XA-D210 and XA-D211 Pinouts
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> XDP4000X-List
Site Admin
PostPosted: Tue Aug 29, 2006 10:54 am    Post subject: XA-D210 and XA-D211 Pinouts Reply with quote
At 05:13 AM 8/29/2006 Tuesday, you wrote:
--> XDP4000X-List message posted by: Christopher Scoles <crscoles(at)yahoo.com>
Hi everyone. I am new to your list. I thought I would introduce myself. My name is Chris. I have had a Sony ES 910 for years and am now finally starting to build out the system. I recently picked up an XDP-210EQ. I looked for a 4000 for a while, but they seem to be very hard to come by. My first question is regarding the XA-D210/211 adaptor. I have been trying to pick one up for a while. There were two on ebay just recently, but I lost out on both auctions. Anyway, I been through your archives researching alternatives to the adaptor. I was specifically looking for the actual pinout for the plug. I know there are three different channels, VCC, Data, and Ground. What I couldn't find is which ring on the plug is which? The reason I ask is because, I found this converter, http://cgi.ebay.com/Audio-Authority-977T-977TPO-Digital-Converter_W0QQitemZ5805001032QQihZ008QQcategoryZ14968QQssPageNameZWD1VQQrdZ1QQcmdZViewItem.  I believe it will work if you
could get a cable with the correct plug configuration on the head unit end. Any thoughts, opinions, or help would be appreciated. Thanks.
Chris
Hi Chris,
These guys might have one (scroll to the bottom of the page):
http://www.mcs-direct.co.uk/acatalog/Sony_Accessories.html
Also, the German Amazon.de seems to list it:
http://www.amazon.de/gp/product/B00006OAHH/028-1978638-1838131?v=glance&n=562066
And here as well:
http://www.edbpriser.dk/Listprices.asp?ID=147035
I took a look at the schematics on the CDX-C90 today and found a little information on the pinout for the XA-D210/D211. I've included a snippet of the schematic below that details the specific information related to the XA-D210/D211.
Looks like Pin1=VCC (+5v), Pin2=Data, and Pin3=Grd. This probably means, that for the XA-D210, the TIP is +5v, the next in ring is DATA, and the shoulder is Ground (connection closest to the plastic).
You should verify this with a Volt meter and optionally a oscilloscope.
As far as a digital to toslink converter, you might also want to take a look at your local Radio Shack. They used to have a number of devices for converting. Seems like they were around $20.
Best of luck!
[img]cid:.0[/img]
- The Matronics XDP4000X-List Email Forum -
http://www.matronics.com/Navigator?XDP4000X-List
 Filesize:  126.64 KB
 Viewed:  1476 Time(s)
 Filesize:  68.63 KB
 Viewed:  1291 Time(s)
PostPosted: Tue Aug 29, 2006 12:11 pm    Post subject: XA-D210 and XA-D211 Pinouts Reply with quote
Thanks Matt,
I contacted MCS a while ago, they don't ship outside the UK. I have no idea about the Danish company. My girlfriend lives in Germany, so I will probably go that route if I can't figure something out.
The reason I chose the Audio Authority one was because it was the only one that runs off 12v DC. Everything else seems to be 6V-9V. I figured it would be fairly easy to wire it to turn on with the head unit instead of finding a cigarette lighter power adapter or something of that sort.
Site Admin
PostPosted: Tue Aug 29, 2006 12:17 pm    Post subject: XA-D210 and XA-D211 Pinouts Reply with quote
6-9v is actually what you want. You've already got 5v coming from the C90 for powering the XA-D211. That should be sufficient to power the other devices. That way you don't have to mess with extra power and how to turn it on and off.
Matt
At 01:09 PM 8/29/2006 Tuesday, you wrote:
[quote]Thanks Matt,
PostPosted: Wed Aug 30, 2006 9:58 am    Post subject: XA-D210 and XA-D211 Pinouts Reply with quote
Well, this just became a moot point. I found an XA-D210 on ebay. So, I am all set.
But, because the discussion was interesting, I will continue my line of thought. I had thought of using the 5V out of the plug, but that seemed a little more complicated to get at. 12V tends to be very easy to find in the car. I could have ran a wire from the 12V turn on wire or power antenna lead. I think that would have been easier than trying to concoct a way to get the 5V off that plug.
Chris
Site Admin
PostPosted: Thu Aug 31, 2006 8:58 am    Post subject: Re: XA-D210 and XA-D211 Pinouts Reply with quote
Those pcm-to-toslink converters run on 5v internally. The 6-9v ac adapter that comes with it supplies the 7805 regulator on the board. Likely you could have just powered the converter right off of 5v or worst case just bypassed the 7805 regulator on the converter.
In anycase, finding a XA-D210 is an even better option! Smile
Best regards,
Matt
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> XDP4000X-List All times are GMT - 8 Hours
