aadamson(at)highrf.com Guest
Posted: Sun Aug 20, 2006 4:55 pm Post subject: MOV's |
Bob,
Just curious if a design element changed, or if they were there due to the
composite structure and some other phenomena.
In your "WireBook" for the Lancair IVP, you use MOV's across lots of
contactors, switches, etc. And yet, your book doesn't show, nor discuss
them at least not as far as I've found. Did something change since you did
that wirebook, or do you recommend them on composites?
Thanks in advanced,
Alan
nuckollsr(at)cox.net Guest
Posted: Sun Aug 20, 2006 7:01 pm Post subject: MOV's |
At 08:53 PM 8/20/2006 -0400, you wrote:
Quote: |
<aadamson(at)highrf.com>
Bob,
Low voltage MOV's are hard to find and more expensive than
diodes. Neat idea but not practical in low voltage DC systems.
Hence the switch to diodes in later documents.
< with experiment. >
< --Lawrence M. Krauss >
Eric M. Jones
Posted: Mon Aug 21, 2006 10:02 am Post subject: Re: MOV's |
Coil Suppression:
Mechanical relays and contactors depend upon magnetism generated by an electric current running through a wire coil. When the current stops, the magnetic field collapses. But the relay does not know the difference between a wire coil moving in a magnetic field (as in a generator) or a magnetic field moving in a wire coil (as in a collapsing magnetic field). Thus a large voltage—1000V to 1500V typically—is induced in the coil. This current goes the same direction the original current did—so it slows the contact opening—allowing arcing, chatter, bouncing, contact welding and even re-closure! Coil suppressions is required both to limit the damage to the relay contacts, and other parts in the system.
MOVs are considered to be better than diodes for coil suppression, although they have higher impedance. But MOVs typically have a limited lifetime.
Diodes are not the best devices for the task today. Not even the second-, third-, or fourth- best method. But in the 1960's they were the way to go.
Perihelion Design sells 18V 600W Bi-Directional Zener Transient Voltage Suppressors (for 14.5V systems) that provide the most modern Third Millennium technical solution to relay coil suppression. We sell these as a set of twelve with the typical hardware needed to retrofit a small airplane.
Every manufacturer of bi-directional Zener transient voltage suppressors seems to have a trademarked name for these: Transils™, Surmetics™, Transorbs™, TranZorbs™, TransGuards™, Mosorbs™; the list is endless. We call them SnapJacks™.
They also are offered in a range of voltages, packages, and wattages. Perihelion Design offers the 18 Volt 600 Watt axial lead version of these guys, commonly known to close friends as P6KE18CA, and includes some of the connectors and shrink tubing you may need to install them.
Basic Plan: SnapJacks are used to replace coil suppression diodes wherever they are now installed. For coils, contactors and relays that are internally equipped with a suppression diode, the best solution may be to buy the equivalent non-diode part. If possible, install the SnapJacks with the shortest leads possible consistent with strain relief and mechanical mounting of the part.
SnapJacks have NO POLARITY, regardless of any marking on the parts. Although the 600 W parts will work fine with the biggest relay, contactor, or motor that your aircraft could lift, you may wish to parallel two SnapJacks on the big loads for redundancy. In some cases diodes associated with contactors are there for switching logic purposes, not suppression. These should be left alone.
ref: http://relays.tycoelectronics.com/kilovac/appnotes/transients.asp
See: http://www.periheliondesign.com/suppressors/SnapJack.pdf
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
echristley(at)nc.rr.com Guest
Posted: Tue Aug 22, 2006 6:05 am Post subject: MOV's |
Quote: |
Coil Suppression:
Diodes are not the best method today. Not even the second-, third-, or fourth-
In what aspect does the common, sub-$1, available-everywhere diode fall
short enough to justify paying $30 for your single-source solution?
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
paulm(at)olypen.com Guest
Posted: Tue Aug 22, 2006 8:47 am Post subject: MOV's |
I get them for as little as under 25 cents each in qty of one (15 cents each
for 100). All industrial electronic suppliers stock them in many types and
brands. $30 will get you 100 parts including shipping in some cases. The
cost difference is not significant in the big picture.
