Navman F2100 Fuel Guage
f.miles.tcp.833(at)clearw
PostPosted: Tue Sep 26, 2006 11:59 am    Post subject: Navman F2100 Fuel Guage Reply with quote
Has anyone in this group used the Navman fuel gauge with the Rotax two cycle and if so, what has been your experience?
Frank
msm_9949(at)yahoo.com
PostPosted: Tue Sep 26, 2006 1:40 pm    Post subject: Navman F2100 Fuel Guage Reply with quote
Hi Frank.
I installed the NavMan 2100 (marine version) on my Model 2 with 582 gray head. It seems to work great. I empty my tanks after each flight and the amount I drain out appears to coincide closely with the NavMan's remaining fuel calculation. I'll do something a bit more empirical to verify appearances before relying on it, but so far I'm pleased and impressed. Also, the price from Boaters Land is unbeatable. I'd recommend it.
See http://www.boatersland.com/index.html
Marco Menezes
Frank Miles <f.miles.tcp.833(at)clearwire.net> wrote:
[quote] Has anyone in this group used the Navman fuel gauge with the Rotax two cycle and if so, what has been your experience?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Get your own [url= http://us.rd.yahoo.com/evt=43290/*http://smallbusiness.yahoo.com/domains]web address for just $1.99/1st yr[/url]. We'll help.
dave
PostPosted: Tue Sep 26, 2006 4:11 pm    Post subject: Navman F2100 Fuel Guage Reply with quote
Frank, I have a navman 2100 and I had over a year now . No problems at all. I checked on my fuel use on it tonight while flying and since July 07 ( the last time that i reset the totals)
I have used 920 litres of fuel. This is on a 582 and on flights of 3 hours+ it seems to be accurate on fuel burn.
Higly recommended. I di a search on google http://www.google.com/search?num=100&hl=en&newwindow=1&safe=off&rls=GGLG,GGLG:2005-48,GGLG:en&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=navman+2100&spell=1
And I think i got mine at boatersland. It was 119$ i recall and rec;d the next day via courier in Canada.
Only thing I did not like was the nipples on transducer are 3/8" and I use 1/4 " line . It is hooked in right below the fuel pump on firewall after the gascolator and covered in gas sleeves.
I used a fitting on each end to change 1/4 to 3.8 and visa versa.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
algate(at)attglobal.net
PostPosted: Wed Sep 27, 2006 5:32 am    Post subject: Navman F2100 Fuel Guage Reply with quote
I’ve used one with a 582 for 3 years and now have one on my Jabiru. Probably one of the most useful gauges in my airplane.
Gary Algate
Classic 4 / Jab2200
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Frank Miles
Sent: Tuesday, September 26, 2006 3:59 PM
Subject: Navman F2100 Fuel Guage
Frank
Lynn Matteson
PostPosted: Wed Sep 27, 2006 7:13 am    Post subject: Navman F2100 Fuel Guage Reply with quote
Hi Gary-
Can you explain a little about how the F2100 Fuel Flow Indicator works?
By that I mean, what senses the flow, an impeller? Where do you insert
the sensing device?
I'm a little concerned about the specs on this unit....only good down
to 32 F? And one other spec...90-300 hp? That puts our 85-horse Jabs a
little below their range...have you found this to be a problem?
Lynn
Gary Algate
Classic 4 / Jab2200
Lynn
Kitfox IV-Jabiru 2200
N369LM
dave
PostPosted: Wed Sep 27, 2006 8:59 am    Post subject: Navman F2100 Fuel Guage Reply with quote
Lynn,
I have one too and have operated as low as - 25C ( -15F) with NO
troubles.
It works by impeller and I think that temp range is most likely for the LED
display.
It say min flow rate 5 litres per hour and mine read below that but you know
alot like to brag how they only burn 4 litres an hour but in reality we all
know that a range of 5 t o 130 litres perhour will cover most all Kitfoxes.
Dave
PostPosted: Wed Sep 27, 2006 10:08 am    Post subject: Navman F2100 Fuel Guage Reply with quote
Hi Lynn
The flow is sensed by a small turbine that has an inlet and outlet nipple.
You just put this into the fuel supply line after the filter and before the
fuel pump.
A signal cable then runs back to the gauge which just requires a 12V supply
and ground hook up.
As the fuel flows the turbine spins and the flow is monitored and displayed
on the LED display.
I had over 300 Hrs or 4,500 ltrs through my last gauge without any problem
and consistently better than 98% accuracy. As soon as I purchased my new
Kitfox I fitted a Navman and I have about 450 Ltrs through this one. I
drained the fuel last weekend and checked the volume against the gauge and
it was within 1/2 Ltr.
You have to make sure that you remember to update the gauge everytime you
add or remove fuel as it doesn't read anything from the fuel tanks. I also
fitted the Murle Williams low fuel warning light just to have a direct
contact with the actual fuel supply. I located both in a small consol that I
built for fuel management. See attached Foto.
You can see the low fuel light in the bottom right corner of the lexan cover
Hope this helps
Gary
Hi Gary-
the sensing device?
Lynn
Gary Algate
Classic 4 / Jab2200
 Filesize:  68.98 KB
 Viewed:  423 Time(s)
Lynn Matteson
PostPosted: Wed Sep 27, 2006 2:29 pm    Post subject: Navman F2100 Fuel Guage Reply with quote
Thanks Dave and Gary...I think that answers all my questions.
Lynn
On Wednesday, September 27, 2006, at 12:59 PM, Dave wrote:
Lynn,
troubles.
the LED display.
you know alot like to brag how they only burn 4 litres an hour but in
reality we all know that a range of 5 t o 130 litres perhour will
Dave
Lynn
N369LM
