bsmith3163(at)aol.com Guest
Posted: Fri Aug 25, 2006 5:54 am Post subject: Mechanic near 35A? |
I found this on the EAA website:
"Condition Inspection
What is a Condition Inspection?
A condition inspection is the equivalent of an "annual" for a type
certificated aircraft. Although FAR Part 43 specifically states that it does
not apply to experimental airworthiness certificates, the operating
limitations on your homebuilt will include the following (or something
similar):
No person shall operate this aircraft unless within the preceding 12
calendar months it has had a condition inspection performed in accordance
with the scope and detail of appendix D to part 43, or other FAA-approved
programs, and found to be in a condition for safe operation. This inspection
will be recorded in the aircraft maintenance records. Condition inspections
shall be recorded in the aircraft maintenance records showing the following
or a similarly worded statement: "I certify that this aircraft has been
inspected on (insert date) in accordance with the scope and detail of
appendix D to part 43 and found to be in a condition for safe operation."
The entry will include the aircraft total time in service, and the name,
signature, certificate number, and type of certificate held by the
person performing the inspection.
See the condition inspection checklist for use in conducting annual
condition inspections.
Who can perform a Condition Inspection?
The inspection can be performed by any licensed A&P mechanic, an FAA
Approved Repair Station, or by the builder of the airplane provided the
builder obtains a "Repairman's Certificate" from the FAA. Note that unlike
an annual for a type certificated aircraft, the A&P mechanic does NOT have
to have his/her "Inspection Authorization".
Who can maintain a Homebuilt?
FAR Part 43 specifically states that the rules of that part do not apply to
amateur-built airplanes. Therefore, any maintenance on an experimental
airplane can be performed virtually by anyone regardless of credentials.
(This does not apply to the condition inspection previously discussed). Let
common sense be your guide as to what maintenance you conduct yourself."
The last paragraph holds what I believe to be the answer to your question.
I am new to this type of flying (experimental) so confirm this before you
act on it but I believe the owner may do all maintenance on his experimental
aircraft. If he is listed on the "Repairmans Certificate" then he can even
do the Annual Condition Inspection. If he is not the original builder and
he is not listed on the Repairmans Certificate, then he can not do the
Annual Condition Inspection. He then can have any A&P (one without a
Inspection Authorization is OK) do the annual.
Anyone else know this to be wrong or misleading?
Brian Smith
dosmythe(at)cox.net Guest
Posted: Fri Aug 25, 2006 5:59 am Post subject: Mechanic near 35A? |
Wingnut,
I might be off here but I "think" you can make the changes to your fuel
lines you just can't sign off the yearly conditional inspection. This might
not be the right attitude but nobody is ever going to know you changed the
fuel lines anyway. Besides, I don't think changing a fuel line would be
considered a major change any more than changing oil or spark plugs.
As far as the pitch trim goes, (this is just a thought) fabricate
another piece of linkage or screw the original one in/out to put the trim
tab back to zero and disable the servo until you can get to a spot for
further repairs. I rarely ever use my elevator trim.
Don Smythe
wingnut
Posted: Fri Aug 25, 2006 5:59 am Post subject: Re: Mechanic near 35A? |
| Quote: | Therefore, any maintenance on an experimental
Hmm. That's something to chew on. I guess I'll wait until I can talk to a loca A&P. Thanks for the heads up.
-Luis
pwmac(at)sisna.com Guest
Posted: Fri Aug 25, 2006 6:00 am Post subject: Mechanic near 35A? |
I never heard that the owner of an experimental cannot do his own
maint. or repairs. The only thing you cannot do if you did not build
the plane is the annual inspection. If you are confused about the
rules just ask the EAA and they will tell you what I said above. Just
follow the advice from the list members as to how to solve your leak.
Regards, Paul
At 07:23 AM 8/25/2006, you wrote:
The fuel odor in my kitfox is getting worse. I suspect that it's the
fuel lines so I want to have them replaced with automotive lines.
Only problem is that I'm not the builder so, as I understand it, I'm
not allowed to make this kind of modification myself... Any thoughts?
Can someone point me to a good shop in the near 34A (no FBO at my
airport). I need something close because my pitch trim decided to
stop working yesterday (it's stuck in the landing configuration) so
I'm giong to have to trailer it. I'm so depressed...
jose_m_toro(at)yahoo.com Guest
Posted: Fri Aug 25, 2006 6:02 am Post subject: Mechanic near 35A? |
"wingnut":
It is my understanding that you can do the lines
replacement and any other maintenance on your
experimental. What you can't do is to perform or sign
the annual condition inspection because you are not
the repairman.
Listers, if this information is incorrect, please
provide feedback for the benefit of all.
Regards!
Jose
--- wingnut <wingnut(at)spamarrest.com> wrote:
suspect that it's the fuel lines so I want to have
them replaced with automotive lines. Only problem is
(no FBO at my airport). I need something close
because my pitch trim decided to stop working
so I'm giong to have to trailer it. I'm so
depressed...
http://forums.matronics.com/viewtopic.php?p=57217#57217
Posted: Fri Aug 25, 2006 7:33 am Post subject: Mechanic near 35A? |
Luis:
Another source for this information is the EAA web
site, www.eaa.org. I know this specific question is
answered in that site.
Jose
up.
