Oxygen Tank Explosion, Hydrotesting
Mike Bell
PostPosted: Tue Sep 19, 2006 7:42 pm    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
Ben mentioned the oxygen tank explosion at Reno. I was shooting video of his team's gorgeous Grumman Tigercat when I heard the big boom. The picture below shows what that does to a Mustang.
Jill and Carl at M-14P can now do your hydrotesting. The turnaround is fast and they won't ruin your tanks using the wrong fittings.
 Filesize:  69.04 KB
 Viewed:  608 Time(s)
Mike Bell
Elk Grove, CA
avbell2(at)comcastdotnet
viperdoc(at)mindspring.co
PostPosted: Wed Sep 20, 2006 5:48 am    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
Ouch, so there is a reason for reading the TO's when servicing these
military aircraft.
Doc
[Original Message]
To: <yak-list(at)matronics.com>
Date: 9/19/2006 10:53:29 PM
Subject: Oxygen Tank Explosion, Hydrotesting
Mike Bell
Yak 52
Elk Grove, CA
yakflyr(at)comcastdotnet
http://forums.matronics.com/viewtopic.php?p=62673#62673
http://forums.matronics.com//files/reno_2006_008_e_314.jpg
Mike Bell
PostPosted: Wed Sep 20, 2006 1:43 pm    Post subject: Re: Oxygen Tank Explosion, Hydrotesting Reply with quote
I heard third-hand that it was a case of improper filling, not necessarily a problem with the tank. There has been much discussion here in the past about where to get hydrotesting and the lack of shops familiar with our tanks. That is no longer a problem.
Mike Bell
Elk Grove, CA
PostPosted: Wed Sep 20, 2006 1:56 pm    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
As I understood, it was over pressurized by using the wrong scale to the
tune of 1800 psi, if I heard correctly. Strictly rumor and inuindo at this
point.
Doc
[Original Message]
Date: 9/20/2006 3:35:05 PM
Subject: Re: Oxygen Tank Explosion, Hydrotesting
Does anyone know why it exploded? Or are we just assuming that it’s
lack of hydro?
Tanks have still failed after a hydro.
Don’t own a Yak unless you can afford to be married to a maintenance
schedule!
http://forums.matronics.com/viewtopic.php?p=62831#62831
PostPosted: Wed Sep 20, 2006 1:59 pm    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
One of my YAK-9 buds was about 50 feet from it when it let go at Reno. It
was filling it to the wrong pressure that did the tank and the ass end of
the Mustang in. Luckly, no bystanders.
Doc
[Original Message]
Date: 9/20/2006 4:52:32 PM
Mike Bell
Yak 52
Elk Grove, CA
http://forums.matronics.com/viewtopic.php?p=62853#62853
pilko2(at)btinternet.com
PostPosted: Thu Sep 21, 2006 12:01 am    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
Yak air tanks can be lethal too !
This one let go on the ground during warm up.
Keep em tested !
kp
 Filesize:  564.5 KB
 Viewed:  539 Time(s)
ira.saligman(at)verizon.n
PostPosted: Thu Sep 21, 2006 11:07 am    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
The tank exploded because it was over pressurized. It was an original type tank, which is low pressure and rarely used today.
The important questions are:
from the aircraft owners point of view: WHo allowed it to be filed w/out checking/confirming what was going in
from the maintainer's view: How did someone come to be filling a tank without know for certain the type of tank it was.
Ira Saligman
RPA Treasurer
o 610 687 0420
c 610 324 5500
f 215 243 7699
treasurer(at)flyredstar.org (treasurer(at)flyredstar.org)
isaligman(at)saligman.com (isaligman(at)saligman.com)
Scooter
PostPosted: Thu Sep 21, 2006 12:36 pm    Post subject: Re: Oxygen Tank Explosion, Hydrotesting Reply with quote
I assume that's pilot O2 (what else can it be)? Seems like a large supply. I guess these guys are flying up high. I did a little searching and found two other O2 cylinder explosions in P-51 mustangs over the years (one last year and one in '72).
ben(at)designselect.net
PostPosted: Thu Sep 21, 2006 2:39 pm    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
It happened in Tom Dwelle's Sea Fury as well. Pressure indicator rated for
3000 psi, bottle rated for 1000 psi. When it blew it took Dwelle's fingers
and sent the bottle through the airplane and into the top of the hanger.
Ouch!
rvfltd(at)televar.com
PostPosted: Thu Sep 21, 2006 3:31 pm    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
This is a good point, you should be checking your gauges as well as your
tanks.
New CJ replacement tanks used to be very hard to find but I have managed to
source them out of China once again, but testing is still the lowest cost
way to be sure, this being said make sure you ask the right questions of the
firm doing the testing. I found one outfit who simply was cleaning and
inspecting the interior of the tanks and did no pressure testing because
they indicated that they did not have the fittings to do so, but were still
willing to say the tank was ok for use. "let the buyer beware"
Always Yakin,
Doug Sapp
PostPosted: Thu Sep 21, 2006 5:30 pm    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
Hence my first statement on the this thread, Ouch...those Tech Orders really do mean something!
Doc
L39parts(at)hotmail.com
PostPosted: Thu Sep 21, 2006 6:44 pm    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
Are we to understand that North American didn't didn't know about relief valves or rupture disks when they designed the Mustang?
N13472(at)aol.com
PostPosted: Thu Sep 21, 2006 7:39 pm    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
In a message dated 9/21/2006 7:45:20 P.M. Pacific Daylight Time, L39parts(at)hotmail.com writes:
[quote] Are we to understand that North American didn't didn't know about relief valves or rupture disks when they designed the Mustang?
PostPosted: Fri Sep 22, 2006 8:25 am    Post subject: Oxygen Tank Explosion, Hydrotesting Reply with quote
Absolutely true. Just checked with my CAF buds at the Dixie wing. Home of the Red Nose P-51. A couple of the original 51 drivers verified that these were low pressure O2 tanks so that those 20 mm rounds and Flak did not bring them down with one pass.
Doc
Ernie
PostPosted: Sat Sep 30, 2006 8:57 am    Post subject: Re: Oxygen Tank Explosion, Hydrotesting Reply with quote
I was having a discussion about this topic yesterday, and was informed that it is a DOT requirement for ANY pressure vessel, regardless of its application has to be hydro inspected by law. Is this correct?? Also how can I get a hold of Carl and Jill Hayes? I want to have the bottles in the CJ and the L-29 checked.
Ernie
Mike Bell
PostPosted: Sat Sep 30, 2006 4:38 pm    Post subject: Re: Oxygen Tank Explosion, Hydrotesting Reply with quote
Ernie,
Carl and Jill are at (928) 681-4400 in Arizona.
Mike Bell
Elk Grove, CA
