ruebd(at)skymail.csus.edu Guest
Posted: Wed Aug 30, 2006 7:43 am Post subject: wing spars |
Gentlemen:
If you degrade an aircraft structural member by heating it,
please be sure it never gets into the hands of someone who may want to
use it for it's original purpose. None of us would want to ever be
'fooled' by assuming that a piece of aircraft metal is as marked if it
isn't.
This may seem trivial, but if you were fooled by assuming that a
piece of aircraft metal was in it's marked condition and then used it in
your baby, and then --- , well, you see what I mean. Either cut off the
heated (altered) portion or clearly mark the piece as altered and no
longer useable for aircraft construction.
Duane Rueb
hank(at)hankseidel.com Guest
Posted: Wed Aug 30, 2006 8:06 am Post subject: wing spars |
Hi,
My wings were factory built and when I was setting up to attach them it became obvious that the front spar would have to be bent to have the attachment pin pass vertically through the center of the spar. I called the factory before continuing and was told not to bent the spar at all but to drill off center. Looks odd but that is what they told me to do. I am curious as to whether your spars have the correct separation at the inboard end. Perhaps the previous owner introduced a bend to correct the same sort of problem I had with my quick build wings.
Hank
On Aug 29, 2006, at 6:14 PM, cirrus10 wrote:
| Quote: | I am the second owner of a 6 in which the previous owner did very little constructionwise, and am at the point of attaching the wings. One of wings fore spars has a bend on the vertical (perpendicular to the shear of the insert). It is a continuous bend from end to end, and is 3/16" - 1/4" at the apex. I carefully inspected the rivets and glue joints on that spar and see nothing unusual.
Problem? Do I need to replace the spar?
Thanks for any advice,
Ed
Fox5flyer Guest
Posted: Wed Aug 30, 2006 8:09 am Post subject: wing spars |
With that tiny bid of bend, it's probably just from the way it was glued and
I doubt it would ever cause any sort of problem or even be perceptible when
covered. As someone said, use the fabric shrinking to straighten it.
Deke
cirrus10(at)qwest.net Guest
Posted: Wed Aug 30, 2006 8:57 am Post subject: wing spars |
Hank,
One of the first measurements I made were the tube distances, and they were both the same, 27.5" c to c.
Thanks.
Ed
Posted: Wed Aug 30, 2006 8:59 am Post subject: wing spars |
Thanks Duane, good advice.
Ed
Posted: Wed Aug 30, 2006 9:00 am Post subject: wing spars |
John,
No, not varnished. I will take your advice and reglue the stringer.
Ed
Posted: Wed Aug 30, 2006 9:01 am Post subject: wing spars |
Thanks Deke.
Posted: Wed Aug 30, 2006 9:02 am Post subject: wing spars |
Thanks Guy, good info.
Float Flyr
Posted: Wed Aug 30, 2006 2:35 pm Post subject: wing spars |
Sorry about that Ed As I got deeper into the thread this morning it became evident that you were trying to soften the epoxy to remove the ribs. I just got back to the 'puter tonight.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
occom
Posted: Wed Aug 30, 2006 3:19 pm Post subject: wing spars |
Posted: Wed Aug 30, 2006 3:43 pm Post subject: wing spars |
Not a problem. Just thanks to you and everyone else who has emailed.
Ed
Posted: Wed Aug 30, 2006 3:48 pm Post subject: wing spars |
Lucky for me that it's the leading edge spar. I think I will be able to pry it as I'm using the heat. Thanks again for the help.
Ed
shilocom(at)mcmsys.com Guest
Posted: Thu Aug 31, 2006 3:02 am Post subject: wing spars |
Generally so, but not exactly. 6061-T6 actually has a slight increase in tensile properties up to 440 degrees for up to 30 min. I looked into this when I was considering powder coating an aluminum frame, but never did do it. Bob U.
