jwt(at)roadmapscoaching.c Guest
Posted: Tue Aug 15, 2006 9:59 am Post subject: Door seal adhesive |
I am not having much luck finding a good adhesive for the door seal. What are others having success with?
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Finish kit - gear legs and wheels
8/15/2006
Tim(at)MyRV10.com Guest
Posted: Tue Aug 15, 2006 10:49 am Post subject: Door seal adhesive |
3M Super silicone sealant. NAPA and auto parts stores
carry it, or can order a caulking tube of it. From what
I can tell, it's almost or exactly like regualar GE clear
silicone sealant you could by at the hardware store.
John Testement wrote:
| Quote: | I am not having much luck finding a good adhesive for the door seal.
John Testement
jwt(at)roadmapscoaching.com <mailto:jwt(at)roadmapscoaching.com>
40321
Richmond, VA
8/15/2006
jesse(at)itecusa.org Guest
Posted: Tue Aug 15, 2006 11:02 am Post subject: Door seal adhesive |
Plain old Silicone is the only thing that we could get to work.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement
Sent: Tuesday, August 15, 2006 1:59 PM
Subject: Door seal adhesive
John Testement
40321
Richmond, VA
8/15/2006 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567890123
-- No virus found in this incoming message. Release Date: 8/14/2006
8/14/2006
dlm46007(at)cox.net Guest
Posted: Tue Aug 15, 2006 1:27 pm Post subject: Door seal adhesive |
Just remember that silicone sticks to paint but paint will not adhere to silicone.
Posted: Tue Aug 15, 2006 2:59 pm Post subject: Door seal adhesive |
I tried GE Silicon II and it did not stick. Also tried 3M super trim adhesive, and Goop. Maybe I need to scuff the rubber some more.
John Testement
40321
Richmond, VA
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Tuesday, August 15, 2006 3:01 PM
Subject: RE: Door seal adhesive
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
John Testement
40321
Richmond, VA
8/14/2006
4-- No virus found in this incoming message. Checked by AVG Free Edition.
8/15/2006
Posted: Tue Aug 15, 2006 6:44 pm Post subject: Door seal adhesive |
Not sure what that means, but it seemed to work the way we did it. We tried everything else we could think of before just going ahead and doing it the way Van’s recommends. By the way, those that saw N256H at Osh with the screws holding it on, that didn’t hold up and we replaced it just using silicone and it worked fine. I don’t know the make or part number for sure, but I think it was a caulk gun tube size and I think it was GE. I just know that it said Silicone on it.
I would be very interested in another style of door seal, like the one Debbie had. I think the design of the doors, latches and seals are by far the weakest feature of this plane, although I understand the RV-10 isn’t the only plane out there with door problems.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Tuesday, August 15, 2006 5:08 PM
Subject: Re: Door seal adhesive
flysrv10(at)gmail.com Guest
Posted: Wed Aug 16, 2006 2:47 am Post subject: Door seal adhesive |
I used a rubber door seal that I purchased from Brown Aircraft Supply in Jacksonville, FL along with 3M 1300L glue. The seal only comes in black and it has the identical profile with Van's seal supplied with the kit.
I was looking for a door seal with smaller diameter bulb so the door could be closed easier. I also did not want to get silicone glue (the only glue you can use with the door seal that comes with the kit) near my plane before painting the plane for the fear of contamination.
I seem to have a good seal and am able to close latch the door with less force on the handle.
Do not archive.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David McNeillSent: Tuesday, August 15, 2006 5:08 PMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Re: Door seal adhesive
Posted: Wed Aug 16, 2006 3:57 am Post subject: Door seal adhesive |
I installed the seal after the door was painted. The door does need
a good pull though to close, so it would be nice to have your
seal, but in the standard silicone. The silicone should last
longer and hold up better. Both should be fine.
| Quote: | I was looking for a door seal with smaller diameter bulb so the door
Posted: Wed Aug 16, 2006 4:51 am Post subject: Door seal adhesive |
Rob,
Which actual part number did you buy? They have a number of them that look the same as the Van’s gray seal.
Thanks and do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Sent: Wednesday, August 16, 2006 6:45 AM
Do not archive.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
7890
123456789012345678901234
8/15/2006
8/15/2006
Posted: Wed Aug 16, 2006 5:27 am Post subject: Door seal adhesive |
It is BA1900010. It has a smaller bulb and a shorter leg. Just make sure that you mask the door before applying the 3M glue. Once there and cured, it will not come off.
Do not archive.
On Aug 16, 2006, at 8:49 AM, Jesse Saint wrote:
Rob,
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob KermanjSent: Wednesday, August 16, 2006 6:45 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Re: Door seal adhesive
Do not archive.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David McNeillSent: Tuesday, August 15, 2006 5:08 PMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Re: Door seal adhesive
