jesse(at)itecusa.org Guest
Posted: Mon Aug 21, 2006 4:02 pm Post subject: Panel Drawing |
Does anybody on the list have an accurate drawing of the standard Van's
panel for the -10? I talked to Van's and they said there should be on on
the Van's Airforce website, but they only had the 8 and 9 or something
like that. If you have a drawing of the -10 (especially if you know from
experience that it is accurate), please e-mail it off the list.
A waterjet cutting company said it would be cheaper to cut the panel and
all of the cutouts out of a ractangle of aluminum than to just cut out
the...uh...cutouts...from an already cut out panel. Well, I think I got
that out right.
Thanks and do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Tim(at)MyRV10.com Guest
Posted: Mon Aug 21, 2006 5:57 pm Post subject: Panel Drawing |
I've had one at this link for a couple years now...
Not sure if it's the format you need.
http://www.myrv10.com/miscphotos/rv_drawings/index.html
evmeg(at)snowcrest.net Guest
Posted: Tue Aug 22, 2006 6:32 am Post subject: Panel Drawing |
I have a couple of AutoCAD layouts you are welcome to. I have build quite a
few panels for assorted airplanes using these shapes so I think you will
find them pretty good....but check them anyway with a full sized drawing
first. I have a piece of 1/4" alum. I am planning on laser cutting for my
panel. It is thicker than stock but heavy enough to machine countersink for
flush instrument screws. I figure that by the time I am done cutting there
wont be much left of the original panel anyway so no big weight penalty.
Evan
