		wayne.e(at)grandecom.net Guest
				 Posted: Mon Aug 21, 2006 5:33 am    Post subject: Skybolt adjustable cam locks |
				Don't know if any of you have considered cam locks  vs hinges for your cowling. Skybolt has adjustable camlocks for the RV10 and  they have a RV10 kit. The non adjustable camlocks would be a problem because  they would loosen and damage the cowling. With the adjustable one you can keep  them tight by adjusting them as they loosen.
 If anyone is interested here is their web site. Look  around until you find the RV section. I'm just now installing mine. We'll see  how well  it goes.
 http://www.skybolt.com/
 Here is their blurb.
 VANS RV SERIES AND OTHER KIT PLANE  INSTALLATION
 Skybolt has perfected the installation of CLocŪ Fasteners in  hundreds of Vans RV 4,6,7,8,9 and 10 and other kit planes. The Skybolt design  adds functionality and appearance to any cowling. Hinge is the perfect design  for a pop-rivet aircraft. Skybolt CLocŪ is the perfect design for a true  investment in pride.
 Wayne Edgerton #40336
 working installing  camlocks
		mritter509(at)msn.com Guest
				 Posted: Mon Aug 21, 2006 6:44 am    Post subject: Skybolt adjustable cam locks |
				Wayne,
 I used the Skybolt camlocks around the fuselage and they work great.  I went
 with the piano hinge to connect the upper and lower cowls along the
 horizontal axis.  I used the piano hinge because there are no curves along
 the sides (pins easy to get in and out) and they makes for a "clean" look.
 Mark (N410MR flying)
  	  | Quote: | 	 		  From: "Wayne Edgerton" <wayne.e(at)grandecom.net>
 Subject: Skybolt adjustable cam locks
 Date: Mon, 21 Aug 2006 08:32:21 -0500
		Jim & Julie Wade
				 Posted: Mon Aug 21, 2006 9:31 am    Post subject: Re: Skybolt adjustable cam locks |
				Mark I did the same thing!! Adjustable camlock next to the fuselage and hinge on the half separation. When I realized I was going to have to do a lot of reenforcing the upper and lover half for the camlocks, I decided to go with the hinge. Not a lot of room for the camlocks next to the valve covers .I bought the RV-10 kit from Skybolt and didn't use but half of it. You might just want to buy enough camlocks just to do the back half.
 Finished everything, waiting on panel this week!!!!
 Jim
 40383
 Slow build
		neilmcleod(at)hughes.net Guest
				 Posted: Mon Aug 21, 2006 6:39 pm    Post subject: Skybolt adjustable cam locks |
				I used the Skybolt camlocs on my RV-7. As I see it  the advantage besides adjusting for wear is adjusting for the thickness of the  cowling. Being a hand laid up fiberglass piece it is not a consistant thickness  and the adjustable camlocs make it easy to set up on the original installation.  I'm happy with thim so far but only have about 30 hours on them so far. I have  not installed the retainers for the outer part that locks into the airframe yet  because I'm still tweaking things.
  Neil
  [quote]   ---
		KiloPapa
  Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
				 Posted: Mon Aug 21, 2006 8:58 pm    Post subject: Skybolt adjustable cam locks |
				Wayne,
  I plan on looking at the CamLocs when I get to  that point.  I will be interested in your thoughts on them after you get  them installed.  Would enjoy some pics too.
  Kevin
 40494
 tail/empennage
  [quote]   Sent: Monday, August 21, 2006 6:32    AM
  _________________ Kevin
40494
do not archive |
