SD737(at)aol.com Guest
Posted: Mon Aug 21, 2006 8:24 pm Post subject: M701 Thrust |
Hey guys,
Thought I would post a question.
My engine temps are quite good, but I don't develop the thrust/speed that my compadres possess during formation takeoff and also at formation cruise.
At cruise in formation with EGT's matched I am turning about 4% more indicated RPM than my fellow L-29 buddies. i.e. I'm at 94% and they are at 90% with matched EGT and matched speed.
I have talked to a few different guys and also a warbird shop on the field here at Reno, Stead and I have got a range of input on what to do such as:
1. Adjust the fuel controller to deliver more fuel since temps are good .
2. Wash the turbine blades
3. Put a smaller Nozzle on
4. Replace the engine with a factory zero time overhauled engine.
Anyone else encounter this situation or have any suggestions.
Scott
| - The Matronics L29-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
colyergreg(at)aol.com Guest
Posted: Mon Aug 21, 2006 8:35 pm Post subject: M701 Thrust |
Go for the new engine!!!
Posted: Mon Aug 21, 2006 8:37 pm Post subject: M701 Thrust |
or just loose some weight....
Posted: Mon Aug 21, 2006 8:39 pm Post subject: M701 Thrust |
You gonna come to Reno during the air races and help me pull the thing?
The engine that is!
Posted: Mon Aug 21, 2006 8:41 pm Post subject: M701 Thrust |
of course!!! anything for you...
ainut(at)hiwaay.net Guest
Posted: Mon Aug 21, 2006 8:57 pm Post subject: M701 Thrust |
Along that line, do any of you guys know what the equivalent horsepower the L-29 engine is putting out at cruise, say? I know it's not a direct comparison, yet crossover formulae do exist -- I just don't remember them
David M.
SD737(at)aol.com (SD737(at)aol.com) wrote: [quote] Hey guys,
Scott
delfin(at)mail.pf Guest
Posted: Mon Aug 21, 2006 9:28 pm Post subject: M701 Thrust |
Does the engine gives 100% at full throttle ?What is the EGT at full throttle ?
What is the fuel pressure at 100%
Does the runway take off lenth seems normal ?
May-be you have to adjust the fuel controller to deliver less fuel
Scott
ntribution
Ernie
Posted: Tue Aug 22, 2006 7:37 am Post subject: M701 Thrust |
There are variations in fuel controllers for different year airplanes,
then there are the weight disparities, some people removed a lot more
than others, then there is CG, if you are flying with more forward CG
then the others then you will affext your cruise speed. Also there
are discrepancies between different gauges.
I pulled and cleaned my fuel nozzles last year, they were heavily
carboned up, and it did make a difference in power and fuel
consumption.
Ernie
Le 21 août 06 à 18:24, SD737(at)aol.com a écrit :
Hey guys,
Scott
ntribution
