		darinh
				 Posted: Sun Oct 01, 2006 1:04 pm    Post subject: Two Series 7 Questions |
				I am prepping my tanks for install on my Series 7 and have run into a few questions.
 1.  The manual says to carefully tap the the openings in the tanks to clean out the existing threads.  I then says to use a 1/8" NPT and 3/8" NPT tap.  Obviously the 1/8" must be a typo as there are no holes in the tank that size.  QUESTION:  What are the correct sized as I will need to buy taps this size (they look to be 3/8" NPT and 5/8" NPT, not 1/8").
 2.  The manual also says to use a thread sealant that is compatible with gasoline.  I have a small tube of sealant that came with the kit labeled 9AR.  QUESTION:  Is this the thread sealant I should use?  And if not, can someone suggest a one that has worked?
 Lastly, and this has been beaten like a dead horse, but I have yet to figure it out.  What has everyone been doing about the E85 fuel compatibility of the resin in our tanks?  I have yet to find a slosh that is compatible.  I know there has been at least a couple of Kitfoxes built within the last year, so someone should know something.  There is always the option of simply not using gasoline and sticking with 100LL with a lead scavenger which is what I am planning.  But is is nice to be able to fill up with premium unleaded when at the home field.  If anyone knows of a product that will work, I would appreciate hearing about it.
 Thanks guys,
 Darin Hawkes
 Series 7
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jdmcbean(at)cableone.net Guest
				 Posted: Sun Oct 01, 2006 1:25 pm    Post subject: Two Series 7 Questions |
				Darin,
 	The 1/8" and 5/8" NPT are correct.  The 1/8" NPT is are the fuel sight tube
 fittings and vent tube.  The 5/8" NPT is the main fuel line where the finger
 strainer is used.  The 9AR is a good fuel sealant has worked well on ours.
 Fly Safe !!
 John & Debra McBean
 208.337.5111
 www.kitfoxaircraft.com
 "It's not how Fast... It's how Fun!"
		pwmac(at)sisna.com Guest
				 Posted: Sun Oct 01, 2006 3:14 pm    Post subject: Two Series 7 Questions |
				Wow, E85 will eat most any thing in a fiberglass tank as well as the
 sealant for the fittings. E10 is bad enough.
   Lots of fitting sealer used over  the years for various members of
 the list. I am sure you will get many suggestions. Some work some
 don't. My suggestion is to call Permatex and get ahold of the
 application engineer and tell him what fuel you want to use and that
 you have a fiberglass tank. Do not tell him it is for an airplane.
 The guy will tell you what their best product is. And I bet it will
 be different than when I called 2 years ago.
   Don't worry about the tap - just use the one that fits.
 BTW, you should reconsider using E85 its bad stuff and I know of no
 engine used in planes that will not be damaged by the stuff, unless
 you are using something out of an auto less than a year old that was
 originally designed for E85. I know of no sloshing compound designed
 for pure or 85% alcohol. You would need nylon, polyurethane, or
 Aluminum tanks. Then you would have to use Teflon hoses and then make
 your engine compatible buy changing the materials in the
 fuel  system. Its a real big deal to use more that 10%
 Regards, Paul
 At 03:04 PM 10/1/2006, you wrote:
 a few questions.
 Thanks guys,
 Darin Hawkes
 Series 7
 http://forums.matronics.com/viewtopic.php?p=65054#65054
		Guy Buchanan
				 Posted: Sun Oct 01, 2006 3:35 pm    Post subject: Two Series 7 Questions |
				At 02:04 PM 10/1/2006, you wrote:
  	  | Quote: | 	 		  1.  The manual says to carefully tap the the openings in the tanks to
 The sizes recommended are correct. A 1/8" NPT looks like 3/8" NC. It's a
 bit confusing because they're pipe sizes.
 However, if I had to do it over again I'd do some serious investigation
 into putting a permanent 1/2" NPT boss at the intakes to facilitate
 repeated removal and installation of the finger strainers. The 1/8 NPT
 brass vent boss is permanent, since the vent is attached using a 90 degree
 AN fitting into a pipe/flare junction, which is never removed from the
 brass boss which is never removed from the tank. However the 3/8" NPT
 finger strainers are threaded into the tank directly which makes
 maintenance a pain. Eventually the threads will fail and I'll have to do
 the 1/2" boss installation with the tanks in the plane. I understand using
 a 1/2" boss will raise the pick-ups about 3/16", but since I never run the
 tanks that dry anyway I don't think it will be a problem.
  	  | Quote: | 	 		  2.  The manual also says to use a thread sealant that is compatible with
 I tried lots of things which didn't work. (Permatex 1 & 2 & Grey.) The one
 that did was the 2-part polysulfide sealant sold by, among others, Aircraft
 Spruce. It's hideously expensive and messy to work with, but it definitely
 works with 100LL, even on a polyethylene tank. (This before Herb found the
 great polyethylene adhesive. I should have looked harder. Thanks Herb!)
 Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
		Guy Buchanan
				 Posted: Sun Oct 01, 2006 3:42 pm    Post subject: Two Series 7 Questions |
				At 04:10 PM 10/1/2006, you wrote:
  	  | Quote: | 	 		  You would need nylon, polyurethane, or
 Regards, Paul
 Paul,
          I wouldn't go that far. Most gasoline storage tanks are made, now,
 of vinylester / E-glass laminate. It's entirely possible, (though
 unlikely,) that Skystar used vinylester in their original fabrication and
 that the tanks are impervious to auto and aviation fuel. Maybe John McBean
 at Kitfox will know.
 Guy
Deceased K-IV 1200
		darinh
		shilocom(at)mcmsys.com Guest
				 Posted: Sun Oct 01, 2006 5:21 pm    Post subject: Two Series 7 Questions |
				http://www.age85.org/
 Go to the above site and study for a while before making such claims below.
 Many Lycomings and Continentals are run on AGE85 which is at least 85%
 ethanol and generally closser to 90%.  Read for yourself.  Bob U.
				 Posted: Sun Oct 01, 2006 5:22 pm    Post subject: Two Series 7 Questions |
				By the way the PR-1005-L slosh sold by ASP is good for Ethanol.   You can
 call 1=800-237-6649 or ASP them selves.  Bob U.
		Float Flyr
				 Posted: Sun Oct 01, 2006 5:43 pm    Post subject: Two Series 7 Questions |
				Your post is the first I've heard of a lead scavenger can you tell me more
 about this process?
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Float Flyr
				 Posted: Sun Oct 01, 2006 6:10 pm    Post subject: Two Series 7 Questions |
				I notice this fuel is so good it requires an STC. Available for only few
 engines and it seems only on a C180.  This is uncertified fuel and there
 fore should not be used when carrying paying passengers.
 I noticed one of the constituents is bio-diesel  A fuel that has no specs
 what ever.  So much for consistency.  Of course with the affinity ethanol
 has for water/vapour you can't expect any consistency any way.
  The only plus I see is it is described as being no lead.
 Before using this stuff be sure your complete fuel system is ethanol
 compatible and your insurance allows it's use.
 I've said it before and I'll say it again.... Ethanol is a dismally poor, at
 best, half baked, makeshift answer to a big question.  There are better
 answers out there all we have to do is develop them.  Of course most of
 these answers won't get politicians in agricultural ridings get re-elected
 Alcohol and flight should be separated by at least twelve hours....always!
 Noel
 [quote] --
Kitfox III-A
		Float Flyr
				 Posted: Sun Oct 01, 2006 9:02 pm    Post subject: Two Series 7 Questions |
				I feel fortunate that there is so little ethanol degraded fuel in this area.
 There seems to be two or three things that can be done when dealing with a
 substance that is better suited to a glass after flying than in a tank to
 fly on.
 1. The alcohol can be washed out of the fuel using plain old fashioned
 water.  This of course has to be done in separate containers and the water
 drained off before fuelling your plane.  There are a couple of
 inconveniences, one, it requires separate containers that you won't be
 flying to remote fields with and secondly, you cant be sure of what other
 additives the water will wash out.
 2. Find a source of non eth fuel.
 3. A guy on another list says he has been using eth laced fuel for years
 with no problems(composite tanks) He was premixing his gas for his R582.
 Recently, within the last year, he installed a Jab and now uses a little top
 lube (oil) in his gas in hopes that is why his tanks were not attacked by
 the booze.  He may be right as it is more than possible that the alcohol may
 have more affinity to oil than to epoxy.
 The old dead horse now officially flogged again!
 Noel
  	  | Quote: | 	 		   Lastly, and this has been beaten like a dead horse, but I
Kitfox III-A
		darinh
				 Posted: Mon Oct 02, 2006 7:49 am    Post subject: Re: Two Series 7 Questions |
				Float Flyr,
 We don't have ethynol laced fuel in my area yet either but I am sure it is coming.  I will use premium unleaded in my Series 7 until they start mixing the corn gas (ethynol) in.  At that point, I will make the switch to 100LL with a lead scavenger.  In my model III I always carried a bottle of the scavenger for when I fueled up while on X-country trips.
 The scavenger is called Decalin TCP and John McBean sells it on Sportplanellc.com.  Here is a link:
 http://www.sportplanellc.com/Decalin%20TCP.htm
 John uses it exclusively in his personal Kitfox as I understand and if its good for his Fox, it will be good for mine.
 Darin Hawkes
 Series 7
