darinh
Posted: Wed Sep 06, 2006 12:07 pm Post subject: LED Nav lights?? |
I am looking at putting LED Navs in on my Series 7 to reduce the amp draw from the alternator. Has anyone used these or know anything about them? I had Whelen strobes and navs on my Model III (912UL) and with the com, transponder, GPS, EIS, stobes, and navs, the 18 amp alternator could not keep up. I would like to install the same instrumentation on my 7 and add landing/taxi lights but unless I can decrease the amp draw from a couple of these, it doesn't look like a viable option. Anyone know of a company that is making the LED navs?...If so, what do you guys (and possibly gals) recommend?
Darin Hawkes
cjswa(at)comcast.net Guest
Posted: Wed Sep 06, 2006 3:05 pm Post subject: LED Nav lights?? |
Darin,
I bought a set of LED position lights / strobes to reduce the current draw
but haven't tried them yet so can't say how they perform. I bought them
from Wicks, but I'm not sure if they still carry them. They were made by GS
Air, whose website is www.gs-air.com
Bill Anderson
Model 4-1050 (still under construction)
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Wed Sep 06, 2006 3:28 pm Post subject: LED Nav lights?? |
Sure do. I bought the Kuntzleman strobe/LED position light combo heads. Amp
draw from the LEDs is less than 1A, and the strobes are about 3A. Very nice
units, and pricey. But I figure it's cheaper than the mid-air.
The wingtip heads have two LEDs (red/green) in front, the strobe in the
middle, and a single white LED in the back. The third unit has the strobe
and two white LEDs aft. All under very nice polycarbonate teardrop lenses,
with tubing adapters for the tail. Bases are machined from aluminum, and
have a rubber o-ring to seal from water.
I mounted the third on top of the vertical stab, and of course the two on
the wingtips. Very bright, and double strobe flashes, about 140 per minute.
The box weighs about 10oz, maybe 12oz, and is mounted to the tubing aft of
the baggage bag using Adel clamps. Two switches, and +12V and ground, ready
to go. I'm thinking of adding an LED flasher, mostly for the Gucci effect,
and it's really cheap.
With these, and wig-wag landing lights, if you're not seen by anyone below
FL200, they're not looking.
I highly recommend these units.
http://www.kestrobes.com/
Bradley
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
darinh
Posted: Wed Sep 06, 2006 5:10 pm Post subject: Re: LED Nav lights?? |
Thanks guys...Great leads! I like the Kuntzleman set-up from the looks of it.
darinh
Posted: Wed Sep 06, 2006 5:12 pm Post subject: Re: LED Nav lights?? |
Bradley,
Sent you a PM with some questions on your setup...
Darin
kitfox(at)itsys3.com Guest
Posted: Wed Sep 06, 2006 5:47 pm Post subject: LED Nav lights?? |
I decided to build my own LED bulbs and use the Whelen fittings.
A description is here
http://www.itsys3.com/kitfox/discover.shtml about half way down
the page.
darinh wrote:
Darin Hawkes
http://forums.matronics.com/viewtopic.php?p=60023#60023
Float Flyr
Posted: Wed Sep 06, 2006 7:56 pm Post subject: LED Nav lights?? |
Most LEDs have a voltage drop of just under 2V and a current drain of a few
milliamps this means a string of 6-7 LEDs wired in series will have a
voltage drop of about 12V. The LEDS aren't expensive so you can experiment
a bit with them and build your own nav lights. You can even make them
dimmable. According to what I see as traffic lights are replaced with LEDs
they are a lot brighter than the conventional filament bulbs. For ease of
application there are red LED replacements made for automobiles that plug
into the standard sockets.... I haven't seen any blue/green replacements
yet. The nice thing is you won't need the expensive hard to find lenses any
more.
I would recommend that you have an ammeter installed in your plane as a load
meter so that when you turn on your landing/taxi lights you will see how
much of the nav gear etc. to turn off to prevent over loading the battery.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Thu Sep 07, 2006 4:27 am Post subject: LED Nav lights?? |
Check with John McBean...I bought a set from him, and they work just
fine. I don't recall the amp draw, but it is WAY low, These are combo
strobes and Nav lights...separate switches of course.
Lynn
On Wednesday, September 6, 2006, at 04:07 PM, darinh wrote:
Darin Hawkes
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
n10pg(at)neo.rr.com Guest
Posted: Thu Sep 07, 2006 11:46 am Post subject: LED Nav lights?? |
Hello Darin:
I saw a display at last Oshkosh of a wingtip LED Position/strobe setup and
promptly purchased a set. They arrived a few days later and I installed
them, replacing my Whelen A600-PG-PR. They look better and the LEDs are
infinitely brighter. I love 'em.
They are called Skybright Nightlight Strobe/LED System made by Rollison
Airplane Co. (Rob Rollison), Bloomfield IN 47424 (812-384-4972),
www.airplanegear.com
If you talk to Rob Rollison please be sure to say hello for me.
Sincerely,
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
fultz(at)trip.net Guest
Posted: Mon Sep 11, 2006 11:54 am Post subject: LED Nav lights?? |
I saw somewhere, a year or so ago, someone was offering direct replacement
bulbs in an LED array. They were not cheap, but someone was manufacturing
them. Anybody else seen them? I've lost the link to their site and don't
remember the name of the manufacturer.
Andy F.
Posted: Mon Sep 11, 2006 12:23 pm Post subject: LED Nav lights?? |
Hello Andy:
www.airplanegear.com If you talk to Rob Rollison please be sure to say hello
for me.
Sincerely,
Peter Graichen
Posted: Mon Sep 11, 2006 1:05 pm Post subject: LED Nav lights?? |
Thanks Peter. I knew of the complete assembly replacements that you are
refering to, but what I was talking about was just the bulb replacements for
the WHELEN or AEROFLASH assemblies. Somewhere I saw them and can't remember
now where. I had the link saved on my other computer before it crashed and
I lost all that info.
Andy F.