-Luis
http://forums.matronics.com/viewtopic.php?p=57228#57228
wingnut
funflyer1959(at)yahoo.com Guest
Posted: Fri Aug 25, 2006 9:59 am Post subject: Mechanic near 35A? |
i too had a fuel odor for a time and also couldn't determine the source. it ended up being from stress cracks at the formed ends near the welds of the aluminum wing fuel tanks. the cracks were so small that only minor discoloration from fuel occurred, but you still got the odor in the cockpit from the wing roots. the cracks were fortunately near the top of the tank and there was never any measurable loss of fuel. (of couse, lighting up a cigarette in the closed cabin would've been interesting) flying with the doors opened eliminated the odor and kept me flying til time for the annual inspection, at which time the wings were removed and slosh seal installed in both tanks. problem solved. finding the problem took a lot of looking, smelling and shaking of the plane with all the cowlings off and everything opened up for inspection. the stress cracks only appeared in one tank, but i sealed them both just to be sure.
wingnut <wingnut(at)spamarrest.com> wrote: [quote]--> Kitfox-List message posted by: "wingnut"
The fuel odor in my kitfox is getting worse. I suspect that it's the fuel lines so I want to have them replaced with automotive lines. Only problem is that I'm not the builder so, as I understand it, I'm not allowed to make this kind of modification myself... Any thoughts?
Can someone point me to a good shop in the near 34A (no FBO at my airport). I need something close because my pitch trim decided to stop working yesterday (it's stuck in the landing configuration) so I'm giong to have to trailer it. I'm so depressed...
Read this topic online Get your own [url= http://us.rd.yahoo.com/evt=43290/*http://smallbusiness.yahoo.com/domains]web address for just $1.99/1st yr[/url]. We'll help. [url=http://us.rd.yahoo.com/evt=41244/*http://smallbusiness.yahoo.com/]Yahoo! Small Business[/url]. [quote][b]
kirkhull(at)sbcglobal.net Guest
Posted: Fri Aug 25, 2006 7:11 pm Post subject: Mechanic near 35A? |
Maintenance on a homebuilt can only be done by an A&P or a person holding a
repairmans cert for that plane. Aka the builder. Not just anybody can do
the maintenance
eccles(at)Chartermi.net Guest
Posted: Sat Aug 26, 2006 5:31 am Post subject: Mechanic near 35A? |
I do believe that you can do the work as long as an A&P or person with a IA
rating supervises the work.
Posted: Sat Aug 26, 2006 6:32 am Post subject: Mechanic near 35A? |
I am pretty sure you can do the work yourself and log it into your required
log books without any A&P supervision. If you do not hold a repairmans
certificate (you didn't build the plane) then you must have a certified A&P
to sign off the annual condition inspection. I haven't looked into this
lately but I'm almost certain that is the way it used to be. Even on
certified aircraft, the owner is allowed to do certain maintenance without
an A&P.
Don Smythe
blackcatmoan(at)hotmail.c Guest
Posted: Sat Aug 26, 2006 11:14 am Post subject: Mechanic near 35A? |
Dear 'Wingnut':
Don't despair. Before you get all depressed, know this: Sometimes, the
trim gets stuck not because of a mechanical failure, but because the
rocker-switch gets worn-out. Obviously, it's intelligent to check all
possible points of failure, for safety's sake, but I would start with the
switch. So, FYI, here's a method for bringing a switch back into service:
Tools needed: Flat head screwdriver, phillips head screwdriver, a bit of
sandpaper or contact cleaning solution, good lighting, shop magnet (very
useful if you drop small springs on the hangar floor), and a good pot of
coffee (America's favorite drug!!).
1. Remove the side access-plate on your center cosole.
2. Stick your hand in there, underneath the switch (make sure master is
off!) and pinch the plastic tabs holding it in place. You should now be
able to pop it out of it's recess.
3. Crack open the plastic switch casing. OPEN IT SLOWLY AND CAREFULY.
There are springs in there that might pop out.
4. Look at the mechanism. If you notice, there is a rocker in there that
moves two springs on either end that push a 'contact cylinder' or 'tab' to
make contact (close the circuit).
5. These springs sometimes get compressed, and fail to push the contact
cylinders all the way. So, carefully pull the contact cylinders out, and
put them in a safe place. Next, pull the springs out. What you want to do
now is gently stre-e-e-e-e-tch them to make them just a bit longer (without
warping them). Next, with a bit of sandpaper, or contact cleaning solution,
you want to clean the contacts (which might be carbonized).
6. Put the switch back together. Now, turn on the master and test it.
Voilá! Hopefully, it should be almost good as new, and ready to give you
many more hours of service.
While you're at it, open the access hatch in the tail section, and make sure
the trim mechanism looks good (use the builder's manual as reference). Move
it up and down, and make sure it travels correrctly. And most importantly,
make sure THAT THE TRIM-MOTOR SERVICE BULLETIN IS COMPLIED
WITH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Literally, your life depends on
it.
I know you feel depressed and overwhelmed right now. But, when you own an
experimental, "hands-on" is the nature of the game, even if you didn't build
it.
When you make your first repair, and realize that YOU CAN DO IT, you'll be
very happy and it will seriously BOOST YOUR CONFIDENCE.
Then, when you realize that you just saved hundreds of dollars that you
would have had to pay an A&P, you'll feel even better!!!!
I hope this avoids you having to trailer it.
Best of luck,
Tony.
