Float Flyr
Posted: Mon Sep 04, 2006 12:41 pm Post subject: Type of Aircraft |
No listing for floats???
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
kirkhull(at)sbcglobal.net Guest
Posted: Mon Sep 04, 2006 12:59 pm Post subject: Type of Aircraft |
What kind of fuel burn # ( GPH ) do you get?
lcfitt(at)sbcglobal.net Guest
Posted: Mon Sep 04, 2006 2:25 pm Post subject: Type of Aircraft |
Lynn, I have you . Until Michel posted, you were the one and only. Now you
are one of two.
Lowell
Posted: Mon Sep 04, 2006 2:26 pm Post subject: Type of Aircraft |
This is getting interesting, I have one on wheels going to floats and I
have you as TW but mostly on floats. Do you prefer floats on the listing?
I think I'll add another catagory.
Lowell
Got it
Lowell
do not archie
Kcozik(at)cablespeed.com Guest
Posted: Mon Sep 04, 2006 3:16 pm Post subject: Type of Aircraft |
I'll add mine as well:
Kitfox S6
rotax 914 turbo
Czech 1650 amphibs
Kevin Cozik
Ben-PA
Posted: Mon Sep 04, 2006 3:46 pm Post subject: Type of Aircraft |
Lowell,
I put my plane on Michel's list, not in the email.
Model 5
Subaru EJ-22
Conventional gear.
_________________ Sign up on the Kitfox Frappr Map:
http://www.frappr.com/kitfox
You can see where fellow Kitfoxers live and pictures of their planes. Be sure to post some pictures of you, your plane, or share the scenery of the Kitfox world. |
janderson412(at)hotmail.c Guest
Posted: Mon Sep 04, 2006 3:55 pm Post subject: Type of Aircraft |
ZK-RJA, Series 5 EA81 Intercooled Turbo EFI. Not NSI
Subject: Re: Re: Type of Aircraft
Date: Mon, 4 Sep 2006 10:29:08 -0700
Did a quick count of those that posted onto the list. Results are as
follows, given present status. I will try to keep this up if the list is
interested. I may have missed some. If you think you are not listed try
again, I have the list by name on a spreadsheet.
Lowell
TD--34
NW--5
582----------11
912UL--------9
912ULX------2
912ULS------7
912A---------1
NSI-----------3
NSI-T--------1
STR-SUB----1
EA81-RAM--1
J2200--------1
L-0-235------2
C-0200-------1
KFM---------1
Lowell
Need more speed? Get Xtra Broadband (at)
http://jetstream.xtra.co.nz/chm/0,,202853-1000,00.html
Posted: Mon Sep 04, 2006 3:58 pm Post subject: Type of Aircraft |
Shivers, how about a shot of it Guy!!
Date: Mon, 04 Sep 2006 12:47:27 -0700
At 10:29 AM 9/4/2006, you wrote:
| Quote: | If you think you are not listed try
Lowell,
You must have missed me. K-IV 1200 with Walter M601E gas turbine.
It really goes, but unfortunately only for about 20 minutes. Then I have to
refuel.
Guy Buchanan
Read the latest Hollywood gossip (at) http://xtramsn.co.nz/entertainment
Don Cravener
Posted: Mon Sep 04, 2006 4:44 pm Post subject: Type of Aircraft |
Kitfox Classic IV
Jabiru 3300
115 hrs.
Owner / Builder: Don Cravener
experimental208nd(at)comc Guest
Posted: Mon Sep 04, 2006 5:03 pm Post subject: Type of Aircraft |
HI Lowell,
KF 4-1200 912UL
Tail Dragger
Jay Fabian
Float Flyr
Posted: Mon Sep 04, 2006 6:08 pm Post subject: Type of Aircraft |
The only thing I've done on the tail wheel is taxi... The guy who was
supposed to get me started on the tail wheel was busy that day. Two
winters I've taken the floats off and still don't have one minute on wheels
or skis... I guess I'm going to have to be satisfied with float flying. I
think I can suffer that!!
BTW my float flying was some what curtailed this summer by a SNAFU at
Transport Canada. I should have my float endorsement finished this week.
Now all I'll have to do is wait for TC to issue the endorsement.
Noel
P.S. Definitely put me down for floats...Aerocet composite 1100 straight.
[quote] --
Kitfox III-A
davestapa(at)juno.com Guest
Posted: Mon Sep 04, 2006 6:18 pm Post subject: Type of Aircraft |
David Estapa
Woodstock, GA
Series 5 912ULS
Tail wheel
Ceashman(at)aol.com Guest
Posted: Mon Sep 04, 2006 6:48 pm Post subject: Type of Aircraft |
. Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
--Did a quick count of those that posted onto the list. Results are as
--follows, given present status. I will try to keep this up if the list is
--interested. I may have missed some. If you think you are not listed try
--again, I have the list by name on a spreadsheet.
Hi Lowell.
Please add my details:
Eric Ashman
Atlanta area GA.
Classic IV (N893)
912 UL (3 blade Warp Drive)
T wheel.
Working on a Skybolt
Thanks. Eric.
Posted: Mon Sep 04, 2006 8:15 pm Post subject: Type of Aircraft |
Thanks Kevin.
Posted: Mon Sep 04, 2006 8:20 pm Post subject: Type of Aircraft |
Thanks, Ben.
Posted: Mon Sep 04, 2006 8:38 pm Post subject: Type of Aircraft |
Thanks Don.
Posted: Mon Sep 04, 2006 8:42 pm Post subject: Type of Aircraft |
Thanks, Jay.
Posted: Mon Sep 04, 2006 8:45 pm Post subject: Type of Aircraft |
Thanks, Noel. Floats it is.
Lowell
Posted: Mon Sep 04, 2006 8:47 pm Post subject: Type of Aircraft |
Thanks, David
Loewll
