		Martin Pohl
  Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
				 Posted: Fri Aug 25, 2006 8:04 am    Post subject: Fuel Tank Leakage Test |
				I am currently trying to test my fuel tanks (including fuel line to the wing root) for leakages.
 Problem: I want to follow Bingelis' instruction using a balloon at the fuel tank vent. It is quite difficult to seal the fuel tank filler neck properly. How did you do that? Any advice?
 Cheers from Switzerland
 Martin
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
		hrs1(at)frontiernet.net Guest
				 Posted: Fri Aug 25, 2006 9:46 am    Post subject: Fuel Tank Leakage Test |
				Martin, I used surgical gloves which really look weird when blown up.
 After putting the entrance to the glove over the filler neck, I took a
 couple of large rubber bands - about 7" in length from bend to bend and
 wrapped them around the filler neck as tightly as possible.  I then
 filled the glove through the fuel line, and had a C clamp near the end
 which I clamped down on the hose once the glove was filled.  Test the
 balloon / filler neck with some soapy water to see if you have any leaks
 there.  If not, enjoy a beer and wait about 2 hours to see whether the
 glove deflates.  If so, reinflate the glove and then start testing
 joints the fuel line, etc. for leaks.  Hope this helps. Robert
 Schoenberger 701
 Martin Pohl wrote:
  Martin
  Martin Pohl
  Zodiac XL QBK
  http://forums.matronics.com/viewtopic.php?p=57270#57270
		sales(at)steelframe.com.a Guest
				 Posted: Fri Aug 25, 2006 2:18 pm    Post subject: Fuel Tank Leakage Test |
				Best thing to use is a Condom,
 works better than a balloon.
    Ron Saarinen
		Martin Pohl
				 Posted: Sat Aug 26, 2006 2:50 am    Post subject: Re: Fuel Tank Leakage Test |
				Thank you for all your ideas. Will try how that works...
 Cheers Martin
Zodiac XL QBK
