		zackrv8
				 Posted: Fri Sep 22, 2006 2:15 pm    Post subject: Motor Mount |
				Guys,
   Anybody else have this problem?
  I pinned the motor mount onto the firewall today.  With the top 2 motor mount holes up flush against the firewall, the bottom 2 outboard holes are about a 3/16 of an inch from the firewall.  This is because the 2 bottom inboard mounting holes of the motor mount won't allow the 2 outboard mounts to sit flush.
   What did you guys do about it?  Send it back? Make shims?  Just pulled it tight with the bolts?  Reweld it?
   I'm inclined to make shims.  I don't want undue stress on the mount by pulling it tight with the bolts.
 Zack
  _________________ RV8 #80125
RV10 # 40512 |
		rene(at)felker.com Guest
				 Posted: Fri Sep 22, 2006 2:30 pm    Post subject: Motor Mount |
				I do not remember having that problem.  If I remember right mine all sat
 pretty flat.
 Rene' Felker
 40322
 Finish
 N423CF
		acs(at)acspropeller.com.a Guest
				 Posted: Fri Sep 22, 2006 2:41 pm    Post subject: Motor Mount |
				Zack, my concerns were more to do with the alignment of the outer holes
 being up to half a hole out, but found when I began to pull the bolts up it
 easily stretched and moved into place, well below any torque value required
 on the nuts. You'll find some information in the archives reporting the fact
 that there seems to be a bit of twist in some frames.
 John 40315
 [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of zackrv8
 Sent: Saturday, 23 September 2006 8:15 AM
 Subject: Motor Mount
 Guys,
 to sit flush.
 Zack
 RV8 #80125
 RV10 # 40512
 http://forums.matronics.com/viewtopic.php?p=63295#63295
		dlm46007(at)cox.net Guest
				 Posted: Sun Sep 24, 2006 12:54 pm    Post subject: Motor Mount |
				Just drilled up the motor mount this morning; another possible gotcha is the
 top two pilot holes on the QB (#8 Mar/2005) fuselage were about .050
 different in distances from the outboard edge. When we drilled the right top
 pilot hole the left top was almost out of the mount hole. After pinning the
 other four holes with rivet sets which fit the 3/16" on one end 3/8" on the
 other and 3/16" bolts we were able to flex the mount on the top left hole to
 use as a drill bushing for an off center drilling of the pilot hole. Also
 its best to test fit the motor mount (section 47) before riveting the front
 deck (section 41) as the access for cleaning and deburring the mount holes
 inside is much easier.