Eric provides a value added KIT of parts etc its up to you to convert
convenience for absolute cost. (Eric also posted the exact part number for
those who wanted to get just the diodes from most any source as above)
Relays with internal diodes are available simply because of demand, not for
technical reasons. Engineers resist change and if it seems to work why
change?
Transorbs are better or (no worse in some opinions) and work in 100% of the
cases. Its a "no brainier" for some of us.
While they may not appear to make a difference in a 5 amp resistive load
with a small relay, Transorbs are proven to have a large advantage in
inductive and larger current loads with larger or different type relays.
But so what! Bob has his "repeatable" test of one and is convinced he is
right.
One size (test) does not fit all cases and perhaps its 90% (for diodes) for
the average aircraft but clearly not 99.99% based on MY own lab repeatable
tests.
The entire world, North America, and Europe for example, ALL say the same
thing that Eric referenced about Diodes vs. Transorbs etc. Just who is out
of step here????
There are hundreds in every modern auto. Given the number of autos made each
year and yes Transorbs do cost more than simple diodes why would auto makers
spend millions of $$ every year for them if the diode was as good and they
could save all that money with diodes. Perhaps they know something not
stated on this list??
If you look at the available data including the many references and read and
understand the available info, its far more compelling than appears on the
surface.
Is "good enough" OK if you can get better for little more?
I am unwilling to have another useless debate. It ends up with a lot of
words/heat etc. and no opinion ever gets changed.
Paul
Eric M. Jones
Posted: Tue Aug 22, 2006 9:46 am Post subject: Re: MOV's |
Ernest,
See both of the links I posted,
but especially:
http://relays.tycoelectronics.com/kilovac/appnotes/fig48.asp
You are incorrect on several points-- These are not single sourced. Every manufacturer of bi-directional Zener transient voltage suppressors seems to have a trademarked name for these: Transils™, Surmetics™, Transorbs™, TranZorbs™, TransGuards™, Mosorbs™; the list is endless. We call them SnapJacks™. They are 18 Volt 600 Watt axial-lead bi-directional Zener transient voltage suppressors, part number P6KE18CA.
The kit includes:
(12) P6KE18CA
(24") of suitable heat shrink tubing,
(4) 1/4" faston solder adaptors
(10) 6-8-10 Multistud ring tongue connectors
(2) 1/4" ring tongues
(2) 5/16" ring tongues
(4) Faston tabs rivet or screw mount
(1) Instructions and technical details,
(1) Perihelion Design catalog
(1) Free first-class shipping
My accountant says I lost $xx,xxx on my little business in '04 and will maybe break even in '05 and '06, due entirely to my Space Shuttle Switch Guards that I sell to NASA (Perihelion Design parts are in orbit!) and the Military.
Selling little SnapJack™ kits like this is a money loser no matter how you cut it, but I get to hang out with the most interesting people. That's worth a lot.
113 Brentwood Drive
(508) 764-2072
N6030X(at)DaveMorris.com Guest
Posted: Tue Aug 22, 2006 9:54 am Post subject: MOV's |
Ok, so translated into complete neophyte-speak, for the rest of "us",
this means:
1. The experts disagree (as they do in high vs low wing)
2. You can use a diode or a transorb, but do use something.
3. Pick whichever you find cheaper and more readily available.
4. A transorb can be wired up either direction, while a diode must be
wired with the correct polarity.
Dave Morris
N5UP
cents each for 100). All industrial electronic suppliers stock them
in many types and brands. $30 will get you 100 parts including
shipping in some cases. The cost difference is not significant in
the big picture.
convert convenience for absolute cost. (Eric also posted the exact
part number for those who wanted to get just the diodes from most
not for technical reasons. Engineers resist change and if it seems
to work why change?
of the cases. Its a "no brainier" for some of us.
load with a small relay, Transorbs are proven to have a large
advantage in inductive and larger current loads with larger or
he is right.
diodes) for the average aircraft but clearly not 99.99% based on MY
own lab repeatable tests.
same thing that Eric referenced about Diodes vs. Transorbs etc. Just
who is out of step here????
made each year and yes Transorbs do cost more than simple diodes why
would auto makers spend millions of $$ every year for them if the
diode was as good and they could save all that money with diodes.
