hcourier(at)cox.net Guest
Posted: Sat Aug 26, 2006 6:53 pm Post subject: Looking for parts for a AC 680 FLP |
Gentlemen:
I'm looking for parts again. Need two items, one is needed ASAP.
Aircraft - 1964 Aero Commander 680 FLP w/Mr. RPM Conversion, SN 1479-6
Parts Needed:
1. ASAP - I need the idler arm, or bracket or whatever it may be called, that attaches to the right engine on one end and to
the right engine alternator on the other end. Midway on this bracket is the eccentric idler wheel used to adjust
belt tension. The arm has a slight bend to it in near the middle. The old arm broke at the bolt hole on the engine side. We've looked for a part number in the manuals and on the part but no luck. I didn't think of it today, but tomorrow I'll take a picture of the item in case that may help anyone who thinks they might have a part.
So many of you guys out there are so knowledgeable about the Aero Commanders you probably know how much it weighs, what time of day it was made, and the name of the wife and children of the guy who made it. (Ha! Ha!)
2. Fuel cap - The cap used is about 2 1/2" diameter, and has a zeus type fastener that engages the anti-siphon value in the
fuel tank. The small leaf spring on the cap I have is about useless and I have to check after every refueling to
be sure the cap is locked in place because the small leaf spring gets out of place and doesn't do it's job.
If anyone has such items please email me at www.hcourier(at)cox.net. My cell phone is 850-217-5185, it's always with me, call
anytime. If I'm flying or asleep I turn it off otherwise it rules my life.
Thank you,
Ray Mansfield
Ft. Walton Beach, FL
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
Posted: Sat Aug 26, 2006 7:43 pm Post subject: Looking for parts for a AC 680 FLP |
(Note: I thought I sent this once, but I didn't get my copy. If this is a repeat please excuse)
Gentlemen:
Parts Needed:
Thank you,
Ray Mansfield
kamala(at)MSN.COM Guest
Posted: Sun Aug 27, 2006 4:35 am Post subject: Looking for parts for a AC 680 FLP |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> rm, there is a aircraft welding shop in san antonio, tx that repaired mine. reasonably priced. from lycoming they are unconcienably expensive. mason
bowing74(at)earthlink.net Guest
Posted: Sun Aug 27, 2006 10:26 am Post subject: Looking for parts for a AC 680 FLP |
Heck Ray,
You’re over on the “Redneck Riviera”. You should take it over to Bubbas Welding shop and Florist and “Geet er done” $20.00.
bilbo
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Ray Mansfield
Sent: Saturday, August 26, 2006 10:53 PM
Subject: Looking for parts for a AC 680 FLP
Gentlemen:
Aircraft - 1964 Aero Commander 680 FLP w/Mr. RPM Conversion, [b]SN 1479-6[/b]
Parts Needed:
Thank you,
Ray Mansfield
01234567890123
moe(at)rosspistons.com Guest
Posted: Mon Aug 28, 2006 5:49 am Post subject: Looking for parts for a AC 680 FLP |
Ray,
Jack Chappell has the fuel caps. 1.951.371.7513.
Moe Mills
N680RR 680F(p)
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of MASON CHEVAILLIER
Sent: Sunday, August 27, 2006 5:34 AM
Subject: Re: Commander-List: Looking for parts for a AC 680 FLP
wjrhamilton(at)optusnet.c Guest
Posted: Mon Aug 28, 2006 6:09 pm Post subject: Looking for parts for a AC 680 FLP |
Ray,
Contact General Aviation Maintenance, GAM, Steve Nott, in Melbourne, Australia. Phone +61 3 9379 1019, fax +61 3 9374 2620.
Also, there is a firm here , J&R Aerospace, who make a range of hard to get bits for Aero Commanders, they can reproduce to a pattern, that would probably need a DER/337 sign-off, depending on the views of your A&P/IA.
Bill Hamilton
At 12:52 PM 27/08/2006, you wrote:
[quote]Gentlemen:
Parts Needed:
Thank you,
Ray Mansfield
