		lwinger
				 Posted: Tue Sep 26, 2006 7:20 am    Post subject: Corrosion Protection Answers |
				In my quest for answers to the age-old question about internal corrosion protection, I contacted the folks at PTI (http://www.aircraftspruce.com/menus/cs/pti.html) for answers.  As it turns out, my conversations ended with the President, Steven Andrews, actually coming by my office to pick up some scrap 6061-T6, a few actual rudder parts, and a Scotch-Brite pad (7447).  After decades of serving the defense and commercial markets, PTI is waking up to the general aviation and homebuilt market.  When I mentioned some of my questions (which some on this list seem to share), he was anxious to provide answers.
 He took the parts and they applied their zinc chromate and non-zinc chromate primers to perform adhesion tests.  These were parts which had normal marks that you get from working aluminum into compound shapes.  Half of the parts were scuffed with Scotch-Brite and the rest were not.  All parts were solvent cleaned with isopropyl alcohol (talk about inexpensive and easy).
 The bottom line is that the tests showed high levels of adhesion, regardless of whether scuffing was done or not.  I have pictures available on request.  The use of a single, inexpensive solvent was partly in my response to questions about using Alumiprep 33 and Alodine.  Their contention is that such time-intensive preparation is not required.
 My final question to him was this:  “Is adhesion all that matters?”  I asked because I know many builders are using the NAPA Self-Etching Primer or similar products and claim that is adheres very well.  Here is his response.
 “Well, adhesion is not the only issue.  Obviously though, the primer has to adhere to protect.  I do not know who manufactures the product that NAPA sells so I do not know how it is formulated.  If it is a generic zinc chromate primer (which I suspect it is) then there is no telling what the quality of the resin system is, how it will hold up to chemical exposure, changes in climate, exposure to humidity, high heat or extreme cold.  Whether it has the flexibility to expand and contract with the metal given altitude changes and the other unique environmental challenges unique to aviation as compared to the automotive environment I cannot say.  But I can say that our product is specifically formulated for aircraft -- actually military aircraft.  It is made with the highest quality resins available and conforms to the strictest standards as set out in the Military Specification to which it is formulated.  So once it adheres -- it will perform.”
 My reason for contacting PTI was that I liked what I read on the Aircraft Spruce website about their products and client list.  They make the landing gear coatings for all major airlines, and their products are used in the interior and cargo holds of the Space Shuttle Challenger.  Their customers since 1947 have a lot higher standards to meet than the project I’m buiding in my garage.
 If nothing else, they have saved me lots of time and money in what appears to be unnecessary prep for priming.  From now on, I’m using isopropyl alcohol until the rag comes off clean, then I’m priming with an aviation-specific product.  My purpose in sending this message is to pass along information in case anyone on the list has been wrestling with similar issues.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
		p.mulwitz(at)worldnet.att Guest
				 Posted: Tue Sep 26, 2006 8:28 am    Post subject: Corrosion Protection Answers |
				Hi Larry,
 Thanks for the great information.
 I wish to add one thought on the fancy priming
 issue.  You might want to use different
 techniques for internal paint vs. external finish
 paint.  The simple approach is probably overkill
 for internal use, but certainly good enough.  For
 the external finish, I would go the complete
 route of alumiprep, alodine, primer, and top
 coat.  The difference is that the external finish
 is subject to heavy sunlight exposure along with
 nasty weather and related stuff.
 Paul
 XL fuselage
 At 08:20 AM 9/26/2006, you wrote:
 the folks at PTI
 Larry Winger
 Tustin, CA
 601XL #6493 from scratch
 Stabilizer skeleton ready to rivet
		lwinger
				 Posted: Tue Sep 26, 2006 9:07 am    Post subject: Corrosion Protection Answers |
				My questions of PTI were about internal corrosion protection only.  I know they have completely different answer when priming for external painting.  Thanks for highlighting that difference.
  On 9/26/06, Paul Mulwitz <p.mulwitz(at)worldnet.att.net (p.mulwitz(at)worldnet.att.net)> wrote: [quote]--> Zenith-List message posted by: Paul Mulwitz p.mulwitz(at)worldnet.att.net  (p.mulwitz(at)worldnet.att.net)
 paint.  [b]
Tustin, CA