Perhaps they know something not stated on this list??
read and understand the available info, its far more compelling than
appears on the surface.
of words/heat etc. and no opinion ever gets changed.
Paul
Posted: Tue Aug 22, 2006 12:32 pm Post subject: MOV's |
Comments by your numbers.
1. I only know one "expert" that disagrees with the use of transorbs. I am
sure they are more but the overwhelming majority of my engineering
associates agree with the "true experts in the field" of relays and
contacts etc.
2. Sort of true in most cases. Not usually true with contactor type relays
switching inductive loads for example. There are two issues the coil
inductive kick that must be addressed that affects the driver of the coil
and the relay contacts which can affect the switched load by delays (seldom)
and slow opening which power contactors really have a large delay in many
cases and the duration and magnitude of the slow opening of a large
inductive load can be damaging.
3. Sure quality and use is trumped by price. 5 cents is better than 25
cents. Using the same logic go to your rat shack and get plastic crimp
terminals as they are cheaper and easier to find.
4. Transorbs are both uni-directional and bi-directional. True in one case
and polarity is important in the other.
However a uni-directional transorb is no better than a diode, and is a diode
in that use.
Paul
klehman(at)albedo.net Guest
Posted: Tue Aug 22, 2006 12:53 pm Post subject: MOV's |
True for a bi-directional transorb. But just to muddy the waters, I kind
of like the more common uni-directional transorbs. They will still help
with positive spikes (if you believe in positive spikes ). Used
across a contactor coil, they may delay the opening a smidge compared to
a bidirectional transorb, but I suspect that, like the common diode,
they are more effective at preventing negative spikes (if you believe in
negative spikes comining off contactor coils ). It seems to me
that an 18 volt bidirectional transorb may still let negative spikes
through that are large enough to damage electrolytic capacitors and
perhaps solid state devices, if there is no battery in the circuit. I
guess I used diodes on all the contactors and then added a few transorbs
on the b-lead just because I could...
Are automobiles incorporating transorbs within some devices now? I've
never come across one yet that I've noticed.
Ken
Quote: | 4. A transorb can be wired up either direction, while a diode must be
tonybabb(at)alejandra.net Guest
Posted: Tue Aug 22, 2006 12:58 pm Post subject: MOV's |
Dave,
As a neophyte thanks for leading me to the bottom line here - THANK YOU !!
Tony
Posted: Tue Aug 22, 2006 3:15 pm Post subject: MOV's |
At 01:57 PM 8/22/2006 -0700, you wrote:
Dave,
Tony
Posted: Tue Aug 22, 2006 6:34 pm Post subject: MOV's |
contacts etc.
Who's claiming to be an expert? Please cite the writings
of any other individual who has measured, illustrated and
explained variabilities and their effects in the manner
which I've offered. The name, job title and organization
of any such individual are unimportant. The numbers and
explanations are. Good data and experimental technique
stands by itself because it (1) makes sense and/or (2)
is easily supported (or refuted) by repeating the experiment.
I can demonstrate at least three cases in the past 8 years
where the best that some big-name companies could bring to
bear on high dollar problems was insufficient to the task.
Instead of getting their fast-turn advice on how best to
deduce failures of their products, it took me months and
in one case years to figure it out for myself. In the end,
I knew more about some aspects of their product than they
did.
(seldom) and slow opening which power contactors really have a large delay
in many cases and the duration and magnitude of the slow opening of a large
If I read this correctly, you're citing the occasional
system performance issue where a 12 mS dropout delay
is okay but a 60+ mS delay causes problems. Yes, I've
had to deal with a few systems where multiple relays could
get into operating "races" and produce unpredictable and
unsatisfactory performance. I know of no situation in OBAM
aviation where this could be an issue.
