n8vim(at)arrl.net Guest
Posted: Sun Oct 01, 2006 9:16 am Post subject: Replacement Air Compressor |
While we are on the subject,
I am considering replacing my old compressor ("5HP" Coleman Black
Max, 20 Gal. Tank). While it does do the job, it is quite loud and runs
almost continuously while using the die grinder. I cannot talk to anyone
in the shop while it is running.
I am looking for a compressor which matches, or exceeds these specs:
1. Quiet !! (Yes, I know its subjective.. Use your best judgement)
2. 60-80 Gallon tank (Vertical)
3. Twin cylinder oiled compressor
4. 208/220v motor
5. Minimum 10CFM (at) 90PSI
6. $800 or under
Got any suggestions?
-Jim 40384
Rick S.
Posted: Sun Oct 01, 2006 9:41 am Post subject: Replacement Air Compressor |
You can't beat that one John mentioned he saw at Costco....I think it exceeds your minimums for less than $400.
Rick
40185
_________________ Rick S.
RV-10
40185 |
LIKE2LOOP(at)aol.com Guest
Posted: Sun Oct 01, 2006 11:16 am Post subject: Replacement Air Compressor |
If you have a lot of space in your shop and the old compressor tank is in good shape, you can increase capacity by keeping the old tank in series with the new one. Go for the best compressor head and add capacity.
Steve
ninepapa(at)bendbroadband Guest
AV8ORJWC
Posted: Sun Oct 01, 2006 12:36 pm Post subject: Replacement Air Compressor |
Give consideration to using the old tank with a simple vacuum
compressor. You can do some fabulous composite lay-ups' with simple
materials and the ole reservoir tank connected off the vacuum pump.
Recovered compressors from junked refrigerators can be had for a song
with simple soldering.
The tanks alone at Harbor Freight are running $27.00.
John 40600
bob.kaufmann(at)cox.net Guest
Posted: Sun Oct 01, 2006 2:02 pm Post subject: Replacement Air Compressor |
Put the Costco special next to the neighbors laundry room, plumb in your
tank in series in your garage, and if you are real sneaky, wire into your
neighbors hot tub circuit.
Does that make you eligible for an energy efficient unit or what?
Seriously, going with the Costco unit and running your tank as a buffer
extra capacity is a great idea. Do put on outside and the other anywhere,
but the extra volume is well worth it.
Bob K
I hate fiberglass
