cirrus10(at)qwest.net Guest
Posted: Tue Aug 29, 2006 3:15 pm Post subject: wing spars |
I am the second owner of a 6 in which the previous owner did very little constructionwise, and am at the point of attaching the wings. One of wings fore spars has a bend on the vertical (perpendicular to the shear of the insert). It is a continuous bend from end to end, and is 3/16" - 1/4" at the apex. I carefully inspected the rivets and glue joints on that spar and see nothing unusual.
Problem? Do I need to replace the spar?
Thanks for any advice,
Ed
donpearsall Guest
Posted: Tue Aug 29, 2006 4:04 pm Post subject: wing spars |
Ed, I am having trouble visualizing what you are describing. Can you attach a photo of the part you are talking about?
Don
[quote] From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of cirrus10
Sent: Tuesday, August 29, 2006 4:14 PM
Subject: wing spars
Ed
ddsyverson(at)comcast.net Guest
Posted: Tue Aug 29, 2006 4:24 pm Post subject: wing spars |
Ed,
I am having a bit of difficulty visualizing where the damage is and what it
looks like.
Any chance you have a digital photo?
Tubular spars depend on their strength from their shape.
Any bend will change the overall strength of the tube and will quite likely
create a stress riser where a crack may start at some unknown time in the
future. You may no longer be at design strength. It also makes a difference
if it is in the middle of the spar, at the inboard attach point or on the
last quarter inch on the outboard end.
Do you have the construction manual? What does it say about evaluating the
condition of the spar tubes?
I threw away two spar tubes for my model 7 because I didn't like the scratches
(Radial scratches - 0.003 - 0.005" deep) and got new ones.
I may be a bit more conservative than some. I would be reluctant to advise
anyone to incorporate a damaged spar tube in the wing.
Knowing what the actual strength is on a damaged spar, is a real experiment -
too much of an experiment for me.
Sincerely,
Dave S
St Paul, MN
On Tuesday 29 August 2006 6:14 pm, cirrus10 wrote:
| Quote: | I am the second owner of a 6 in which the previous owner did very little
and see nothing unusual. Problem? Do I need to replace the spar?
Ed
rliebmann(at)comcast.net Guest
Posted: Tue Aug 29, 2006 5:08 pm Post subject: wing spars |
[quote] Hi Ed,
As I read your note, as you look down the spar with the web vertical, the bend goes either to the right or left depending.....is this correct?
Is the wing completely built?
Send digital pics to the list if ya can....
Ron N55KF
Ed
Posted: Tue Aug 29, 2006 5:30 pm Post subject: wing spars |
Thanks Dave,
There is really no damage per se. It's more of a slight bow, no point along
the spar can I say is the beginning or the end of the bow. It's more like a
cue stick that is bowed continuously from one end to the other. The thing
is, that it is bowed on the shear of the insert.
Ed
Posted: Tue Aug 29, 2006 5:34 pm Post subject: wing spars |
Actually, it's bowed on the shear of the insert, so it is up and down. The wing was factory built. There is no actual damage, but a slow bow from one end to the other.
What's the possibility of removing that spar with heat?
Ed
Guy Buchanan
Posted: Tue Aug 29, 2006 6:04 pm Post subject: wing spars |
Since you're at the point of attaching the wings that means they're
assembled without strut fittings. It also means the bend must be vertical,
(which you state,) since a horizontal bend would be evident in both spars.
(The ribs should force the spars to be parallel, though it's certainly
possible they were installed with a bow in the forward spar.) However, a
vertical bend should be in the plane of the shear web of the insert, not
perpendicular to it. The shear web should be a vertical "I" beam. Some
clarification is required.
Given the bend is vertical, and about 3/16 - 1/4", you then have almost 1/2
degree twist in the wing just due to the bend. If so, you may be able to
trim the aircraft with the struts, but you're stall behavior will probably
be less than desirable. Not to mention your aircraft will look like crap to
the naked eye. (You'd be surprised how easy it is to see unnatural
deformations.) I vote replace the spar. (I'd bend it back if the shear web
weren't installed. There's too much of a risk of de-bonding the shear web
with it installed.)
