Tim(at)MyRV10.com Guest
Posted: Thu Sep 28, 2006 1:50 pm Post subject: RV-10 Nose Wheel Safety Issue : Repost from RV-List |
I didn't see that Russ posted this to the RV-10 list, just the RV-List,
so I am reposting it here.
I lost in flight one of the U-1024's (page 48-17) attached to the 1013C,
bracket along with the mounting screw (Allen head) and lock washer. I am
not sure what caused the loss but no damage occurred.
I have since drilled the heads of the two mounting screws and drilled a
safety wire hole in the two 1013C's so that I can safety wire the two
mounting screws to the mounting bracket and this cannot happen again. I
drilled the heads in two 90 degree locations so that when I safety wire
I can run the wire from either the top or bottom of the screw head and
the tow bar will not sub on the safety wire while moving the airplane.
If both U-1024's had come loose and the 1013C mounting brackets had both
slide back I could have suffered major damage to the nose wheel pant on
landing.
My assumption is that while moving the RV-10 with the two bar the two
bar pressure caused the mounting screw to back off the lock washer
enough that during flight the vibration caused the screw to back out far
enough to drop off the U-1024 into somebody's pasture.
__________________
Russ Daves
Lubbock, TX
N710RV - RV-10
First flight 7/28/06
