wrong photo.
occom
PostPosted: Wed Sep 06, 2006 2:49 pm    Post subject: wrong photo. Reply with quote
Here is a close up of the insert end on.
 Filesize:  33.7 KB
 Viewed:  302 Time(s)
Guy Buchanan
PostPosted: Wed Sep 06, 2006 5:01 pm    Post subject: wrong photo. Reply with quote
Are the inserts still good? The one you show appears OK. Couldn't you re-use them? (The old holes don't matter.)
Guy Buchanan
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
smokey_bear_40220(at)yaho
PostPosted: Wed Sep 06, 2006 8:37 pm    Post subject: wrong photo. Reply with quote
I am surpised to see that the new inserts do not have
the "V" relief cut in each end. This "V" cut is to
reduce the sharp change in stiffness at the insert
ends, which creates stress points on the spar.
Anyone else have the inserts without the relief "Vs"?
It is new to me.
Kurt S.
Guy Buchanan
PostPosted: Thu Sep 07, 2006 2:23 am    Post subject: wrong photo. Reply with quote
I believe you cut those in yourself. You definitely want them.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
occom
PostPosted: Thu Sep 07, 2006 3:25 am    Post subject: wrong photo. Reply with quote
<smokey_bear_40220(at)yahoo.com>
It is new to me.
They just came out of the crate, I'll get to that.
occom
PostPosted: Thu Sep 07, 2006 3:29 am    Post subject: wrong photo. Reply with quote
The old insert for one side is still good, but Kitfox recommended they not be reused. There is some scratching from being pushed out. With the thicker walls I don't think the old inserts will fit the new spars anyway.
PostPosted: Sat Sep 09, 2006 6:12 pm    Post subject: wrong photo. Reply with quote
A senior moment on my part. They were already done on
my quick built wings, but I now remember the
instructions for them.
Kurt S.
have
want them.
Guy Buchanan
to Bob Ducar.