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
john(at)leptron.com Guest
Posted: Tue Aug 29, 2006 6:07 pm Post subject: wing spars |
Ed,
1/4 “ does not seem like much, is the wing covered, and how is the wash out. if the wing is not covered you can take it out with the shrinking of the fabric. You could take the spar out with heat but it does not seem like much.
John Oakley
Sent: Tuesday, August 29, 2006 7:34 PM
Subject: Re: wing spars
Ed
Posted: Tue Aug 29, 2006 8:21 pm Post subject: wing spars |
Ed,
Is the leading edge on now? Removing and replacing this might fix the problem. Don’t panic yet, it does not seem bad.
John Oakley
Ed
janderson412(at)hotmail.c Guest
Posted: Tue Aug 29, 2006 11:42 pm Post subject: wing spars |
If the wing is built, could it have been done on an wrongly set up jig?? And
yes 1/4" over the full length doesn't seem much?? John A.
Subject: RE: wing spars
Date: Tue, 29 Aug 2006 20:13:06 -0600
Ed,
much.
John Oakley
end to the other.
Ed
Float Flyr
Posted: Wed Aug 30, 2006 2:47 am Post subject: wing spars |
Never heat structural aluminium! ..... Not and use it again.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Wed Aug 30, 2006 5:03 am Post subject: wing spars |
You're correct, parallel not perpendicular.
To remove the spar is the next question. Would you suggest heating the tube
and prying it away from the ribs? Thanks.
Ed
Posted: Wed Aug 30, 2006 5:08 am Post subject: wing spars |
John,
No, the leading edge is not on. I,ll try some clamping with the leading edge, and see if I can get some of the bow out. Thanks.
Ed
Posted: Wed Aug 30, 2006 5:09 am Post subject: wing spars |
The wing was factory built, aand yes that is a possibility. Thanks.
Ed
Posted: Wed Aug 30, 2006 5:10 am Post subject: wing spars |
Noel,
I meant for removal purposes, but that info is good to know,. Thanks.
Ed
Posted: Wed Aug 30, 2006 5:34 am Post subject: wing spars |
Ed,
Lay the wing upside down to help remove the bow. Place the leading edge in position, and then run continuous tape top and bottom of the leading edge.
Sorry if I am pushy, I built several of these guys and learned a bunch. (ok, sometimes I think I am an expert) just slap me.
John Oakley
Sent: Wednesday, August 30, 2006 7:08 AM
John,
Ed
Posted: Wed Aug 30, 2006 6:06 am Post subject: wing spars |
Ed,
The stringers that hold the false ribs may hold the problem also, I assume they are in.
John Oakley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of John Oakley
Sent: Wednesday, August 30, 2006 7:39 AM
Ed,
John Oakley
John,
Ed
Posted: Wed Aug 30, 2006 6:40 am Post subject: wing spars |
On the contrary John. I'm not into reinventing the wheel, and you're expertise is always appreciated. The stringer is installed on the top only. Thanks again.
Ed
Guy Buchanan
Posted: Wed Aug 30, 2006 6:55 am Post subject: wing spars |
At 06:02 AM 8/30/2006, you wrote:
| Quote: | To remove the spar is the next question. Would you suggest heating the tube
You don't really heat the tube, just the adhesive where the ribs bond.
(Although if you're going to toss the tube you could just blow a torch down
the middle, get the tube nice and hot, and then pull it off in one shot. Neat.)
Guy Buchanan
Deceased K-IV 1200
Posted: Wed Aug 30, 2006 7:13 am Post subject: wing spars |
Hi Ed,
I think I have the whole picture now,
The area with the insert is not bowed permanently because the insert is straight. So the problem was in jigging. The worse case scenario is taking off the upper stringer and rigging the wing to re install the stringers and leading edge. I have never seen a bent spar unless is damaged so no worry there. Both Dan and Phil were both very careful in their selection and inspection of materials. One more question, is the wood varnished?
John Oakley
Sent: Wednesday, August 30, 2006 8:40 AM
Ed
