FLYaDIVE(at)aol.com Guest
Posted: Sun Oct 01, 2006 6:09 am Post subject: battery cables & Relays - Now G's |
In a message dated 9/30/06 1:59:19 PM Eastern Daylight Time,
robert.mccallum2(at)sympatico.ca writes:
| Quote: | The "G" forces required to open a closed contactor are generally not
survivable. (or at least very close to it). I don't have quantitative
numbers, but I have tried pulling one open and the force required is VERY
significant. Many, many times that required to close it.
Bob McC
Dave & Bob:
UhmpTeen years ago I had access to a laboratory of test equipment. And did
some pretty weird tests ... Mostly for the government ... Figures ... They are
TOTALLY WEIRD! And useless I might add.
Anyway ... How many 'g's' do you think it takes to pop on a Bic Pen cap, you
know the old style Bic Pen that had the clear barrel and the blue removable
snap on cap?
The procedure was to LIGHTLY place the cap on the tip of the pen.
Hold the pen in a vertical position with the cap and point facing UP.
Then drop the pen on the other end.
The drop (KE) with the sudden stop would pop the cap onto the pen.
The height was increased until the cap was fully seated.
If I recall the height was somewhere around 4 or 5 feet onto a steel
accelerometer surface.
So how many 'g's' do you think?
Remember the height was ONLY 4 to 5 feet.
Barry
"Chop'd Liver"
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Sun Oct 01, 2006 6:40 am Post subject: battery cables & Relays - Now G's |
Interesting test, but not really valid here...
You "Bic pen" test measured essentially two things:
Friction
Sealing
These are the two factor that determine the ease (or lack thereof) with
which the cap can be seated on the pen.
Gravity would have been a negligible factor in this type of test.
With a contactor, you are dealing with a solenoid, which is designed and
constructed to provide a given, and measurable, amount of "pull in" force.
You can also simply weigh the object being pulled in.
Just as a hypothetical...note that I am neither a scientist nor an engineer,
so if I'm "terminology deficient" please try to let it slide.
Assume that, if operated vertically, the solenoid can lift a 15 lb weight.
Also assume that the movable contactor portion of the device weighs 1 lb.
Obviously, it would take a gravitational force of greater than 15 g's to
open the contactor.
Note that it was only "static" gravity being considered in the above
hypothetical.
In an aircraft flying aerobatics, such factors as acceleration would also
play a part in the equation...
N6030X(at)DaveMorris.com Guest
Posted: Sun Oct 01, 2006 6:57 am Post subject: battery cables & Relays - Now G's |
Barry, I think that would depend on whether it was a girl's BIC pen
or a guy's. (Girls tend to chew on the caps and then a higher force
is required to re-cap them).
I give up, how many g's?
Dave Morris
At 09:07 AM 10/1/2006, you wrote:
> Bob McC
Dave & Bob:
... They are
snap on cap?
Barry
"Chop'd Liver"
Bob McC
Posted: Sun Oct 01, 2006 7:34 am Post subject: battery cables & Relays - Now G's |
Bill;
_________________ Bob McC
Falco #908
(just starting) |
khorton01(at)rogers.com Guest
On 1 Oct 2006, at 10:07, FLYaDIVE(at)aol.com wrote:
> quantitative
> is VERY
> Bob McC
Dave & Bob:
And did
cap, you
removable
snap on cap?
How did you determine the relationship between the reading on
accelerometer when the pen landed on it and the acceleration that the
pen cap was subjected to?
If the accelerometer wasn't mounted on the pen cap, I'm not really
sure what you were measuring.
Kevin Horton
Ottawa, Canada
Bob McC
Posted: Sun Oct 01, 2006 7:54 am Post subject: battery cables & Relays - Now G's |
Barry;
I don't know, but it's going to be pretty high as the deceleration distance is extremely small, and you have to provide enough force to overcome distorting the plastic past the detents. The weight of the cap is tiny, the force required a few ounces, so the G's will be extreme. (now there's a quantified term for you )
Bob McC
DO NOT ARCHIVE
[b]---
Falco #908
(just starting) |
nuckollsr(at)cox.net Guest
Posted: Sun Oct 01, 2006 12:37 pm Post subject: battery cables & Relays - Now G's |
At 11:33 AM 10/1/2006 -0400, you wrote:
>>quantitative
>>is VERY
>> Bob McC
>Dave & Bob:
>And did
>cap, you
>removable
>snap on cap?
I'm having trouble visualizing it too. The acceleration imparted
on the cap was a function of change in velocity and
time over which the change takes place. Acceleration =
delta velocity / t. Terminal velocity on a 5 foot
fall at 32.16 f/s/s is 18 feet/second.
When the pen hits the hard stop, we don't know what
time interval elapses between first contact and zero
velocity . . . i.e. time to bring to rest. The smaller
the number, the higher the acceleration. I suspect the
accelerometer was used as a timing device . . . I.e,
measurement of the force interval for stopping the
pen's fall, not as a direct measurement of acceleration.
In any case, numbers in the hundreds of g's would not
surprise me.
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sun Oct 01, 2006 7:15 pm Post subject: battery cables & Relays - Now G's |
Man, you sure can tell it's the weekend...
_________________ From The PossumWorks... |
Posted: Mon Oct 02, 2006 4:13 am Post subject: battery cables & Relays - Now G's |
In a message dated 10/1/06 11:58:27 AM Eastern Daylight Time,
| Quote: | Barry;
distance
| Quote: | is extremely small, and you have to provide enough force to overcome
Bob McC
EXCELLENT Bob, EXCELLENT!