However, in the last sentence you seem to be speaking of
contact spreading velocity which I've shown is mildly
affected by the form of coil spike suppression.
Price has nothing to do with the design points under
discussion. MOVs were attractive to me early on in spite
of their price BECAUSE they were bi-directional devices.
I reasoned that use of the MOV would prevent the occasional
accidental mis-wiring that is possible with the decidedly
uni-directional nature of diodes. However, they did not
perform as well as diodes for the purpose of reducing stress
on the controlling switch. Further, they were hard to find
in very low conduction voltage ratings.
I abandoned them in my writings after a few years in
favor of readily available, lower cost, better performing,
plain vanilla diode.
diode in that use.
In fact, you cannot use a uni-directional Transorb (or
plain-vanilla zener) unless combined with a diode to
prevent forward conduction as shown in multitudes of catalogs
and literature on relays.
Paul
each for 100). All industrial electronic suppliers stock them in many types
and brands. $30 will get you 100 parts including shipping in some cases.
The cost difference is not significant in the big picture.
Agreed. Let us leave cost out of it.
technical reasons. Engineers resist change and if it seems to work why change?
???? Really. You don't speak very highly of engineers. Stuck
in ruts (do they never seek to broaden their horizons?) Further,
they're willing to accept anything that "seems" to work. Don't
you think it's incumbent upon the savvy engineer to KNOW how
and why things work and not rely on mortal perception? Perhaps
I benefited from not having finished school if I avoided that
upper level class: Ruts and Perceptions 425 - Recipes for
Failure.
How are they "better"? I've never said that they SHOULD
NOT be used or that they were somehow inferior. The only
thing I've said and demonstrated was that there is no
measurable value FOR using them.
The difference between NO suppression (open circuit) and
the most aggressive suppression (diode) was a spread of
10% in arc-time during contact opening. A diode-transorb
combo would fall somewhere in between. This means that
the delta for diode-transorb versus diode-only could be
as little as 1% and maybe as much a 9% . . . that was
the point of the experiment, to put some bounds on a
spread. Further, it's the only claim being made from
analysis of the data.
Please cite the experiments and the resulting data.
Keep in mind that off-the-shelf relays of ALL sizes
are available with nothing, diode-zener and diode
only coil suppression. If one technique were so
decidedly favorable over another technique, why
hasn't the relay and contactor industry all jumped
onto one bandwagon as your "entire world" citation
below suggests they should?
But so what! Bob has his "repeatable" test of one and is convinced he is right.
I gathered data on one relay and tested three others of various
sizes from 2 to 30 or so amps. The measured results with respect
to effects on contact spreading velocity were similar. If the test
was poorly crafted then it should be no big deal to demonstrate
my error.
tests.
Please share the data of your tests. What size relay would
you like to see data on? I have some real honkers. I think I
could do a 400A interrupt experiment for you. Let us compare
notes.
of step here????
Please cite the literature. You've cited applications literature
on Transorbs before that was shown to be overstated or when it
came to over-voltage and load-dump mitigation. You once advocated
a generous sprinkling of Transorbs on the bus . . . one for every
breaker as I recall. The Transorb is a high power, low energy
device well suited for mitigating short duration events . . .
lightning strikes and ESD. I'm well aware of their usefulness. I
stuck an array of Transorbs on an electro-whizzy just this weekend
so that I could pass and ESD test in the lab tomorrow morning.
At the same time, others here on the list have shown that the
Transorb is not suited to a load-dump mitigation without
deliberate impedance limiting of the energy source (just
like the manual says). In this discussion, we're definitely in
the short duration, low energy realm where a Transorb thrives.
But I'll say again, I'm not campaigning against Transorbs for
this application. I'm only stating that there's no compelling
evidence support superior performance over the lowly diode for
coil suppression when it comes to fending off the contact-eating
gremlins.
each year and yes Transorbs do cost more than simple diodes why would auto
makers spend millions of $$ every year for them if the diode was as good
and they could save all that money with diodes. Perhaps they know something
Perhaps you have special knowledge of the reasoning behind their
use? Yes, we use hundreds of them on airplanes too, but they're
not used on large contactors in lieu of diodes . . . for the
reasons I've cited.
and understand the available info, its far more compelling than appears on
the surface.
