pilotdds(at)aol.com Guest
Posted: Wed Sep 06, 2006 6:09 am Post subject: Converting fixed pitch to constant speed |
Could any of you folks knowledgable about the conversion advise me if external oil lines are necesary when making this conversion.My understanding is that the outside plug must be removed a 1/8 plug must be placed inside the crankshaft and external oil lines are necesary for rear mounte governors but not front mounted type. Is this correct? 728dd-flying
coop85(at)bellsouth.net Guest
Posted: Wed Sep 06, 2006 4:20 pm Post subject: Converting fixed pitch to constant speed |
I can’t help with the 1/8 plug, but you will need to remove the outside plug and there are no oil lines on a front mounted governor.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com
Sent: Wednesday, September 06, 2006 10:09 AM
Subject: Converting fixed pitch to constant speed
01234567890123
Posted: Thu Sep 07, 2006 7:44 am Post subject: Converting fixed pitch to constant speed |
thanks for the info
