Deems Davis
Posted: Tue Aug 29, 2006 5:12 pm Post subject: Garmin D sub pin removal ?? |
What's the secret to removal of the SMALL Garmin machined pins (as in
the GMA 340) from a Dsub connector? The tool for the larger pins won't
fit, I thought I heard someone say they used a paperclip filed flat, and
I've tried that to no avail yet. Would appreciate any suggestions as
I've mis placed some pins.
Deems Davis # 406
Fuse/Finishing/Panel
http://deemsrv10.com/
Posted: Tue Aug 29, 2006 5:29 pm Post subject: Garmin D sub pin removal ?? |
Check the archives - recently there was a thread on pins and there was a
picture of two different tools red for the 'normal' size and green (IIRC)
for the high density.
I don't remember which list but it was within the last few days.....I have
the other tool - I'll try to remember this weekend to get part num......
Ralph
planepubs(at)ev1.net Guest
Posted: Tue Aug 29, 2006 5:36 pm Post subject: Garmin D sub pin removal ?? |
I've removed those pins with the throwaway removers. Make sure you're using the correct color, which naturally escapes me now. I've also broken a few of those plastic tools on them.
Al
On 08/29/2006 8:11:26 PM, Deems Davis (deemsdavis(at)cox.net (deemsdavis(at)cox.net)) wrote:
[quote] --> AeroElectric-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
I've
Deems Davis # 406
Features Browse, -->
bsp; available gt; ===========
bsp; - NEW MATRONICS LIST WIKI -
wgill10(at)comcast.net Guest
Posted: Tue Aug 29, 2006 5:49 pm Post subject: Garmin D sub pin removal ?? |
Go to:
http://www.steinair.com/connectors.htm
SAT-034 is for the high density pins
nuckollsr(at)cox.net Guest
Posted: Tue Aug 29, 2006 6:03 pm Post subject: Garmin D sub pin removal ?? |
At 06:11 PM 8/29/2006 -0700, you wrote:
What's the secret to removal of the SMALL Garmin machined pins (as in the
GMA 340) from a Dsub connector? The tool for the larger pins won't fit, I
thought I heard someone say they used a paperclip filed flat, and I've
tried that to no avail yet. Would appreciate any suggestions as I've mis
placed some pins.
You need a tool like
http://www.aeroelectric.com/Mfgr_Data/Connectors/AMP_Tyco/91285-1_Extraction_Tool.pdf
which offers interchangeable blades for working
both the 20 and 22HD sized d-sub connectors.
DigiKey offers this tool in the upper end of right hand
column at:
http://dkc3.digikey.com/PDF/T062/0181.pdf
dsvs(at)comcast.net Guest
Posted: Tue Aug 29, 2006 6:17 pm Post subject: Garmin D sub pin removal ?? |
Steinair has it. It is part 2 SAT-034
Posted: Tue Aug 29, 2006 8:02 pm Post subject: Garmin D sub pin removal ?? |
Yes, it was the green color tool that I used/abused! Thanks Bill.
glineberry(at)earthlink.n Guest
Posted: Wed Aug 30, 2006 7:35 am Post subject: Garmin D sub pin removal ?? |
SteinAir has a tool for these pins listed at $5.00
