jdmurr(at)juno.com Guest
Posted: Sun Jan 22, 2006 1:58 pm Post subject: 1989 Firestar Aileron Linkage Update? |
I had my Firestar out today for about 2 hours (around freezing here in the Northeast brrr). Anyway it was a little bumpy and it always seems like I don't have enough aileron throw especially to the left since the stick hits my leg. Even if I stomp on the rudder really hard it doesn't handle the way I would like it to.
I also don't like the idea of single standoff on the cage that the aileron bell crank bolts onto. Looks like a failure point to me. I could modify the linkage to get more throw, but then it would put more pressure on this bolt because of the increased leverage.
I thought I heard somewhere that there was an update to the control linkages on the older Firestars. It would be nice to have more control authority with less input. Differential would be nice too!
Has anyone dealt with these two issues? My plane flies really well, but I would like more roll rate especially in rougher air and close to the ground where I'm flying less than one mistake high. Thanks.
John Murr
1989 Firestar.
I had my Firestar out today for about 2 hours(around freezing here in the Northeast brrr). Anyway it was a little bumpy and it always seems like I don't have enough aileron throw especially to the left since the stick hits my leg. Even if I stomp on the rudder really hard it doesn't handle the way I would like it to.
I thought I heard somewhere that there was an update to the control linkages on the older Firestars.It would be nice to have more control authority with less input. Differential would be nice too!
John Murr
1989 Firestar.
Kolbdriver(at)bellsouth.n Guest
Posted: Sun Jan 22, 2006 5:30 pm Post subject: 1989 Firestar Aileron Linkage Update? |
John,
Is the gap between the ailerons and the wing sealed??
Steven
rswiderski(at)earthlink.n Guest
Posted: Sun Jan 22, 2006 5:31 pm Post subject: 1989 Firestar Aileron Linkage Update? |
John, I don't know about the updates, but I haven't seen a Kolb that did not
have differential ailerons. Maybe I haven't seen enough of them?
Richard Swiderski
Posted: Sun Jan 22, 2006 6:08 pm Post subject: 1989 Firestar Aileron Linkage Update? |
About 80% of it. There is as small piece missing.
-- "Steven Green" <Kolbdriver(at)bellsouth.net> wrote:
John,
Steven
ElleryWeld(at)aol.com Guest
Posted: Sun Jan 22, 2006 6:26 pm Post subject: 1989 Firestar Aileron Linkage Update? |
John Murr
You can do what I did to my aleron controll linkeage there are pictures of
the new linkeage I built in the Photo share
I swaped the controll horns on my ailerons and built the linkeage under my
boom tube
Ellery
