rexjan(at)bigpond.com Guest
Posted: Sun Sep 17, 2006 4:18 pm Post subject: Grove gear |
i am thinking of
upgrading to grove gear and would like any opinions on doing so.
Ron,
I have Grove gear and love it. On the other hand I have no experience with tube gear. However in my opinion Grove gear seems a bit more robust and has a wider track. Logically this means it will not groundloop quite as easilly.
Rex.
lcfitt(at)sbcglobal.net Guest
Posted: Sun Sep 17, 2006 5:22 pm Post subject: Grove gear |
I too have the aluminum spring gear. All great except the one negative, it
will add about 15 lbs to the empty wt of the airplane. I have friends that
are more concerned with short field performance and every pound is a real
negative for them.
Lowell
dave(at)cfisher.com Guest
Posted: Mon Sep 18, 2006 3:37 am Post subject: Grove gear |
I have never flown a grove gear airplane .
I have flown many bungee aircaft including Kitfox and Avid Flyers.
I don't know where all the fear comes from with regards to ground looping, unstable tube gear etc as the kitfox is a pretty tame aircraft in flight and take off and landing.
I think the pilot can be blamed for most of this fear.
Trigear pilots are esentially lazy footed creatures and do have troubles adapting to flying a taildraggger at times but it is like walking. You were given to feet but if you don;t move them you will not walk. In a taildragger if you don't use them then you cannot steer.
Next time you out flying your fox go practice X wind landings 10 to 15 knot (at) 90 degrees if you can find a suitable spot and preferably a grass strip. If you cannot handle that then you should look up that Andrew CFI that posted here and get some help.
Sorry to sound harsh guys but your Kitfox will fly in same conditions as a c 152 or 172 and I don't see them grounded often.
as far as weight of grove gear ........ It just extra weight to carry around.
I do not know which gear is more rugged but the tube style gear load is carried over over 2 attact points about a foot or more apart and the grove gear is attached in a smaller spot so I would only guess that the load exerted is greater on the attach points of the bottom of fuselage.
Dave
mike Guest
Posted: Mon Sep 18, 2006 5:59 am Post subject: Re: Grove gear |
why is it that when something is harder, it's the way to go??? I have flown both the bungy gear and the grove gear and I will say the grove is much safer and easier to land. My self, I prefer the safer. I have the grove and that's that. When you have a landing that is hard(you know those last couple feet and you just drop for no reason), the grove is going to hold up, when you come in and get a dust devil that throws you around, the grove will help(wider stance). Oh and lets not forget, you don't have to put those bungies on every year either, or after a hard one.
mike Guest
Posted: Mon Sep 18, 2006 6:02 am Post subject: Re: Grove gear |
Oh one last thing, 15lbs. My answer to that is drink more water and eat less Twinkies.
Posted: Mon Sep 18, 2006 7:36 am Post subject: Grove gear |
Mike ,
Are you saying it is less safe to fly a Kitfox without a Grove gear ?
I think a poll should be done on that topic alone. Have you had a bad
experience with a tube gear ?
Sorry I cannot see how a proficient pillot could make a statement like that.
Dave
occom
Posted: Mon Sep 18, 2006 9:03 am Post subject: Grove gear |
| Quote: | why is it that when something is harder, it's the way to go??? I have
flown >both the bungy gear and the grove gear and I will say the grove is
much >safer and easier to land. My self, I prefer the safer. I have the
grove and >that's that.
But Mike- following that logic it would be easier to have only tricycle
gear. It seems a lot of people have the original gear and find it perfectly
adequate. The tone of your post seems to imply they are just plain wrong.
janderson412(at)hotmail.c Guest
Posted: Mon Sep 18, 2006 1:29 pm Post subject: Grove gear |
Ask seasoned Spitfire / Mustang pilots. The former type is a pig on the
ground to the latter as he's used to the wider Mustang track. But the
Spitfire pilot knows no diff...until he tries the Mustang..
Subject: Re: Re: Grove gear
Date: Mon, 18 Sep 2006 11:35:21 -0400
Mike ,
Dave
dan(at)azshowersolutions. Guest
Posted: Mon Sep 18, 2006 4:23 pm Post subject: Grove gear |
Well said John....:>)
Dan, Mesa
314DW - IV- 912s- Groves spring gear
John Anderson <janderson412(at)hotmail.com> wrote:
[quote]--> Kitfox-List message posted by: "John Anderson"
To:
--> Kitfox-List message posted by: "Dave"
Mike ,
Dave
jleathem(at)cogeco.ca Guest
Posted: Mon Sep 18, 2006 5:47 pm Post subject: Grove gear |
Ron, my advice is to do it. We switched to Grove gear a couple of years ago and it was the best investment we have made in the aircraft. Much easier to handle on the ground, x-wind landings are much easier and the gear does not bounce as much as the bungies. I’ve done landings that may have collapsed the original gear but the Grove gear just absorbed the impacts and kept the aircraft straight and manageable on the runway. It’s like flying in a different aircraft.
J. Trevor Leathem
Ontario, Canada
szakreski(at)shaw.ca Guest
Posted: Tue Sep 26, 2006 3:11 pm Post subject: Grove gear |
War Birds revival....my generation missed out, but go to any big warbirds
show now and see the line up..
Subject: RE: Re: Grove gear
Date: Tue, 26 Sep 2006 05:42:46 -0600
"Ask seasoned Spitfire / Mustang pilots...."
Boy, there must be lots of those around.
SteveZ.
