RichWill
Joined: 24 Feb 2006 Posts: 24 Location: Southern Maine
Posted: Thu Sep 14, 2006 4:49 pm Post subject: Annual on Kitfox III |
Anyone know of an A/P who will sign off or do the annual on a kitfox M3 in the S Maine /S New Hampshire area? Both of my hopefuls have renigned and changed their minds.. Due in Nov 06
thanks
Rich
spaghettiohead(at)hotmail Guest
RichWill
Posted: Thu Sep 14, 2006 5:25 pm Post subject: Re: Annual on Kitfox III |
How does that work? He can do and/or sign off..yes? I am 2nd owner and it's been 14years since the plane was built.. I have address and name.. but frankly.. Think the guy might have even passed away..
Posted: Thu Sep 14, 2006 8:42 pm Post subject: Annual on Kitfox III |
Hmm...that's a tough call then! The builder, since he is the "manufacturer"
can sign off an annual - It might be worth checking out...and heck, if he is
alive, then he might get a kick out of seeing the plane he built!
Andrew
KF3
msm_9949(at)yahoo.com Guest
Posted: Fri Sep 15, 2006 7:16 am Post subject: Annual on Kitfox III |
I think Andrew's right that builder can sign off on annual "condition inspection" . . . but only if builder applied for and received FAA "repairman's certificate" for the airplane.
Andrew Matthaey <spaghettiohead(at)hotmail.com> wrote:
[quote]--> Kitfox-List message posted by: "Andrew Matthaey"
Andrew
KF3
[quote]From: "RichWill"
Subject: Re: Annual on Kitfox III
Date: Thu, 14 Sep 2006 18:25:06 [quote][b]
RichWill
Posted: Fri Sep 15, 2006 11:46 am Post subject: Re: Annual on Kitfox III |
Thanks guys... appreciate it..
Andrew, do you have your CFI and can do TW signoffs? Still have the plane at B19
Rich
Posted: Fri Sep 15, 2006 11:52 am Post subject: Annual on Kitfox III |
Marco - I could be wrong - but a "Repairman's Certificate" is only for LSA,
no? Rich's 'Fox is an Experimental-AB, therefore, the builder does not need
any additional cert's.
Andrew
KF3
| Quote: | From: Marco Menezes <msm_9949(at)yahoo.com>
Subject: RE: Re: Annual on Kitfox III
Date: Fri, 15 Sep 2006 08:15:43 -0700 (PDT)
is
Andrew
KF3
>From: "RichWill"
>Date: Thu, 14 Sep 2006 18:25:06 -0700
but
>Semper Fi
>15 ITT
>G2 HqCo HqBn
>1st MarDiv
>Read this topic online here:
>http://forums.matronics.com/viewtopic.php?p=61710#61710
Marco Menezes
Model 2 582 N99KX
Posted: Fri Sep 15, 2006 12:10 pm Post subject: Annual on Kitfox III |
Hey Rich - I sent out an email a few days ago after I passed my last
checkride...Finished up my CFI/CFII/MEI last week, so yep, I can Instruct
and sign-off in a Tailwheel now.
Biddeford, eh? I'm flying up home this weekend for a couple of days - If
you'd like to go flying, give me a holler - I've got a lot of business to
take care of, finishing up my move to Jax and all, but maybe we can squeeze
something in. My cellphone again is 646.354.3252.
Andrew
KF3
Get real-time traffic reports with Windows Live Local Search
http://local.live.com/default.aspx?v &cp=42.336065~-109.392273&style=r&lvl=4&scene=3712634&trfc=1
lcfitt(at)sbcglobal.net Guest
Posted: Fri Sep 15, 2006 2:41 pm Post subject: Annual on Kitfox III |
The Repairman Certificate is issued to a builder after completing a short
application at the time the DAR or FSDO representative issues the
Airworthiness Certificate. It allows the holder to do the Annual Condition
Inspection on the aircraft he built. If the aircraft is sold, he as well as
an A&P are authorized to do the Annual Conditon Inspection.
Lowell
john(at)leptron.com Guest
Posted: Fri Sep 15, 2006 2:42 pm Post subject: Annual on Kitfox III |
Andrew,
A repairman's Cert. Is required on an experimental, IF you did build it you
only have to request and apply for it after the 40 hours. Otherwise you are
in violation..
John Oakley
ddsyverson(at)comcast.net Guest
Posted: Fri Sep 15, 2006 2:45 pm Post subject: Annual on Kitfox III |
OK Guys,
This is the way it is. - In the US anyway.
A repairman's certificate can be applied for by the builder of the airplane,
and it is has nothing to do with LSA. You build it, you can apply for and get
a repairman's certificate.
Experimental; whether it is light sport or not, if you built it you can get
the RC.
The repairman's certificate entitles the holder to do the annual condition
inspection and sign off on it.
The repairman's certificate only applies to the aircraft the person built - it
cannot be used for doing a condition inspection on any other aircraft.
If you didn't build it - you can't get the repairman's certificate for that
aircraft; nor can you do the annual condition inspection; unless you are an A
& P.
Sincerely,
Dave S
On Friday 15 September 2006 2:52 pm, Andrew Matthaey wrote:
Andrew
KF3
> "manufacturer" can sign off an annual - It might be worth checking
>Andrew
>KF3
> >From: "RichWill"
>but
> >Semper Fi
> >15 ITT
> >G2 HqCo HqBn
> >1st MarDiv
>_________________________________________________________________
>Marco Menezes
>Model 2 582 N99KX
kirkhull(at)sbcglobal.net Guest
Posted: Fri Sep 15, 2006 7:27 pm Post subject: Annual on Kitfox III |
Another note. Any A&P can do the inspection. They DO NOT have to have an IA
which is required to do an annual insp on a certified aircraft.
Lynn Matteson
Posted: Sat Sep 16, 2006 3:31 am Post subject: Annual on Kitfox III |
John-
I questioned this "after the 40 hours" on this group...was told not
true...called the FAA...they said come on over and get it, and I
did...during the 40.
Lynn
On Friday, September 15, 2006, at 06:44 PM, John Oakley wrote:
Andrew,
it you
you are
in violation..
John Oakley
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dosmythe(at)cox.net Guest
Posted: Sat Sep 16, 2006 10:17 am Post subject: Annual on Kitfox III |
I applied for mine at the same time I got the inspection.
Don Smythe
RichWill
Posted: Tue Oct 03, 2006 2:04 pm Post subject: Re: Annual on Kitfox III |
Andrew,
I didn't get your post until today... Just got back from 3 weeks in Thailand and Malaysia...work!
I will call on cell, but now suspect you are back in JAK...
Rich
dcsfoto
Posted: Wed Oct 04, 2006 9:01 am Post subject: Re: Annual on Kitfox III |
talk to the EAA and your FAA office.
you can go to a class and get a repairmans certificate to do the inspection on a light sport airplane. The MIII con be operated as a light sport.
you might be able to change the certificate to experimental light sport
