		jaybrinkmeyer(at)yahoo.co Guest
				 Posted: Fri Sep 08, 2006 1:26 pm    Post subject: 113" fuse longeron angle - mark it "don't cut" |
				Several of the fuse longeron diagrams have two dimensions shown along the same
 face within a single figure. That is, one diagram is used to show two different
 pieces each with different dimensions. I doubt if my engineering graphics
 professor would have given this scheme a passing mark.
 Measure twice, think longer and cut once? Nah.
 I cut the smaller pieces first without looking around the shop long enough. If
 you do like me you might wind up needing a 113" longeron that is now in two
 pieces (dooh!). Shipping a $15 part with dimensions over 8' from Oregon is
 several hundred dollars as it has to go by freight.
 Luckily I found a local source that supplies the equivalent part.  If there's
 anyone in the Colorado area in the same boat let me know as I now have extra
 AA6-125 3/4 x 3/4.
 Jay
		dlm46007(at)cox.net Guest
				 Posted: Fri Sep 08, 2006 2:32 pm    Post subject: 113" fuse longeron angle - mark it "don't cut" |
				Any raw materials can usually be purchased locally, especially if near a big
 city. Industrial Metals (aka Capital Metals) in Tempe AZ (Phoenix area) can
 supply aluminum in a variety of sizes and grades i.e. 2024,6061,7075. Also
 McMaster Carr will ship raw materials as needed.
		bsponcil(at)belinblank.or Guest
				 Posted: Fri Sep 08, 2006 8:00 pm    Post subject: 113" fuse longeron angle - mark it "don't cut" |
				Yeah, I'm in a similar boat with a tailcone J-Channel. Like a doofus (sp?) I
 cut one of the 93"ers too short and had to order a new one from Vans.
 Naturally it shows up the Friday before a long labor day weekend bent at
 about 35 degrees.  I called vans the following week and they sent another
 one which arrived today so badly bent the driver didn't even bother to wait
 until I opened it.  Looking at the tube he just said, "Oh man, I'd better
 send this back."
 Turns out that even PVC pipe is not enough to protect parts from the
 shipping people, who apparently spend a good deal of time smashing things
 with hammers.
 Now I'm headed off to Reno (Dago Red is running this year!) and am wondering
 what the chances are that I'll find a decent 8' length of J-channel waiting
 on my porch when I get back.
 Anyway, let that be a lesson to the guys/girls just starting. Cut the long
 pieces first!!
 -Brian
 #40497
 N211BD
 Iowa City, IA
 On 9/8/06 4:25 PM, "Jay Brinkmeyer" <jaybrinkmeyer(at)yahoo.com> wrote:
  different
  AA6-125 3/4 x 3/4.
  Jay
		deruiteraircraftservices( Guest
				 Posted: Sat Sep 09, 2006 1:14 am    Post subject: 113" fuse longeron angle - mark it "don't cut" |
				I wonder why Van's put that particular warning in the
 paperwork................
		rv10(at)sinkrate.com Guest
				 Posted: Sat Sep 09, 2006 1:55 pm    Post subject: 113" fuse longeron angle - mark it "don't cut" |
				I did something similar as well with the tailcone J-Channel but x 6.  I
 trimmed all 12 to length properly with no problems but didn't look that
 carefully at the plans to "Trim the ends at a 45 deg angle as shown in
 figure 2".  After I finished cutting the angle on the last of 12 I looked at
 the one in my hand and said... "Huh?  That doesn't look right!"
 Sure enough I cut the 45 not from the vertical edge but the horizontal so
 all of them came to a point at the corner.  When I squared off the now
 messed up edges the 6 long ones were now too short.
 The messed up 93"ers became the 6 shorter ones.  All the others became wall
 art.  I robbed the wing kit, which I just picked up the day before, of the 6
 8' J-Channel in it.  Key word is "PICKED UP".  Van's is a 20 minute drive
 from my place.  Still soaked me for $13.75 x 6 = $82.50 but no down time or
 expensive freight snafu's.
 So the lesson learned is of course read the plans more carefully before
 cutting anything (or move closer to Van's).
 -Ben
 #40579
 Tailcone
 (Darn there are a lot of rivets! Should be done this weekend)
		rwhunter(at)integra.net Guest
				 Posted: Sat Sep 09, 2006 2:18 pm    Post subject: 113" fuse longeron angle - mark it "don't cut" |
				What page of the plans is the cutting of these pieces on so I can b
				 Posted: Sat Sep 09, 2006 2:19 pm    Post subject: 113" fuse longeron angle - mark it "don't cut" |
				What page of the plans are the cutting of the J-Channels on so I don't
 make the same mistake.
 Rob Hunter
 Elevator 40432
		Albert Gardner
				 Posted: Sun Sep 10, 2006 1:30 pm    Post subject: 113" fuse longeron angle - mark it "don't cut" |
				You can splice J-channel with no problem. Butt 2 pieces together and overlap
 a splice strip about 5 rivet on each side. Treat it as a repair and use the
 FAA Acceptable Methods book.
 Albert Gardner
 Yuma, AZ
  _________________ RV-9A N872RV
RV-10 N991RV |