Now I know this is going to sound really crazy but ...
It averaged 200 g's
g's can be measure in either acceleration or deceleration and as the joke
goes ... It is not the fall that kills you, it is the sudden stop.
Barry
"Chop'd Liver"
Posted: Mon Oct 02, 2006 4:14 am Post subject: battery cables & Relays - Now G's |
Hi Bill:
- Bill's thoughts -
Friction
Sealing
[Barry] -
Friction - YES
Sealing - NO
The test does not care if the cap seals, all it cares about is overcoming
friction and moving the cap to is closed position.
Other factors is the weight of the pen, weight of the cap and distance
dropped, velocity of the objects before stopping and force absorption on the objects
and impact surface. KE = 1/2 M x V2
But, take a guess on how many 'g's' were developed?
- Bill's thoughts -
open the contactor.
[Barry] - Good analogy, but what happened to the FRICTION, if it is part of
the pen it is part of the solenoid. And there is also the constant opposite
pull of the coil/solenoid for as long as power is applied.
- Bill's thoughts -
[Barry] - And when would acceleration be encountered? Especially at Max
acceleration?
NOT in straight and level flight! For the only acceleration then would be
Rearward. Not pulling down on the plunger of the solenoid. (Vertically mounted
relay)
If you consider the acceleration {But it really isn't, it is the g force you
are feeling} when you pull out of a dive ... That is a change in velocity
which equates to g forces.
When you pull out of a dive the plane slows down, it does not increase in
speed. It is only the g force you feel that gives that impression.
There is a difference between Velocity and Speed.
Questions:
If you point the nose of the plane down, say 3 degrees and the prop RPM is
fixed will the plane increase in speed until it hits something?
If you feel the g force (greater than 1 g) only during acceleration why can
you feel the g force in a centrifuge at a constant speed?
fixed will there be an increase in g force until it hits something?
Ain't physics grand? An Exlax a day keeps everybody away.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Posted: Mon Oct 02, 2006 4:31 am Post subject: battery cables & Relays - Now G's |
In a message dated 10/1/06 12:58:53 PM Eastern Daylight Time,
N6030X(at)DaveMorris.com writes:
| Quote: | Barry, I think when I worked in a government lab I must have had more
fun than you. We were shooting down missiles using an airborne laser
in a KC-135. You should see what a gigawatt pulsed CO2 laser does to
a BIC cap, or a chunk of asbestos concrete.
Dave Morris
Dave:
You are a sick puppy ... But I like the way you think! (Punch line taken
from a joke)
I don't know who had more fun, but it sure was interesting. So, do we use
LASER cannons today? Where can I get one? Are they small enough to mount on my
car?
Probably too expensive ... Just send me the schematic, I'll build one.
Barry
"Chop'd Liver"
Posted: Mon Oct 02, 2006 4:39 am Post subject: battery cables & Relays - Now G's |
In a message dated 10/1/06 11:37:26 AM Eastern Daylight Time,
khorton01(at)rogers.com writes:
| Quote: | How did you determine the relationship between the reading on
Kevin Horton
Ottawa, Canada
Hi Kevin:
By starting off in low increments of height and dropping the pen; at some
height the cap would snap onto the barrel. Since all parts were falling as one
unit the acceleration was the same for both the cap and the barrel. The
accelerometer just read of the force of the impact in g's.
Sort of like the egg drop experiment but in reverse. We did not want to
preserve the egg
We were making egg salad .
Barry
"Chop'd Liver"
Bill Denton
Posted: Mon Oct 02, 2006 4:41 am Post subject: battery cables & Relays - Now G's |
Just for fun, a couple of points...
I threw in "sealing" in the Bic pen discussion to deal with the air trapped
in the cap. Given sufficient sealing, you would never be able to get the cap
farther down than the compressibility of air would permit.
I ignored friction in the solenoid as it would actually increase the force
required to open the contacts.
Interesting discussion...
Posted: Mon Oct 02, 2006 5:09 am Post subject: battery cables & Relays - Now G's |
In a message dated 10/1/06 11:19:07 PM Eastern Daylight Time,
Fiveonepw(at)aol.com writes:
| Quote: | Man, you sure can tell it's the weekend...
And a RAINY one here in the Mid Atlantic - NJ
Posted: Mon Oct 02, 2006 5:16 am Post subject: battery cables & Relays - Now G's |
In a message dated 10/1/06 4:41:52 PM Eastern Daylight Time,
nuckollsr(at)cox.net writes:
| Quote: | I suspect the
surprise me.
Righty O! Bob ...
Averaged 200 g's
The accelerometer read out in g's and the output was also shown on an
O'scope. There was also other numbers, I don't recall, probably Newtons.
Barry
"Chop'd Liver"
Posted: Mon Oct 02, 2006 6:20 am Post subject: battery cables & Relays - Now G's |
At 08:38 AM 10/2/2006 -0400, you wrote:
> Kevin Horton
> Ottawa, Canada
Hi Kevin:
as one
preserve the egg
Yeah, but if the accelerometer were stationary on
the 'floor' then it's already at-rest when the pen
hits it. The only data one might expect from the accelerometer
is duration of the deceleration event, not its magnitude
but I've not convinced myself that would work either.
Accelerometers are sensitive to delta-v. If the critter
is stuck to a relatively rigid surface like a concrete
floor, whacking it with a falling pen would impart no
motion.
I think Gilles' suggestion for calculating the ratio
of seating force to cap mass would yield the most
meaningful result.