Let us not talk about "surface" or "appearances". How about
physics of test setups and numbers derived therefrom.
It is not my wish to convince you or anyone else of anything
sir. It's my intent to explain things and support my explanations
with demonstrable fact and logical conclusions based on those
facts. If I am in error, nobody would be happier to know the
nature of the error than I. Go to the lab sir. Show us the
data you've collected. I need to know how I screwed up. You
name the test conditions and I'll repeat the test so we can
compare results. This is where the debate becomes useful . . .
not to you or I but to those who choose to read it and
deduce facts of the matter for themselves.
Posted: Tue Aug 22, 2006 7:23 pm Post subject: MOV's |
with positive spikes (if you believe in positive spikes ). Used across
a contactor coil, they may delay the opening a smidge compared to a
bidirectional transorb, but I suspect that, like the common diode, they
negative spikes comining off contactor coils ). It seems to me that
an 18 volt bidirectional transorb may still let negative spikes through
that are large enough to damage electrolytic capacitors and perhaps solid
state devices, if there is no battery in the circuit. I guess I used
diodes on all the contactors and then added a few transorbs on the b-lead
Ken
A contactor coil can generate spikes of either polarity. It
depends on how you switch it. Here's a trace I took off the coil
of a Cole-Hersee battery contactor with no coil suppression.
I dug through the archives and found some more data on devices
common to the OBAM aviation electrical systems. See:
http://www.aeroelectric.com/Pictures/Curves/CH_Bus_Noise_w_0p1_Cap.gif
Here you see a 300+ volt POSITIVE spike because the controlling switch
(battery master) is in the ground lead. Note that with as little as
0.1 uF capacitor on the supply plus whatever the bench supply
(3A regulated) impedance was, the spike noise coupled to the bus
was on the order of one or two volts high. And this may have been
a test setup artifact (meaning smaller than observed). The point of
this setup was to show that coil spikes are a danger only to the
controlling device (in this case, battery master switch) and NOT
to other devices on the bus. These spikes DO NOT propagate about
the system on the lookout for vulnerable electro-whizzies.
The next trace . . .
http://www.aeroelectric.com/Pictures/Curves/CH_w_120_Ohm.gif
shows the coil suppression benefits of a simple resistor. In this
case, 120 ohms. The spike is notably smaller, only 90 volts
or so and again, the spike coupled to the bus was tiny by
comparison and probably not "real". Note the 22 mS release
time for the contactor. The next trace . . .
http://www.aeroelectric.com/Pictures/Curves/CH_w_1n5400.gif
shows what happens with the plain diode spike suppressor.
Note the very slight upward inflection of trace #2 above
bus voltage where the coil energy is staining against the
diode's forward voltage drop as positive going spike is
clamped off. Note the 75 mS release time. The next trace . . .
http://www.aeroelectric.com/Pictures/Curves/CH_w_2x18v_Transorbs.gif
shows the results of a pair of 18v Transorbs (or zeners)
hooked back to back to emulate the bi-directional device.
Here the spike clamps off at an expected level of about 18 volts
above bus voltage and we see a release time of about 14 mS.
http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_without_Diode.gif
Shows a Cole-Hersee contactor release time ploted at some
other time without a diode but this time, I captured the
release time of 11 mS. The next trace . . .
http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_with_Diode.gif
is for the same relay and shows a 53 mS release time, again
about 5x the no-diode time noted above. This data is proprotionally
consistant with numbers I posted for the smaller relay
earlier. Note also that one experiment with the CH contactor
and diode yielded a 75 mS release time while the second
was only 53 mS. This variability is to be expected and is
driven by many factors including contactor temperature and
manufacturing variables. The effects of any one suppression
technique can be accurately compared only when all techniques
are used on the same contactor and done with some effort to
keep the contactor temperature constant for each experiment.
