		nick(at)aoaircrafters.com Guest
				 Posted: Mon Sep 25, 2006 7:34 am    Post subject: Continental 0-200 A Engine Questions |
				I have a Zodiac 601 HD with a Continental 0-200 A engine.  The engine
 installation is about 25% complete.
 Two questions:
 --Do you have problems with oil cooling?  If so, what provisions are
 made for oil cooling?
 --Do you have problems with aircraft weight and balance (i.e. the
 Continental 0-200 engine's weight as opposed to other possible models).
  If so what is generally done to correct the wieght and balance problem?
 Thanks guys,
 ~Nick
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		agbeyer(at)sbcglobal.net Guest
				 Posted: Mon Sep 25, 2006 8:42 am    Post subject: Continental 0-200 A Engine Questions |
				Nick,
   A friend of mine just finished an HD with a Corvair engine.  He has a light battery (about 15 Lbs.) located behind the seats.  With it in that location the forward CG limit was too far forward.  We moved it as far back in the fuselage as we could.  A small hinged door in the bottom of the fuselage was installed. With the extra length of battery cables and mounting Brk's. for the battery we gained 5 Lbs.  The CG limits now come out perfect.  This lowered the weight on the nose wheel by 40 #s.
   Al
 nick(at)aoaircrafters.com wrote:
   [quote]--> Zenith-List message posted by: nick(at)aoaircrafters.com
 Two questions:
 --Do you [quote][b]
		Grant.Schemmel(at)Aerofle Guest
				 Posted: Tue Sep 26, 2006 4:58 am    Post subject: Continental 0-200 A Engine Questions |
				I have an HDS with an O-200 in it, and have maybe 150 hrs. on it now.
 To answer your questions,:
 1) Yes, I had significant cooling problems initially.  I solved mine by putting in an oil cooler with a sandwich plate adapter between the spin-on filter and it's mount (see archives).
 2) I can't say that I had problems with w&b, as I compensated for the weight by putting both of my batteries (2 x 13Ahr) right at about the location of the wing steps.  My w&b then came out perfect.  I get at the batteries through an access hatch on the pilots side of the fuselage.
 Grant Schemmel
 Penrose, CO
 Time: 08:34:48 AM PST US
 Subject: Continental 0-200 A Engine Questions
 Two questions:
 Thanks guys,
 ~Nick
		stephen(at)crichards.flye Guest
				 Posted: Wed Sep 27, 2006 2:27 am    Post subject: Continental 0-200 A Engine Questions |
				Hi Nick Ray Lasniers  601 HD has a 0-200
                          We have had no problem with oil cooling . Fitted
 with original sump screen filter only no extra cooling we are however in the
 UK so ambient  may be lower than you have. We have had a Hot summer for us
 this year and have flown in 85 f with no problem .
 We have had no problem with the weight & Balance the empty weight is 720 lbs
 & arm 9.137 inches  (232.075 mm) the battery is in extreem rear & we have a
 wooden (Lodge) pop due to weight this puts the plane on the forward limit
 with a 140 lb pilot & full 16 US gallon header tank, no luggage. Our
 inspector pointed out that the Zenith W & B sheet gives the wrong arm for
 the baggage compartment (they give the measurment to the front of the
 shelf ) it should be around 69.5 inch
                            Ray built is own engine baffling by copying and
 triming to fit the baffels on a super cub which was down for a engine
 rebuild.
 The engine mount was built from a drawing from Zenith for the 601XL as
 firewall mountings and offsets are the same.
           His engine has the old heavy generator & starter fitted with these
 accessorys fitted the engine complete weighs about 250 lbs. He has the 16
 gallon header tank fitted so the 12 lbs Dry Fit battery is in the extreem
 rear.  You could probably shorten the mounting if you fit a light weight
 starter & Alternator.              The exhaust down pipes were from a C150
 The  Port side mounted 7 ft Throttle Idle cut off and Carb Ice controls as
 fitted to a C150 were from Aircraft Spruce
    He made his own cowling by making a plug mold ( ie cover engine with
 cling film cover this with expanding foam shape & lay up)
  Clive Richards for Ray Lasnier G CBDG 30 Hrs
 I will be changing my email address shortley due to the ammount of spam I
 cannot stop.
 I can find no way of deleating this or messages with pictures  attached  on
 the server prior to downloading if I have to use dial up.
				 Posted: Wed Sep 27, 2006 6:10 am    Post subject: Continental 0-200 A Engine Questions |
				Clive,
 Thanks, that was very informative.  I may just have to sit down and do
 the math- as per weight and balance.  I do not have a header tank, only
 wing tanks.  This should help counteract the nose forward moment.  I
 would rather mount my battery on the front of the firewall (around 15
 lbs), as this is a little less time consuming than mounting the battery
 in the tail.
 As for the engine baffling, after many phone calls to AMD (Aircraft
 Manufacturing and Development), I finally convinced them to ship me a
 baffling kit for the 0-200.  I wish I had a picture of the front engine
 baffling, as I have to modify what they sent me because I do not have an
 engine driven fuel pump (mounted front right on the engine).  Any
 pictures would be appreciated.
 Thanks much
 ~nick
 [quote] ------
