		Arksey(at)aol.com Guest
				 Posted: Sat Sep 16, 2006 6:32 pm    Post subject: firestar ll elevator question...(jim swan) |
				Hello Gang,
     Intended to make the Kolb flyin but had a couple of teeth pulled and they  want me back Frid the 22nd, I tried to get them to change the date  but no luck, they are trying to get my dental work done before I leave for  Florida the last of Oct.   Darn  it..  Have a question that I was  going to ask at the flyin, so here it is. On our Firestar ll when I pull the  stick back it moves the left stabilizer  some on the bolts that fastens it to the  boom, the right stabilizer  moves  some , but not as much, when the stick is moved back just the opposite happens.    Is this normal?  It flys ok and I do not consider it a  danger. I suspicion that it may have to move because of the folding design.
    By  the way I am doing a lot of flying in the firestar and really enjoying it….and I  must admit I am improving, but do not intend to bragg. Thanks to all in advance  for your input. Have some more questions that I will post when you guys get back  from the fly in. thanks again for your input.
     Jim Swan
 Firestar ll   michigan
				 Posted: Sat Sep 16, 2006 6:47 pm    Post subject: firestar ll elevator question...(jim swan) |
 right
 back just the
 opposite happens.  Is this normal?   Jim Swan
 Jim S:
 Sorry you are not going to be able to make the Kolb Homecoming.
 Your elevator situation is normal, when the piano hinge pins are not
 centered exactly on the elevator control mechanism on each side of the
 tail boom.  Will not hurt anything, but make sure the forward tang is
 not being pushed or pulled into the bracket and placing a bending
 moment on it.
 I have one side that does not move, and the other side moves about an
 1/8".  Hasn't hurt the running none.............
  _________________ John Hauck
Titus, Alabama |
				 Posted: Sat Sep 16, 2006 8:10 pm    Post subject: firestar ll elevator question...(jim swan) |
				thanks john,
     makes me feel better about it....yep hate to miss  the Kolb homecomming....but will catch you all at sun and fun if not  before.
  jim swan   firestar ll  michigan
