jesse(at)itecusa.org Guest
Posted: Thu Sep 21, 2006 2:21 pm Post subject: trim brackets |
OK, I am getting close to lust on that one (almost there, John, but not
quite). I could have used those about 2 weeks ago. Man, getting those
cover plates on there with the HS already mounted in place is more than a
bear.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
jdalton77(at)comcast.net Guest
Posted: Thu Sep 21, 2006 2:49 pm Post subject: trim brackets |
cool! is there some reason they have to be removed for painting?
gommone7(at)bellsouth.net Guest
Posted: Thu Sep 21, 2006 3:18 pm Post subject: trim brackets |
Yes if you whant to paint beetwen the Hs and the elevator,you cannot remove the elevator without removing the trim tabs attachments brackets.
hugo40456
Date: 2006/09/21 Thu PM 06:48:27 EDT
Subject: Re: trim brackets
wvu(at)ameritel.net Guest
Posted: Thu Sep 21, 2006 9:57 pm Post subject: trim brackets |
You can remove the cover plate without removing the rivets. You have to
loosen the nuts at the servo end of the cable, trim the servo full nose down
(trim tab up), push the sleeve of the cable aft allowing the cover plate to
move away from the bottom of the elevator, bend the cable down and carefully
turn the cover plate until it falls off of the sleeve. The new design does
seem to reduce the pain of doing it this way.
Anh
deutscht(at)rhwhotels.com Guest
Posted: Fri Sep 22, 2006 4:19 am Post subject: trim brackets |
Can someone give me contact information for the milled trim brackets?
Tom Deutsch, #405
Office 913 451-1222
Fax 913 451-6493
Cell 913 908-7752
zackrv8
Posted: Fri Sep 22, 2006 4:36 am Post subject: Re: trim brackets |
| deutscht(at)rhwhotels.com wrote: | Can someone give me contact information for the milled trim brackets?
Tom Deutsch, #405
Office 913 451-1222
Fax 913 451-6493
Cell 913 908-7752
Tom,
Contact Dave at 302-437-6087 or visit his website at http://www.rivethead-aero.com/
Zack
_________________ RV8 #80125
RV10 # 40512 |
