wcm(at)tampabay.rr.com Guest
Posted: Tue Jan 24, 2006 7:52 am Post subject: Vortex Generators |
How many of you that installed VG's on your planes also added them to the
under side of the horizontal stabilizer?
What are the advantages / disadvantages of adding them to the HS.
I ordered some from Landshorter yesterday but for the wing only, now I'm
wondering if the "wing only" is adequate.
Chris Mallory
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Tue Jan 24, 2006 8:17 am Post subject: Re: Vortex Generators |
wcm(at)tampabay.rr.com wrote: | How many of you that installed VG's on your planes also added them to the
Chris Mallory
do not archive |
Chris, there was some discussion about this earlier... There seems to be some concern that the horiz. stab. VGs might make the elevators too effective... I have them on my Firestar tail, but I have nothing to compare to...
DVD
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
JetPilot
Posted: Tue Jan 24, 2006 9:01 am Post subject: Re: VORTEX GENERATORS |
They may not be needed on the horizontal stab. If the wing is stalling before the elevator, there is really nothing to be gained by putting VG's on the elevator. There is a drag penalty associated with VG's, its not a lot, but I would not put VG's on that dont need to be there.
Michael A. Bigelow
Kolb MK-III Xtra, 912-S |
Richard Pike
Posted: Tue Jan 24, 2006 9:11 am Post subject: Vortex Generators |
At the Kolb Fly-In shortly before his terrible accident, Norm flew my
MKIII with VG's for a while, solo, stalled it, wore it out, which is
what I wanted, and his postflight analysis was a lot like this:
It feels much lighter, more like a Firefly than a MKIII. The stall is
notably slower, and very acceptable, but it feels almost like it might
be approaching a "deep stall" condition when stalled power off and full
flaps. However he was unable to get it into a stall condition which did
not immediately recover when stick back pressure was relaxed. He told me
it was one of the best handling MKIII's he had flown. When queried about
adding VG's to the underside of the horizontal stab, and/or gap sealing
the horizontal stab to the elevators, he was very hesitant. He was
concerned that it might be possible to force the airplane into a deep
stall with possible adverse recovery techniques. He also said that
perhaps that was a groundless concern, because getting a MKIII to fly
that in that slow of a speed regime was pretty much an unknown, and it
might stall and recover just fine. His suggestion was that since it was
already stalling slower and flying better than it had any right to, just
leave it alone and don't screw it up by trying anything else, just fly
the approach a bit faster when I had a passenger.
So that's what I did. The only time I have felt the need for VG's on the
underside of the horizontal tail is when flying an approach with a
passenger at 45 mph (indicated) and full flaps. At that speed, the tail
does not have enough control authority to raise the nose for flare,
although it is still 13 mph above the (indicated) 28 mph stall speed at
gross weight, which is probably around 33 mph TAS. So when I have a
passenger, approaches are at 55 indicated, or partial flaps.
However, others on the list have added VG's to the underside of the
horizontal stab and like them quite well. So make sure your parachute is
good to go, gets lots of altitude, and experiment. You might be able to
gild the lily. But remember: when in ground effect on short final, your
results may vary.
Richard Pike
MKIII N420P (420ldPoops)
Chris Mallory
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Tue Jan 24, 2006 10:06 am Post subject: Vortex Generators |
Chris Mallory
Chris,
I mounted VG's on the FireFly wings. Then I added VG's to the horizontal
stabilizers to get a little more bite when using the flaperons. Previously,
I had discovered that I could not flare the FireFly with full flaperons.
Also, I noticed after adding wing VG's, that the wing wanted to fly off in
the three point stance before there was any feel in the stick. Adding VG's
to the horizontal stabilizer helped.
I have not stalled the FireFly at altitude in it's current configuration.
It is on my short list of things to do.
Jack B. Hart FF004
Winchester, IN
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Tue Jan 24, 2006 10:56 am Post subject: Re: VORTEX GENERATORS |
Group,
I have my set of LandShorter VG's, and now I have to put them on. I went to Home Depot, Lowes, Walmart and a harware storeto get the 3M tape, and cannot find it.
So, I thought that I would skip the tape and put them on permanently. But I don't know how much Loctite 401 is needed.
I also don't have any formica laying around to make a template.
Any tips on installing the LandShorters will be appreciated. Also, is 11 inches back from the leading edge the best position on a Kolb?
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
HShack(at)AOL.COM Guest
Posted: Tue Jan 24, 2006 11:21 am Post subject: VORTEX GENERATORS |
In a message dated 1/24/2006 1:57:23 PM Eastern Standard Time,
jrjungjr(at)yahoo.com writes:
My VG's seem to work best on the FS II with the rear of them at 11" back. Do
not measure following the curve of the wing but do use a square & measure
straight back.
Howard Shackleford
FS II
SC
edchmiel(at)mindspring.co Guest
Posted: Tue Jan 24, 2006 12:27 pm Post subject: VORTEX GENERATORS |
Hi John,
Have you tried a hobby shop that has RC planes? They have
double-sided tape in various thicknesses. Also try the big office supply
stores.
You could probably make a template out of poster board. The
placement isn't that critical, close is good.
As far as the worries about 'deep stall' with VG's on the tail
bottom, the conventional configuration of the Kolbs does not lend itself to
that. Aft CG would be a much bigger worry in any stall recovery scenario.
