xPanel feedback
larry(at)ncproto.com
PostPosted: Tue Sep 19, 2006 3:57 pm    Post subject: xPanel feedback Reply with quote
Is there any more feedback on xPanel ?? Is this a viable product to design an instrument panel in ??
Larry E. James
Bellevue, WA
Super Decathlon
HR2 - under construction - fuselage
 Filesize:  145 Bytes
 Viewed:  2222 Time(s)
LarryRosen
PostPosted: Wed Sep 20, 2006 4:45 am    Post subject: xPanel feedback Reply with quote
I have been using xPanel and I like it. In my opinion it is much better
than the online versions since you can easily add instruments that it
does not have in the data base. Also you get side and top views. It is
a good product for laying out panel design concepts. However, there is
no measuring tool or easy way to move instruments into an exact
location. You would need to use some other tool to actually cut the panel.
They do have a free web based product.
You can try XPanel 5000 in trial mode to see if you like it.
XPanel software is here <http://www.xpanelsoftware.com/Index.htm>
Larry Rosen
RV-10 #356
N205EN (reserved)
Larry E. James
Bellevue, WA
Super Decathlon
Larry Rosen
#40356
N205EN (reserved)
<http>
