speed range for flaps
rpf(at)wi.rr.com
PostPosted: Sat Sep 16, 2006 1:14 pm    Post subject: speed range for flaps Reply with quote
This question is for people that have built, or are building, 601xl's. I was looking at Zenith's website for the speed range for operating the flaps, but could not find it. Does anyone know what the speed range is for the flaps?
Thanks for your help,
Randy Ferri
601xl Jab. 3300
jetboy
PostPosted: Sat Sep 16, 2006 1:55 pm    Post subject: Re: speed range for flaps Reply with quote
Please add CH701 rev-4 flaps speed range to the question. When the 701 was changed to 1100lbs revision the max flap setting was changed to 16 deg.
I have been unable to find a revised flight manual or documentation covering this change
Ralph
CH701 / 2200a
Ralph - CH701 / 2200a
Tim Juhl
PostPosted: Sat Sep 16, 2006 4:21 pm    Post subject: Re: speed range for flaps Reply with quote
I don't have them in front of me but as I recall the speeds are listed on one of the first few pages of the plans you would have got from Zenith.
TJ
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
bryanmmartin
PostPosted: Sat Sep 16, 2006 5:11 pm    Post subject: speed range for flaps Reply with quote
Randy Ferri
601xl  Jab. 3300
I recieved this file in reply to an email I sent to ZAC, It lists a Vf of 80 mph:
Nick Heintz
Zenith Aircraft Company
support(at)zenithair.com (support(at)zenithair.com)
http://www.zenithair.com
Technical Support Disclaimer:  While we strive to ensure that the
advice/information provided through our support is correct, Zenith
Aircraft Company does not accept any responsibility for errors or
omissions. Any advice or information that Zenith Aircraft Company
gives you via any form of communication is not a guarantee that it
will correct your problem. It is only offered as assistance to you.
Zenith Aircraft Company will not be held responsible for any loss or
damage as a result of our advice or information supplied.
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any other MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
   ---- File information -----------
     File:  speed limitations.JPG
     Date:  10 Jun 2004, 12:45
     Type:  JPEG-image
[img]cid:D666B67C-EDD3-461F-80E4-F55C69F7085C(at)local[/img]
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
 Filesize:  154.46 KB
 Viewed:  372 Time(s)
Bryan Martin
do not archive.
pmaxpmax(at)HOTMAIL.COM
PostPosted: Sat Sep 16, 2006 11:56 pm    Post subject: speed range for flaps Reply with quote
I have mine placarded (white arc) to use flaps below 80 mph indicated. I regularly deploy them at that speed, and have never had a problem.
Phil Maxson
601XL/Corvair
Northwest New Jersey
Subject: Zenith-List: speed range for flaps
Use Messenger to talk to your IM friends, even those on Yahoo! Talk now! [quote][b]
