n223rv(at)wolflakeairport Guest
Posted: Sun Sep 03, 2006 4:17 am Post subject: XM Antenna through Fiberglass? |
I have had success mounting the GPS antenna under the fiberglass cowl, so I thought I'd try it with my XM antenna. It seems to work, but not as well. The weather seems to take longer to download and the music is spotty at times. I don't know if it is because I have it close to the baffles and it may be blocking reception during climbs in certain directions, or if it is because of the fiberglass.
Has anyone had success mounting theirs under fiberglass?? Does anyone know if it should work?
-Mike Kraus
RV-4 flying
RV-10 building
brian.kraut(at)engalt.com Guest
Posted: Sun Sep 03, 2006 6:37 am Post subject: XM Antenna through Fiberglass? |
I had one in my KR-2 under the fiberglass turtledeck and it worked fine. I would worry more about the heat than anything under the cowl.
Brian Kraut
Engineering Alternatives, Inc.
www.engalt.com [quote] --
sjhdcl(at)kingston.net Guest
Posted: Mon Sep 04, 2006 5:04 am Post subject: XM Antenna through Fiberglass? |
I had mine under the VS fairing and it didn't work well at all.
XM should and does work under fiberglass but as you experienced the signal
is degraded.
Also try and not splice the antenna wire. Its hard since the connector is
larger but I replaced my XM
antenna with one that was not spliced and placed it on my windshield. The
reception is perfect.
Not only is the tiny wire hard to work into a connector, but the shielding
must be kept in place.
Steve
RV7A
Flying
-Mike Kraus
RV-4 flying
RV-10 building
dane(at)mutualace.com Guest
Posted: Wed Sep 06, 2006 6:57 am Post subject: XM Antenna through Fiberglass? |
Mike
Do you have metal flake paint on the fiberglass? Dick Martin informed me it did affect his antennas in his wing tips. I assume it would do the same in receiving the XM signal
Dane Sheahen
N838RV RV8a
Subject: XM Antenna through Fiberglass?
-Mike Kraus
RV-4 flying
RV-10 building
[quote] [b]
