Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Mon Aug 28, 2006 4:55 am Post subject: Turn on ALT before engine start? |
In an airplane equipped with a Continental 0-200, would you want to turn on the ALT switch before engine start, or after?
Thanks!
brian-av(at)lloyd.com Guest
Posted: Mon Aug 28, 2006 7:09 am Post subject: Turn on ALT before engine start? |
On Aug 28, 2006, at 5:55 AM, Bill Denton wrote:
<bdenton(at)bdenton.com>
It doesn't matter. Do what makes you feel most comfortable.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
nuckollsr(at)cox.net Guest
Posted: Tue Aug 29, 2006 6:09 am Post subject: Turn on ALT before engine start? |
At 05:55 AM 8/28/2006 -0700, you wrote:
It makes no difference. The arguments for and against
either philosophy are not backed by good science meaning
that effects cited as undesirable are so weak as to be
insignificant.
This presumes that you have a "controllable" alternator,
i.e. a separately regulated machine wherein the panel mounted
alternator switch has control over the alternator's field
supply.
The present state of the art for control systems intended
to bring some measure of protection against failures of
internally regulated alternators offers a means by which
the machine can be damaged if inadvertently turned off
by disconnection of the b-lead which produces a load-dump
that can be deleterious to the alternator. Many internally
regulated alternators cannot withstand their own load dumps.
In these cases, one may turn the alternator ON at any time
but it's prudent to wait until the engine stops turning to
turn it OFF.
In the mean time, know that a control system for internally
regulated alternators is "in the works" with an achievable
goal of making the IR alternator behave as if it were
an externally regulated machine. This will offer the
OBAM aircraft builder the option of using the stock
internally regulated alternator as a form-fit-function
replacement for the traditional externally regulated
system at a fraction of the cost and without giving
up functionality or control
< with experiment. >
< --Lawrence M. Krauss >
Hopperdhh(at)aol.com Guest
Posted: Tue Aug 29, 2006 6:35 am Post subject: Turn on ALT before engine start? |
In a message dated 8/29/2006 10:16:33 A.M. Eastern Daylight Time, nuckollsr(at)cox.net writes:
| Quote: | In the mean time, know that a control system for internally
I'm really glad to hear that this is in the works, Bob. Even thought I am pretty familiar with alternators and regulators, the Van's 60 amp internally regulated alternator on my airplane is a "black box." I have no idea what function the 2 wires that run from the "field" breaker to the alternator serve. I believe it is a Nippondenso system. In the meantime, do you know of any available documentation which would reveal any details of its operation?
Dan Hopper
RV-7A
Posted: Tue Aug 29, 2006 7:39 am Post subject: Turn on ALT before engine start? |
At 10:34 AM 8/29/2006 -0400, you wrote:
| Quote: | In a message dated 8/29/2006 10:16:33 A.M. Eastern Daylight Time,
of its operation?
Not that I've been made privy to. That's a major
stumbling block for my personal approach to
systems integration, failure mode effects analysis
and mitigation.
I'm going to look at an alternator drive
stand this weekend that I'm told is a 2+
hp machine with variable speed drive and
isn't covered in more barn-bird-crap than
one would want to wash into the gutters in
front of my house.
If this machine can be resurrected, I'll
be able to characterize the performance of
any product one wishes to examine. I have
a couple of alternators here now that came
from folks on the List that I want to
put into a Z-11 mock-up and characterize
their performance and/or failures.
It seems unlikely that we'll ever be privy
to detailed inner workings of all the options
out there. I'll suggest a prudent approach
that assumes nothing.
Posted: Wed Aug 30, 2006 8:01 am Post subject: Turn on ALT before engine start? |
At 09:47 AM 8/30/2006 -0500, you wrote:
| Quote: | Here's a bit of background on my question...
I was considering panel layouts for an OBAM (Experimental) aircraft, so
there would be no "procedures" other than what I set myself.
I am a firm believer in standardization as I have done a great deal of
computer software development, and I always follow the human interface
standards unless there is a very good reason not to.
But there may rarely be reasons for overriding a standard, or you may have
conflicting standards. For example, workflow patterns are typically set
using a "left to right; top to bottom" flow model.
You will note that in most small single engine aircraft, the standard is
to have the mag/starter switch on the left, with the master switch(es)
(bat and alt) on the right. This violates the typical workflow model as
you must first turn on the battery master (at minimum), then move left to
start the aircraft.
I am considering overriding the "standard" placement and using a
workflow-based placement.
In this instance, you would have the battery master on the left, with the
mag/starter switch to the right.
The question then arises as to when the alt switch should be turned on,
and I recall reading someplace at some time (how's that for precision!)
that it might be best not to turn on the alt switch until after engine start.
If you would turn on the alt switch before engine start, I would use a
layout of: battery master - alt - mag/starter.
But if you would turn the alt switch on after engine start, I would use a
layout of: battery master - mag/starter - alt.
The concept would be maintaining the left-to-right workflow model...
Very good sir. A lucid consideration of both human factors
and the value of procedures but within the OBAM aviation venue.
This validates my perceptions of your question and does not
change my answer. Thank you for the clarification.
