pacificpainting(at)comcas Guest
Posted: Thu Sep 28, 2006 9:53 pm Post subject: 801 Fuel Sender Question |
I am installing the fuel gauge senders in my tanks tonight. It seems like I should turn the units so the float is near the front of the tank so that it will read full when it really is completely full since the tank is tapered. Any thoughts or suggestions?
After driving down to California yesterday and touring the shop, I decided to order an Xtreem IO-360 from Eagle Engines. (which I did today). Looks like I'm really committed for sure, or at least I will be if my Wife finds out how much I spent.
Dave in Salem
801
bryanmmartin
Posted: Fri Sep 29, 2006 1:35 am Post subject: 801 Fuel Sender Question |
It's most important for the gauge to read accurately near the bottom of the scale, that's when you really need to know how much fuel you have left. If it takes a while to move off the full mark, it's not a big deal.
On Sep 29, 2006, at 1:51 AM, Dave Ruddiman wrote:
| Quote: | I am installing the fuel gauge senders in my tanks tonight. It seems like I should turn the units so the float is near the front of the tank so that it will read full when it really is completely full since the tank is tapered. Any thoughts or suggestions?
Dave in Salem
801
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
n801bh(at)netzero.com Guest
Posted: Fri Sep 29, 2006 5:13 am Post subject: 801 Fuel Sender Question |
My 801 flies and sits on the ground in a nose high attitude, If the float was positioned forward it would indicate a lower fuel level then actual. Just my opinion......
Ben Haas
N801BH
www.haaspowerair.com
Dave in Salem
801
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
ics.com
www.matronics.com/contribution
Tom
Posted: Fri Sep 29, 2006 11:46 am Post subject: Re: 801 Fuel Sender Question |
I was going to point mine 90 degrees from the edge and at the time I was installing mine I'm pretty sure there was some backup to that thought but I can' t remember, I do agree with Ben as to not put it pointing to the front and the further back you aim it will keep it on full longer than the true reading. You can also nit pick trying to figure out all the pro's and con's of all these senerio's like we all have done throughout the project or just point the thing in the middle and forget about it!
_________________ Tom CH801
http://tompizza.webhop.net |
Posted: Fri Sep 29, 2006 12:23 pm Post subject: 801 Fuel Sender Question |
Hi Tom,
I called ZAC today to ask them. Not sure who I talked to, but since he had
an accent I figured it was someone important. He said to just mount it
spanwise, which is what I thought it should be also, but I'm always open to
suggestions and someone else's experience.
Dave in Salem
801
