MichaelGibbs(at)cox.net Guest
Posted: Wed Aug 23, 2006 12:14 am Post subject: ALtimeter adjustment |
kitfoxmike sez:
| Quote: | ...THat's why you always give your altitude when getting clearance
with atc, so that things can be zero'd so to speak with the
controller.
Air traffic control is looking for your indicated altitude to be
within 125 feet of the altitude your encoder is transmitting
(adjusted for local pressure). If it is not, you may be asked to
turn off your encoder while receiving radar services because the
controller cannot rely on the altitude value he sees on his screen.
Mike G.
N728KF
Michel
Posted: Wed Aug 23, 2006 1:59 am Post subject: ALtimeter adjustment |
| Quote: | From: Noel Loveys [noelloveys(at)yahoo.ca]
To swing a compass properly on floats
Hum, if I had a seaplane, I think I would adjust the compass by taxiing at say, 10 MPH, on the water, using the GPS set to magnetic heading, as a reference. Of course, it's a two men's job. My experience in both maritime and aviation magnetic compass is that it is impossible to expect more than 5 degrees accuracy, which, IMHO, is good enough.
Michel
lcfitt(at)sbcglobal.net Guest
Posted: Wed Aug 23, 2006 4:19 am Post subject: ALtimeter adjustment |
This has been my thought while reading this thread. It seems that the only
time I use the compass is to estimate my position from an airport when
making an initial contact and that is always reported in approximat terms -
East, Southwest, etc. and when determining runway designations. I guess I
have become a "lazy" pilot as we on the West Coast always are in view of
mountains for general headings. and navigation. Lots of time when on a
cross country, we use roads or rivers, but when in a flight of at least two
will fly direct so have a GPS and "ELT" back-up.
Lowell
Float Flyr
Posted: Wed Aug 23, 2006 5:54 am Post subject: ALtimeter adjustment |
That's why I think some of the requirements for the compass swing is simply
out to lunch. Having the avionics and other flight equipment turned on may
account for a degree or two and having the engine charging system operating
may account for another degree of error. The probability is that the
shotgun in the back of the cabin, the hunting knife on your buddy's waist,
the outboard motor you have strapped to the float or the extra set of
headphones will swing your compass more than having the plane on a trailer
or having the engine switched off.
We are flying relatively slow aircraft VFR. That means we watch the ground
and make course corrections as necessary. This is why as long as the
compass points in the general direction of north we can use it.
While in this part of the world a magnetic compass is a primary navigation
instrument. It is also probably the least used instrument required.
Noel
Michel
ww.matronics.com/Navigator?Kitfox-List</a>
ics.com/contribution</a>
</b></font></pre>
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
