Posted: Sat Aug 19, 2006 5:34 pm Post subject: Where to put garmin GPS |
I buzzed down to Aircraft Spruce today and took my first really good look at a Garmin 396. I realize I'm the last person in the world to look at one, but I figure that the farther away I stay from more expensive toys, the better on my bank account. One of the neat things about dropping in on Aircraft Spruce on a not so busy day was that they said "Take the GPS, go outside with it, drive around with it if you want." I said "Can I take it for a flight?" and they said "Sure, just have it back by closing time." I'm not sure if they meant that, but it was nice to take the unit outside the store and run through the features for a few minutes. There is simply no way to do that at an airshow.
I was very impressed. The menus and features are easy to figure out without relying on a manual, and the resolution is awesome.
Anyway, the question I had after giving the thing a good once over is "Where would I put one?". I have a Lowrance Airmap 100, which I usually just rest on my leg, but I don't think the Garmin will work that way.
So, side by side RV'ers, where do you put your Garmin GPS? I'm not really interested in putting it on the glareshield, and I've already spent all of my panel space...
Now that I've ruled out most of the obvious places, what are your suggestions?
Kyle Boatright
2001 RV-6
400+ hours
ronlee(at)pcisys.net Guest
Posted: Sat Aug 19, 2006 6:05 pm Post subject: Where to put garmin GPS |
| Quote: | So, side by side RV'ers, where do you put your Garmin GPS? I'm not really interested in putting it on the glareshield, and I've already spent all of my panel space...
Is the left corner of the window/glareshield workable?
Ron Lee
do not archive [quote][b]
rv9jim(at)juno.com Guest
Posted: Sat Aug 19, 2006 7:11 pm Post subject: Where to put garmin GPS |
Kyle,
I am putting my GPS on the mount provided my Airmap 500. It will
be bolted to the left side "P/N F704K upright cap strip" that goes from
the spar up to my roll bar. I have put K1000 nuts behind it so I can
mount anything I want in that area. Since it is an area that is fastened
by the blind rivets, you could just drill them out and put in at least
three blind nuts for max holding power. I'm also putting in three blind
nuts on the co-pilots cap strip for any thing else I may want to hook up
in that area. The mount provided by Lowrance is very flexible. I would
thin that Garmin would have something similar.
Jim Nelson
n223rv(at)wolflakeairport Guest
Posted: Sat Aug 19, 2006 7:45 pm Post subject: Where to put garmin GPS |
I built a new instrument panel and installed it right under the Dynon D180..... EFIS, Engine Monitor, GPS, Weather, XM satellite radio, all in two instruments....
-Mike Kraus
RV-4 Flying with a new instrument panel.....
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sun Aug 20, 2006 1:17 am Post subject: Where to put garmin GPS |
I am planning to add a bracket to the 'pillar' (F-304e) using several of
the pop rivet holes. I may replace some of the pop rivets with nut
plates and #8 screws, this would give more options.
Doug Gray
On Sat, 2006-08-19 at 21:32 -0400, Kyle Boatright wrote:
| Quote: | I buzzed down to Aircraft Spruce today and took my first really good
airshow.
that way.
suggestions?
Kyle Boatright
2001 RV-6
400+ hours
Hopperdhh(at)aol.com Guest
Posted: Sun Aug 20, 2006 3:45 am Post subject: Where to put garmin GPS |
Kyle,
The GPS is the instrument that you will look at the most, next to your flight instruments and engine gauges.
Also, it is a device that you need to be able to be able to see and reach to enter data, like your radio or transponder.
You may want to reconsider and devote some premium panel space to it.
I have my Garmin 295 mounted in the center of the panel on top of the radio stack as high up under the glareshield as I could get it. Both I and my "navigator" can see and reach it. I cut the hole in the panel to fit it, and made the bracket that holds it, but the new ready-made plastic mount would be just as good if not better.
I know that may not be much help if you are not willing to redo your panel a little.
Dan Hopper
RV-7A
In a message dated 8/19/2006 9:36:09 P.M. Eastern Daylight Time, kboatright1(at)comcast.net writes:
Kyle Boatright
2001 RV-6
400+ hours
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Sun Aug 20, 2006 4:15 am Post subject: Re: Where to put garmin GPS |
| kboatright1(at)comcast.ne wrote: | ....."Where would I put one?". I have a Lowrance Airmap 100, which I usually just rest on my leg, but I don't think the Garmin will work that way.
