HS-1008L/R Brackets
wv4i(at)bellsouth.net
PostPosted: Mon Sep 18, 2006 1:49 am    Post subject: HS-1008L/R Brackets Reply with quote
Take care to note that dimensions on these angled aluminum parts go from
1.5" on the long side end to 1.5" at angle to 1 21/32" at short side
end. Also, note that the flare is only on one side of short angle side,
not both. Not a big deal if caught early. Note that Air Parts has more
AA6-187-3x3, as well as Van's, hi.....
Link McGarity
#40622
Thanks to Deems Davis' site for great pics of these parts (images 1,4,5):
http://www.deemsrv10.com/album/CNC%20Parts/index.html
Rick S.
PostPosted: Mon Sep 18, 2006 5:52 am    Post subject: HS-1008L/R Brackets Reply with quote
Read the plans, measure twice, cut outside the finished called out dimensions and file to the finished dimensions followed by proper deburring and polishing. Consider fabricating these parts as the EDUCATIONAL part of building your aircraft. If you screw up don't make the same mistake twice Wink
Given that, the trim tab brackets suck and short of brazing up the provided ones I would opt for the nicely machined ones unless I had a mill handy.
Do you think buying these parts will lower your build below the %51 percent mark? They are somewhat time consuming but when you do finish them they sure are a small rewarding part of the construction process.
Rick S.
40185
Rick S.
RV-10
40185
johngoodman
PostPosted: Tue Sep 19, 2006 6:37 am    Post subject: Re: HS-1008L/R Brackets Reply with quote
Link McGarity
#40622
Luckily, Van's provides enough AA6... to make one more (g).
John
