gommone7(at)bellsouth.net Guest
Posted: Thu Aug 17, 2006 5:09 pm Post subject: fuel return |
When use an IO 540 (from Mattituck) is a return fuel line needed to the fuel tanks?.
Thanks in advance
Hugo
Tim(at)MyRV10.com Guest
Posted: Thu Aug 17, 2006 5:45 pm Post subject: fuel return |
No, that's the continental that required that. The IO-540 does not,
at least in the standard install.
gommone7(at)bellsouth.net wrote:
Deems Davis
Posted: Thu Aug 17, 2006 6:47 pm Post subject: fuel return |
It depends upon which Fuel Injection system you are installing. If you
install one of the AFP systems, they have a 'purge' line that requires
plumbing to return the purged fuel.
Deems Davis # 406
Fuse/Finishing/Panel
http://deemsrv10.com/
Tim Olson wrote:
jesse(at)itecusa.org Guest
Posted: Fri Aug 18, 2006 5:13 pm Post subject: fuel return |
No, unless you get a different fuel injection system than is standard.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Sat Aug 19, 2006 3:04 am Post subject: fuel return |
Thanks for the answers,here another question ,its any body have some pict. of the rear seat atach.system for a 4 points harness
thanks
hugo
Date: 2006/08/18 Fri PM 09:11:57 EDT
Subject: RE: fuel return
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Sat Aug 19, 2006 5:06 am Post subject: fuel return |
Hugo,
You just remove or don't install the center "knee killer" lug, and
order rear harnesses that are 4-point. Nothing more to it.
pict. of the rear seat atach.system for a 4 points harness thanks
hugo