Kyle Boatright
2001 RV-6
400+ hours
Kyle,
You do not indicate what canopy configuration you have. I mounted my handheld GPS on a simple plate fashioned from a piece of .063 and it picks up two existing holes attaching the roll bar base to the sill. The GPS is affixed to the plate by the tape Garmin provided. The holding power of that tape is truly tenacious. This arrangement also serves double duty as a convenient place to hang my headset.
http://img95.imageshack.us/img95/855/img00011140hp0.jpg
Rick Galati RV-6A "Darla" 162 hours
dan(at)rdan.com Guest
Posted: Sun Aug 20, 2006 6:29 am Post subject: Where to put garmin GPS |
I use the 296 in my Cherokee, with no panel space I did not like the yoke mount, it was too close to me to read without glasses so I got a "Ram Mount" and am building a bracket to place it in a mid panel location without blocking any critical instruments,
Dan
Snohomish
-8 tail
Mike Kraus <n223rv(at)wolflakeairport.net> wrote:
[quote] I built a new instrument panel and installed it right under the Dynon D180..... EFIS, Engine Monitor, GPS, Weather, XM satellite radio, all in two instruments....
-Mike Kraus
Dale Ensing
Posted: Sun Aug 20, 2006 8:59 am Post subject: Where to put garmin GPS |
Very happy with Garmin 296 in RV-6A slider mounted above the radio stack
which is centered in the panel. Top of 296 is just below glare shield
overhang. Because the slider has a center longitunal former that is the
center support for mounting the panel, it precludes recessing the GPS in the
panel at top center. The 296 is surface mounted with an adapter plate using
Garmin's bracket. Turns out this works very well because it allows for a
slight angle toward the pilot (which can be adjusted) yet the co-pilot can
still see it. Also, it puts the 296 a little bit closer which makes it
easier to see and to reach the push buttons while flying.
One other strange thing. I am using the remote Garmin GPS antenna mounted on
the glare shield. When the remote antenna is placed right behind the GPS it
will not work. The stub antenna mounted on the GPS works but the remote
antenna in the same place does not. Antenna works fine placed forward near
windshield and to right of center support.
Dale Ensing
suggestions?
Kyle Boatright
2001 RV-6
400+ hours
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Sun Aug 20, 2006 11:18 am Post subject: Where to put garmin GPS |
Kyle,
Until we redid our panel, we used a "Ram Mount" which kind of put it out on a pedestal with ball joints, lets the copilot view it, etc... They must have a hundred different combos, so something like that could work. http://www.ram-mount.com/
HTH,
Jerry Cochran
In a message dated 8/20/2006 12:01:25 A.M. Pacific Daylight Time, rv-list(at)matronics.com writes:
| Quote: | From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Where to put garmin GPS
<snip>
suggestions?
Kyle Boatright
2001 RV-6
400+ hours
l_klingmuller6(at)earthli Guest
Posted: Sun Aug 20, 2006 1:28 pm Post subject: Where to put garmin GPS |
Do you have a tip-up or slider??
For two years I had my Garmin 195 loose on my lap/between the seats.
Finally I got off my butt and bought a RAM mount( see page 469, Aircraft Spruce). Mounted this versatile/adjustable unit with a couple of screws/ bolts on the left upright spar and cockpit channel. Works great and I like the fact that I can adjust the GPS for any light conditions. Also, can take the GPS home for flight planing, dreaming where to fly next etc.
If needed, I can take picture the next time I go to the airport.
Lothar, -6A Tip-up, 650 hrs
yenduc(at)sbcglobal.net Guest
Posted: Sun Aug 20, 2006 3:52 pm Post subject: Where to put garmin GPS |
Posted: Sun Aug 20, 2006 8:09 pm Post subject: Where to put garmin GPS |
shempdowling2(at)earthlin Guest
Posted: Mon Aug 21, 2006 6:10 am Post subject: Where to put garmin GPS |
I have the airmap 2000c and put it in the lower left corner of the glare
shield with the provided suction clamp. It really works well there. I
didnt think I would like it there but I was wrong. Oh yeah, its 2300
dollars cheaper, but no weather capability.
Shemp/Jeff Dowling
RV-6A, N915JD
300+ hours
Chicago/Louisville
