Problems with High EGT readings
scc_ron(at)yahoo.com
PostPosted: Fri Aug 25, 2006 12:54 pm    Post subject: Problems with High EGT readings Reply with quote
Hey all,
I've just begun to have 1450+ EGT readings on all cylinders, while the CHT's remain below 390 degrees. No attempt to richen things up (carb heat for example) improves things. I took off the cowl and see no exterior signs of trouble, removed spark plugs and they are nice and tan and even wet from running too rich. I tried a brief flight and all was normal, then on the next long leg they did it again. I recycled the Grand Rapids EIS and then only one cylinder persisted in giving me this reading. Am I right to assume it is an indicator/gauge issue or am I missing something more ominous?
Thanks in advance for your ideas.
Ron
RV-4 N8ZD [quote][b]
brian-av(at)lloyd.com
PostPosted: Fri Aug 25, 2006 4:37 pm    Post subject: Problems with High EGT readings Reply with quote
On Aug 25, 2006, at 1:52 PM, Ron Patterson wrote:
Hey all,
If you have a sudden high EGT on all cylinders, check to see if one
mag has stopped working. If both mags are normal and CHTs are normal,
look for a gauge problem.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
FLYaDIVE(at)aol.com
PostPosted: Fri Aug 25, 2006 6:02 pm    Post subject: Problems with High EGT readings Reply with quote
In a message dated 8/25/06 8:41:24 PM Eastern Daylight Time,
brian-av(at)lloyd.com writes:
Brian:
If you reduce your spark in half your EGT goes DOWN not UP. Loss of a Mag
reduces combustion efficiency. If the timing is incorrect EGT can go UP but
usually the Oil and CHT follows.
Ron said CHT was 390 F but he did not say that was his NORMAL ... Only that
is below 390F.
What Ron should be looking for is something that will cause LEANING ...
either Less Fuel or More Air.
My first place to look would be an AIR LEAK around the Carb.
Second place would be the rubber coupling on the intake, but the chances of
that are very slim since ALL cylinder increased EGT.
Third place is an EXHAUST Leak. Around the flanges ... Ron, you didn't use
those cheep soft exhaust gaskets?
I have a very difficult time believing that all 4 EGT probes drifted in the
same direction. Or that the EIS failed in such a manor that ONLY the EGT was
affected and not the CHT.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Jim Baker
PostPosted: Fri Aug 25, 2006 6:32 pm    Post subject: Problems with High EGT readings Reply with quote
Loss of a
Mag reduces combustion efficiency.
Nope. EGT should rise about 50 degrees F on all cylinders. Think a
bit more about this and you'll understand why it work this way....
Jim Baker
580.788.2779
'71 SV, 492TC
Elmore City, OK
flyeyes(at)mac.com
PostPosted: Fri Aug 25, 2006 6:45 pm    Post subject: Problems with High EGT readings Reply with quote
On Aug 25, 2006, at 3:52 PM, Ron Patterson wrote:
Hey all,
Ron
RV-4 N8ZD
Hi Ron
As Brian mentioned, loss of one ignition will cause all the EGTs to rise simultaneously, along with a small loss of power and slightly lower CHTs.  I have had these exact symptoms caused by an ignition failure in the climb--I noticed it when EGTs went well above their normal peaks as I tried to lean.  You can diagnose this quickly by cycling the mags in the air, but this is probably best done without your wife in the back seat (or so I've heard.  At length.).
I think it's most likely an indicator issue, but would check ignition first.  I have a vague recollection of reading about similar symptoms with an EIS with a wiring issue sometime in the last few weeks.  You might  want to try Greg at Grand Rapids--he seems to be pretty responsive.  A search of the various RV/aerolelectric forums and Doug's VAF site for "EIS" and "EGT" might turn up some relevant posts.
James Freeman
Kellym
PostPosted: Fri Aug 25, 2006 6:49 pm    Post subject: Problems with High EGT readings Reply with quote
Sorry Barry, but Brian is correct. Demonstrable on any mag check during
run up or an in flight mag check. The flame front propagates slower with
single ignition, and burns longer in the cylinder, making it hotter
coming out the exhaust.
Brian:
is below 390F.
Kelly McMullen
KCHD
oldbob(at)beechowners.com
PostPosted: Fri Aug 25, 2006 7:14 pm    Post subject: Problems with High EGT readings Reply with quote
Good Evening Barry,
May I suggest that you rethink that a bit?
When operating on one magneto, the EGTs will rise.
Why?
Because the timing is effectively retarded and the
peak temperature occurs later in the combustion cycle.
The fire gets closer to the point where it is
measured. The actual peak combustion pressure and
temperature will both be lower, but due to the timing
change, the EGTs Will be higher.
Happy Skies,
Old Bob
--- FLYaDIVE(at)aol.com wrote:
FLYaDIVE(at)aol.com
Daylight Time,
check to see if one
Brian:
is below 390F.
the Carb.
Barry
"Chop'd Liver"
time."
Yamashiada
browse
Subscriptions page,
FAQ,
Web Forums!
Admin.
altoq(at)cebridge.net
Barry,
I always get in trouble when I do this but, here goes. By eliminating one
of two firing positions, You effectively retard timing because Peak BMEP
occurs later. Combustion is incomplete, some of what does not burn in the
chamber, burns in the exhaust pipes, hence, higher EGT. CHT may or may not
be lower (depends on too many other things). I would initially look for a
primary ignition fault.
John D.
DO NOT ARCHIVE
Brian:
but
that
is below 390F.
of
use
the
was
Barry
"Chop'd Liver"
mprather(at)spro.net
PostPosted: Fri Aug 25, 2006 7:33 pm    Post subject: Problems with High EGT readings Reply with quote
Turning off one mag slows down the combustion process - effectively
retarding the spark timing. That will cause the EGT to rise because more
of the fuel air mixture will be left burning when the exhaust valve opens.
Cylinder pressure WILL be lower..
See John Deak and George Braly for more info. Or.. Try it on your plane.
Matt-
Brian:
is below 390F.
was
Barry
"Chop'd Liver"
time."
Yamashiada
PostPosted: Fri Aug 25, 2006 7:47 pm    Post subject: Problems with High EGT readings Reply with quote
> normal,
Brian:
Normally I try to be diplomatic but in this case I will make an
exception. You are just plain wrong.
Proof:
Turn off one mag in cruise and watch your EGT go up by about 100F.
Reason:
With both mags working you have two flame-fronts in the combustion
chamber. This means that combustion completes sooner allowing more
time for the gas to transfer heat to the components in the cylinder
thus leading to cooler gas going out the exhaust. When you turn off
one mag you have only one flame front and the combustion time is
slightly longer. There is now less time after the end of combustion
and before the exhaust valve opens so your EGT is higher.
Loss of a Mag reduces combustion efficiency.
Yeah, so?
Actually, if you get advanced timing your CHT will go up but your EGT
will go down for the reasons I outlined above. Detonation will do the
same thing.
Only that
is below 390F.
I read that to mean that he did not see an increase in CHT.
LEANING ...
Perhaps. The simplest explanation for a 100F rise in EGT across all
cylinders without a rise in CHT is the loss of a mag. (Actually CHT
will drop slightly as less heat is transferred to the head.) It is
also pitifully easy to check. After that it is time for more
difficult tests and inspections.