Note that NONE of these traces went to the issue of contact
spreading velocity and resulting arc durations . . . only changes
in release time for the various techniques with a peripheral look
at spike propagation to the bus.
This series of traces serves to illustrate only the variability
of release time which a number of articles have mistakenly
assumed that proportionate decreases in contact spreading
velocity automatically follow. I'll suggest that the
assumed proportionality does not exist and that their is no
demonstrable advantage for using one suppression technique over
another in terms of performance. That suggests we're free to
choose techniques based on price. The plain vanilla diode is
hard to beat for price and wide spread availability. However,
I'd be delighted to be shown wrong if my suggestion is in error.
Posted: Tue Aug 22, 2006 7:49 pm Post subject: MOV's |
I cannot let this get past as your statement is in fact TOTALLY technically
incorrect (vs opinions).
Below requests for links must exclude your own as they need to be unbiased!
As I have stated in my original post which you (apparently do not want to
respond to) I will not get into a debate with you ever again (actually on
ANY subject) and this subject (transorbs) has been debated between us
starting nearly 10 years ago.
If you truly are interested in the reasons (pros and cons) of the various
types of coil suppression please consider reviewing the references Eric
posted as your reference had little info other than to illustrate the types
of suppression relay delays. Yes (as you have stated) the total circuit (not
just the coil) drives the suppression method and Transorbs always work and
diodes only usually work.
I will not respond to your comments below (however erroneous some may be) as
there is no point.
Paul
Posted: Tue Aug 22, 2006 7:57 pm Post subject: MOV's |
At 10:46 AM 8/22/2006 -0700, you wrote:
Okay, lets take a look at this citation . . .
* Improving Relay Operate Time
Coil suppression can have a profound effect on opening time
which is usually called "release time". The citation speaks
of "operate time" which is usually the time it takes for a
relay to close - which is NOT affected by the popular coil
suppression techniques.
* Calculating Pull-in & Drop-out Voltages at High or Low Temperatures
* Radiation Exposure at High Voltage; Is it a Problem?
* Power Conservation Schemes
* High Voltage Processing of Vacuum Relays
These points are not germane to the discussion at hand and will
be ignored for the moment.
"When a 28 Vdc relay coil is turned off, the inductive energy stored in it
can create surge voltages to 1500 volts on a DC power line. With the
increased use of solid state devices which are sensitive to spikes, relay
coils must be suppressed to limit voltage spikes to a maximum of 50 to 80
volts."
The first paragraph uses impressive numbers . . . 1500 volts will scare
the pants off most neophytes. Of course, it's easy to sign up to the
notion
that solid state devices should be "protected" from such horrific
stresses.
The paragraph ends with an assertion that bringing the offending
spike down
to the 50-80 volt range is the magic bullet. But there's a glaring
error . . .
that 1500 volt spike DOES NOT propagate out onto the bus but instead is
impressed across the mechanism of the controlling device be it switch
or transistor.
"The measure of successful coil suppression depends on the degree to which
the method affects the operation of the relay. Improper or excessive
suppression can cause the relay to suffer from a long release time, slow
contact transfer, and contact bounce on break. All of these conditions will
increase contact arcing when load switching, which will reduce relay life
dramatically."
Yes, slowed transfer and bounce are potentially hard on a relay.
Delayed release is not hard on relays but may have an effect on
system performance in time-critical situations . . . and were
talking MILLISECOND criticality. The paragraph correctly infers that
arcing is the proximate cause of reduced relay life.
"There are a number of common ways for a relay user to suppress relay coil
transients and each has advantages and disadvantages. However, the most
widely used methods utilize zener-diode and/or zener-zener combinations.
These combinations are compact, provide excellent suppression, and do not
affect relay release-time or contact life."
We've already demonstrated that the favorably rated zener-zener
technique has SOME effect on release time. It's less effect than
diode only but the effect is not zero. What is inferred and not
supported is that diode only has a profound effect on relay life . . .
an assertion I don't understand based on experiments I've conducted
over the years. I've not yet been able to confirm the assertion
on any size relay I've worked with to date. If someone cares to
show me an experiment that supports the assertion, I'd be pleased
to know of it.
