		leinad
  Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
				 Posted: Tue Sep 26, 2006 3:08 pm    Post subject: Odd materials sources |
				Before I go to Zenith, I thought I'd ask here.  Where do you get the following.
 Nyloil
 cork stips
 dzus strips (do I make these?)
 .090 acrylic (for landing light cover)
 Dan (central Virginia)
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Scratch building XL with Corvair Engine |
		grs-pms(at)comcast.net Guest
				 Posted: Tue Sep 26, 2006 3:56 pm    Post subject: Odd materials sources |
				Dan:
 I bought cork in a sheet from a local craft store and cut it into strips as
 needed.  Good luck on the other stuff.
 George
		bryanmmartin
				 Posted: Tue Sep 26, 2006 3:58 pm    Post subject: Odd materials sources |
				I got the acrylic for one of my landing light covers from Home Depot.
 They gave me a scrap piece of Lexan that I used to make the other
 light cover. I got a roll of cork sheet from Ace Hardware when I ran
 out of the cork strip sent with the kit. I attached it with double
 sided carpet tape. (I also got some red silicone rubber sheet gasket
 material  from Ace that I used on the main landing gear mounting
 instead of the split rubber hose provided by Zenith.)
 Aircraft Spruce and Wicks Aircraft (and probably others) have nylon
 material as well as acrylic and Lexan but unless you are buying a
 bunch of stuff, the shipping may be nearly as much as the order.
 Dzus strips? If you mean the springs for the dzus fasteners, these
 are also available from the usual online sources.
 On Sep 26, 2006, at 7:08 PM, leinad wrote:
  the following.
  Nyloil
  cork stips
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
		leinad
				 Posted: Tue Sep 26, 2006 6:07 pm    Post subject: Re: Odd materials sources |
				[quDzus strips? If you mean the springs for the dzus fasteners, these
 are also available from the usual online sources.ote][/quote]
 On the plans for the optional wing locker they specify dzus strips.  I assume these are metal strips with reqularly spaced dzus spring fasteners, but the plans are no more specific.  They may intend that I make these.
 I especially want to find a source for the nyloil.  This is oil empregnated nylon, specified for the nose gear bearings top and bottom.
				 Posted: Tue Sep 26, 2006 8:48 pm    Post subject: Odd materials sources |
				 	  | Quote: | 	 		  [
 On my plans, the Dzus springs are mounted on standard (.025?)
 aluminum strips.  The builder has to fit the strips to the wing
 locker opening in the skin and locate the springs in the right places
 to match the Dzus "Screws" in the locker cover.  I used tiny soft
 solid rivets to hole the springs in place -- in much the same fashion
 as nut plates.   I don't have the dimensions handy, but if you need
 them, I can get them out in my shop (where my plans are).
 It is a little tricky to make holes in the strips match the holes in
 the locker cover, but the process I used was similar to the Match
 drilling and Line drilling used for rivets.
 Paul
 XL fuselage
  	  | Quote: | 	 		  quDzus strips? If you mean the springs for the dzus fasteners, these
 are also available from the usual online sources.ote] |
[/quote]
