the coil.
Barry
lcfitt(at)sbcglobal.net Guest
Posted: Tue Aug 15, 2006 6:28 am Post subject: Spark Plug Wires |
Barry, The wires are threaded into the coil and the terminals. There are
threaded spikes in both and the wire can be twisted counter-clockwise out
and inserted opposite. The diameter is the important part. I replaced mine
several years ago.
Lowell
jimmieblackwell(at)sbcglo Guest
Posted: Tue Aug 15, 2006 1:19 pm Post subject: Spark Plug Wires |
I have the same metal box and would like to replace the spark plug wires also, but I have not been able to determine how to disconnect the spark plug wires from the trigger coils. Looks like they are molded into the trigger coils. Does anyone know if the spark plug wires can be removed from the older trigger coils like Paul and I have on our 912's?
Paul <ppeerenbo(at)charter.net> wrote: [quote] I am also looking for wire information. It appears that the original wire I have (the blue wires) have a metal shielding. The new wires do not have the shielding. I have the "big metal ignition box behind the instrument panel. I am concern with noise. Any help out there.
Paul
dosmythe(at)cox.net Guest
Posted: Tue Aug 15, 2006 3:00 pm Post subject: Spark Plug Wires |
I don't know about the 912 but on my 582, I relocated the coils off the engine and to the firewall. Of course, I had to put in longer spark plug wires. The wires at the coil end were installed with a type of locktite. It's the locktite that held the wires in place. The spark plug caps screwed into the wires.
As an added note, I purchased "ROTAX" replacement wire from Spruce and it was "way" inferior to what was on the engine originally. Re-ordered the same "ROTAX" wire from CPS and it matched perfectly to the original wire. Just be aware...
Don Smythe