In the mean time, I'm inclined to treat the words of the
cited posting with skepticism. They take a couple of true
statements, a false statement and then infer some golden
actions to be taken based on those statements. As I stated
in an earlier post, there's a LOT of writing like that
in the wild . . .
In this case, the errors are not harmful. There's nothing
inherently wrong with the proposed "gold standard" but
the writing does not foster understanding. Instead, lots
of myths are launched and preached as gospel because they
came from the Tyco-Amp or P&B bibles.
Posted: Tue Aug 22, 2006 10:00 pm Post subject: MOV's |
technically incorrect (vs opinions).
Posted: Tue Aug 22, 2006 10:21 pm Post subject: MOV's |
Yup, that conversation has been enshrined in bytes at
http://aeroelectric.com/articles/spike.pdf
Quote: | If you truly are interested in the reasons (pros and cons) of the various
types of suppression relay delays. Yes (as you have stated) the total
circuit (not just the coil) drives the suppression method and Transorbs
always work and diodes only usually work.
I've read those references. And I've explained what
I've found in them that was in error. If you want
to worship at the altars of Tyco-Amp or Potter-Brumfield
based on your blind acceptance of their Word, that's
your choice . . . but expect to be challenged when you
preach philosophies you cannot yourself explain. You
expose yourself as a propagandist and not as a teacher.
Quote: | I will not respond to your comments below (however erroneous some may be)
as there is no point.
If you can't be a teacher then don't get into
the sandbox to throw mud. Your drive-by insinuations
that errors in my posting are unworthy of your
time and effort is consistent with the behavior
you favored 6 years ago. You stood off and threw
rocks at my explanations and NEVER offered a single
alternative supported by your own explanation of
the underlying physics.
You had plenty to complain about but never a
plan consistent with anyone else's design goals but
your own. You want to play? Fine. If not, then
you know the way out. The unsubscribe link is:
http://www.matronics.com/subscribe/
Posted: Wed Aug 23, 2006 6:11 am Post subject: MOV's |
Bob I love 99% of your posts. You are doing a great job in helping people
understand and wire their aircraft and based on my limited accident
investigation of auto engine powered aircraft.
I would guess you have saved hundreds of lives in the past 10 years.
The stupid things people do that do not know of your information is
astounding.
However what I was asking for is independent backup of your conclusions as
my background and experience as well as all the data I can find support my
opinion not yours.
What is wrong with asking for independent backup. EVERY source (several
beyond what has been mentioned recently) I can find that really evaluates
(and stacks) the different suppression methods put the simple diode at the
bottom and the bi-directional transorb (or its equivalent) at the top. Sure
the different approaches are "application dependent" as which work better
and which are not as good. My point is the transorb always is good (and at
the top of the lost) so why not use it. No need to retrofit and replace
diodes IF you were to go on and discuss the cases where the diode was not as
good.
The only published paper that disagrees with me comes from you. How about an
industry recognized paper that supports your position? Teachers must be able
to backup what they say with independent references or the student can waver
about that and anything else the teacher says. The "prove me wrong" is
interesting but not useful as most students have no ability to try.
I have no interest in trying to prove what the industry says in unison. I
did see the proving data in the EMI lab when I worked in aerospace that
supported the industry and we simply proceeded on. Why not?, there was no
significant mechanical, electrical or cost difference and in some cases
there was a functional improvement. Sure 90% of the time a diode was just
fine but in the other cases it was not.
I can and have been a teacher but you want to be a teacher and yet get upset
when the student says "prove it". Using only your position (which differs
from industry) is not enough for me (and some others unwilling to post)
given the predictable results. A test by you of a single case or a couple of
cases does not make the statement universally true in all cases.
Paul
Posted: Wed Aug 23, 2006 6:43 am Post subject: MOV's |
Yes I remember that interchange and its a wonderful example how selective
cut and paste can change what I was saying and its context.
Its a masterpiece.
Paul
