		pacificpainting(at)comcas Guest
				 Posted: Wed Sep 13, 2006 5:00 pm    Post subject: 801 Builders (I know you're out there) |
				I have the opportunity to buy an 0320 Lycoming with  governor and prop. Anyone know of an 801 that is flying with this combination. I  am planning on an 0360 with a fixed pitch prop, but thought I'd see if there  were any information on this engine and prop combo that has actually been  installed and flown on an 801.
  Dave in Salem
  801
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Jay Herron
				 Posted: Thu Sep 14, 2006 4:31 am    Post subject: Re: 801 Builders (I know you're out there) |
				Dave,
 Jim Frisby has a O320 in his 801, but I don't think he has the constant speed prop.  Search the archives for Frisby in case he misses this post.
 I have a O360 in my 801.  It came with a governor and constant speed prop but I sold the prop and bought a wood one from Props Inc.  The wood prop is about 15 pounds in weight.  The constant speed was around 50 pounds.  Other builders suggested that the 801 is slightly nose-heavy to begin with, so I went with wood.  I was also having a hard time finding room for the governor.
 I still have about a month of work to do on my 801 before it is ready to fly.
 Jay Herron
 Salem, Ohio
				 Posted: Thu Sep 14, 2006 5:12 am    Post subject: 801 Builders (I know you're out there) |
				Jay,
 Thanks for the reply. I'm about 99% sure that I'll go with the 0360 because
 of weight, among other things. I am building my plane without to many
 frills. I don't want to ad to the complexity of addtional systems and costs
 on things I probably won't use anyway. The engine prop combination is more a
 curiosity than anything else. I also found out the engine that I had
 referred to has been pickled for about 9 years. I think I will probably use
 an XP360. Haven't thought to much about a prop yet. What are you using?
 Dave in Salem (Oregon)
 801
		zodierocket(at)hsfx.ca Guest
				 Posted: Thu Sep 14, 2006 2:50 pm    Post subject: 801 Builders (I know you're out there) |
				I'm in the same boat, the 801 were building is about a month away and
 has an 0-360 with a metal prop from Zenith's FWF kit. The constant speed
 application only increases cruise by about 3 knts and is not worth the
 5G's or more in cost. But one thing I can truly say is that this is one
 huge plane to build. It is only about 15% bigger then the 701 but wow it
 is incredible how much more of the hanger it fills.
 Cdngoose
		Jay Herron
				 Posted: Thu Sep 14, 2006 4:06 pm    Post subject: Re: 801 Builders (I know you're out there) |
				Dave,
 The prop that I have mounted on my 0360 is a 72x46 made from hard maple with fiberglass tips and leading edge protection.  Cost was $995 from Props Inc.
 Jay Herron
 Salem, Ohio
 CH801 95% complete
		n801bh(at)netzero.com Guest
				 Posted: Fri Sep 15, 2006 5:10 am    Post subject: 801 Builders (I know you're out there) |
				My initial gut feeling is you are underpropped by a large amount. If nothing else you need a larger diameter to send the prop blast across the tail feathers to make them work at lower airspeeds. 46" pitch will let you accelerate great on the take off roll but top speed will suffer. of course when I say top speed and Zenith 801 in the same sentence is pretty funny.  <G>Let us know how it works out...
 Ben Haas
 N801BH
 www.haaspowerair.com
 -- "Jay Herron" <jay(at)agstore.net> wrote:
 --> Zenith-List message posted by: "Jay Herron" <jay(at)agstore.net>
 Dave,
 Jay Herron
 Salem, Ohio
 CH801 95% complete
 http://forums.matronics.com/viewtopic.php?p=61696#61696
		Jay Herron
				 Posted: Fri Sep 15, 2006 8:34 am    Post subject: Re: 801 Builders (I know you're out there) |
				Ben,
 You are probably right about being underpropped for top speed.  But as you know if I was looking for top cruise speed, I wouldn't be building an 801.  My intention is for fast acceleration on take off and leisurely flying.  If this prop doesn't work out, I'll swap in another.  I'll post the results after I do the test phase.
 Jay Herron
 801
		lllanducci(at)tds.net Guest
				 Posted: Tue Sep 19, 2006 7:15 am    Post subject: 801 Builders (I know you're out there) |
				I don't think that substituting construction foam board for the
 closed-cell insulation/soundproofing foam would be a very good idea
 because:
 1. It is certainly not FAA  approved  and would be a real problem in
 the rare case of a fire. The closed-cell foam meets or exceeds certain
 FAR standards for fire retardancy.
 2. Construction foam is very light and rigid. I think that the
 flexibility and relatively high density of the closed-cell foam is the
 main reason for its effectiveness.
 3. The closed-cell foam is very easy to apply with random dabs of
 contact cement even on curved surfaces. You want to be able to remove
 it to gain access to fuel lines, electrical
      wires, etc.
 4. Another big plus of the closed-cell foam is that it is very easily
 cut with a pair of scissors, and also,since it is flexible it can be
 pushed into crevices and areas which would be
      very difficult to access with a rigid and brittle foam board.
 Larry Landucci -- N801LL
				 Posted: Tue Sep 19, 2006 8:02 am    Post subject: 801 Builders (I know you're out there) |
				THANKS,
 SOUNDS REASONABLE TO ME.