The conventionally-configured GA aircraft (non T-tail) aircraft I've flown
with VG's on the bottom of the tail flew off nicely at takeoff, rock-solid
at slow speeds, but when they quit flying it was a bit more abrupt than
without VG's. Still had good control, but you better be 6" off the ground
when it quit.
Ed in JXN
MkII/503
Richard Pike
Posted: Tue Jan 24, 2006 12:51 pm Post subject: VORTEX GENERATORS |
Here are some pictures of the VG's on the wing of our FSII, and notes on
placement.
Don't know anything about Loctite 401, we used Shoe Goop from Walmart.
Richard Pike
John Jung wrote:
Quote: |
Group,
John Jung
Firestar II N6163J
Surprise, AZ
http://forums.matronics.com/viewtopic.php?p=6495#6495
Kingsport, TN 3TN0
Posted: Tue Jan 24, 2006 1:50 pm Post subject: VORTEX GENERATORS |
No picture link
Richard Pike
Posted: Tue Jan 24, 2006 2:03 pm Post subject: VORTEX GENERATORS |
Quote: |
No picture link
Oh, yeah - Duh...
http://www.bcchapel.org/pages/0003/kolb.htm
Scroll down to Firestar II Tweaks and Hints, click on Vortex Generators
[quote]do not archive
Kingsport, TN 3TN0
Possum
Posted: Tue Jan 24, 2006 2:12 pm Post subject: VORTEX GENERATORS |
At 01:56 PM 1/24/2006, you wrote:
I went to an "auto paint store" and got the "good" double stick tape.
Automotive Acrylic Plus Attachment Tape
Stick it on the bottoms of the VGs, then cut around the edges with an
exacto knife.
When you putting them on your wings, you just pull the paper off the
botton and stick them down.
Haven lost one yet.
The instructions say put them on 10 to 12% of the wing cord (including the
ailerons)
back from the leading edge. Too far forward and they will slow down the cruise
speed, too far back and they become ineffective.
I put mine about 11% or 6 1/2 inches back from the leading edge as measured
through the middle of the cord of the wing - average cord.
But you better check with the instructions.
The instructions say VG's should be placed about 1% of the wingspan apart.
I have a 27' 9" wing span.
So I put two in each valley and used the 2.75 inch spacing guide
to "kind of space them out" between each rib and false rib etc.
Just a guess, but it seemed to work out OK.
I made a guide out of some thicker material with the little "rectangles" cut
out where the VG's go, so I could just stick them in the holes
and move the guide to the next valley.
I just put two on at a time and moved the guide to the next set of ribs.
I used the T-square method like Ben Ransom for the set back
<http://www.bcchapel.org/pages/0003/Vortex%20Generators.html>http://www.bcchapel.org/pages/0003/Vortex%20Generators.html
It took more time to put the tape on each VG than it did
to put the VGs on the plane.
Quote: |
Group,
John Jung
Firestar II N6163J
Surprise, AZ
Possum
Posted: Tue Jan 24, 2006 2:43 pm Post subject: VORTEX GENERATORS |
I forgot to say that I've got an 8 rib wing - your's may be different.
John Jung
Posted: Tue Jan 24, 2006 9:23 pm Post subject: Re: VORTEX GENERATORS |
Don G.
After your testing, how far back did you place the LandShorters? What distances from the leading edge did you try?
Firestar II N6163J
Surprise, AZ |
Possum
Posted: Tue Jan 24, 2006 10:17 pm Post subject: VORTEX GENERATORS |
At 12:23 AM 1/25/2006, you wrote:
Quote: |
Don G.
John Jung
Firestar II N6163J
Surprise, AZ
That's the advantage of using the tape to put them on. You can take
them off with mineral spirits (at least with the tape I used) and
move them. Doesn't hurt the lexan VGs either. I stuck one on my car
windshield for a week before I ever put them on my plane - just to
make sure they would stay in place and to make sure I could take them
off if I didn't like them. They "may" work just as well at 11 inches
back as they do at 11% of the cord. I don't know, I didn't have to
move mine. If your not Very impressed at what they do, I would not
leave them on your plane. It's not something that you would have to
wonder if they're working or not - you will definitely know the
difference. Especially on take off - when you go full throttle and
just keep easing the stick back. Your nose just keeps going up and up
- your speed keeps going down and down - and it just doesn't stall. Neat!!
Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Wed Jan 25, 2006 6:29 am Post subject: Re: VORTEX GENERATORS |
John J,
You are taxing my poor memory John...(grin).....but I had those VGs from 14 back from the leading edge...to 6 inchs back..measured with a square..not around the airfoil. I also tryed a staggered pattern...and a chevron pattern...with the outboard VGs aft and the inboard fore. Neither of these worked worth a dang BTW. NOw I have the landshorters on permenant...all my moveing around was with the alum vgs John , as the little LS VGs couldnt hardly be applied with tape. As I mentioned...mine are a little farther back than LS recommended. They had a spec...which I cannot remember..but was a % of the chord from the LE..when I calculated this, it was at the foremost of the testing I did..and knew I wanted a higher ROC than a lower stall and set the LS vgs back a bit..I think about 10 or 11 inchs..I will measure them when I get over to the hangar sometime. I guess I oughtta go see if the flag fly is still there! Been working on this old Luscombe in what spare time I have.
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
n79rt(at)kilocharlie.us Guest
