ronlee(at)pcisys.net Guest
Posted: Fri Aug 18, 2006 6:53 pm Post subject: Denver |
| Quote: | Any RVer's in the Denver area? I'm planning of flying my RV8 to Centennial
Airport arriving September 13 and need advice on possible temporary hangar
space and/or tie down.
In case you are not used to high altitude flying here are a few suggestions.
1) Fly your normal airspeeds on approach. There may actually be some delta
as altitude changes but the point is that your groundspeed will be higher than
you are used to for the same indicated airspeed. Do not use groundspeed to
determine flare.
2) Lean the engine during runup according to your engine manufacturer.
3) Be aware of the Denver Class B airspace altitudes.
4) If you want to go to Leadville to get your highest airport certificate
let me know.
Ron Lee
