slook(at)mchsi.com Guest
Posted: Tue Sep 26, 2006 5:42 am Post subject: right angle drill? |
I'm ready to drill the front rib attachments on my wing spar but the
trusty DeWalt cordless is too big to do the job. Does anyone have a
recommendation for an electric drill small enough to get in there?
Steve
Steve Look
Monticello, IL
601XL
"Dogs have owners, Cats have staff"
Chris Lewis
Posted: Tue Sep 26, 2006 6:09 am Post subject: Re: right angle drill? |
Steve - I bought a cheapie right angle drill from Harbor Freight. Less than $30.00
Chris in Seattle
Description: |
Filesize: |
14.53 KB |
Viewed: |
583 Time(s) |
_________________ 750/ Zen-vair Semi-Scratch Builder
N750XT (reserved) |
p.mulwitz(at)worldnet.att Guest
Posted: Tue Sep 26, 2006 6:58 am Post subject: right angle drill? |
Hi Steve,
I use a right angle drill attachment for my drill. It takes 1/4x28
threaded drill bits. I use the same short threaded drill bits for
all my aluminum drilling. I made a threaded round bar for my drill
to mount these bits, but there are many right angle kits that come
with an adapter for your drill.
I think I got my right angle drill from Aircraft Spruce, but I looked
in the current online catalog and didn't find the same one. I paid
around $50 for a reduced kit that didn't include the fancy plastic
case. It just came with the right angle adapter, a couple of
extensions and a small handful of drill bits.
Paul
XL fuselage
Steve
Steve Look
Monticello, IL
601XL
_-
randy(at)n344rb.com Guest
Posted: Tue Sep 26, 2006 7:02 am Post subject: right angle drill? |
A flex shaft used in a Dremel tool works good too.. This is how I drilled
mine...
Randy
XL Wings - Plans Only
dredmoody(at)cox.net Guest
Posted: Tue Sep 26, 2006 7:04 am Post subject: right angle drill? |
I bought the "Deluxe Tight Fit Tool Kit" from Aircraft Spruce. Part number 11215. It comes with a right angle attachment that you drive with the drill of your choice. The kit includes a case with all the drill sizes and lengths taht you are likely to need. Sells for around $60 and will prove very helpful throughout the construction of your plane.
I'm sure there are cheaper ones but this is a one time purchase that will last long enough to finish the plane without hunting up the individual components and keeps the stuff organized in a plastic case where you can find what you need when you need it.
Comes in very handy when you would otherwise traumatize the adjacent aluminum with the chuck of a regular drill.
Ed Moody II
Rayne, LA
601XL / cabin
Jabiru 3300
Steve
Jaybannist(at)cs.com Guest
Posted: Tue Sep 26, 2006 7:28 am Post subject: right angle drill? |
Steve, I got a right angle drill attachment directly from Tight Fit Tools. I don't remember what I paid for it, but whatever it was, it was worth it. I can't count the times and places that I've used it. In fact, I have been using it this morning. I got extra bits in sizes 40, 30, 20 & 3/16". I can recommend it with one caveat: It is a two-handed opration, so if you need to press a wood block behind whatever you are drilling, you'll need another hand. They have a good web site.
Jay in Dallas, working on XL fuselage [quote][b]
rstone4(at)hot.rr.com Guest
Posted: Tue Sep 26, 2006 9:11 am Post subject: right angle drill? |
Stephen,
The one and only quality miniature tool I can think of is the DREMEL.
The basic tool comes with 5 accessories for $59.95. There is an accessory
available for this tool called the FLEX-SHAFT for getting into real small
places and this attachment sells for $32.60. If you are interested I got
this information from the catalog. Wholesale tool Company.
http://www.wttool.com If you ask for a catalog they will send you one and
it's the cheapest outfit I ever heard of that quality US made tools.
Bob Stone, Harker Heights, Tx
ZodiacXL
Posted: Tue Sep 26, 2006 9:20 am Post subject: right angle drill? |
Tight Fit Tools at http://www.tightfittools.com/
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jaybannist(at)cs.com
Sent: Tuesday, September 26, 2006 9:28 AM
Subject: Re: Zenith-List: right angle drill?
Posted: Tue Sep 26, 2006 9:42 am Post subject: right angle drill? |
Yes, this is what I did and it worked out really well... I had to also
purchase a drill chuck to fit the flex shaft to hold the drill, but it
wasn't expensive... I got all of my Dremel stuff at Home Depot... I know
Lowes carries all of this stuff as well...
Randy
hrs1(at)frontiernet.net Guest
Posted: Tue Sep 26, 2006 12:32 pm Post subject: right angle drill? |
Steve . . . I believe the product is Tight Fit Drill Kit made by the
Onmi Manufacturing Company in Sante Fe Springs, CA. The drill
attaschment(s) work great both in a straight ahead mode and at right
angles. It saved my bacon a couple of times. Robert Schoenberger 701
Paul Mulwitz wrote:
Quote: |
<p.mulwitz(at)worldnet.att.net>
Hi Steve,
threaded drill bits. I use the same short threaded drill bits for all
my aluminum drilling. I made a threaded round bar for my drill to
mount these bits, but there are many right angle kits that come with
Paul
XL fuselage
> Steve
> Steve Look
> Monticello, IL
> 601XL
> _-
grs-pms(at)comcast.net Guest
Posted: Tue Sep 26, 2006 3:31 pm Post subject: right angle drill? |
Dremel now makes a pistol-grip cordless tool which is very compact. I
haven't had a chance to try one out but I'm putting it on my Christmas list.
Meantime, I have had good luck with the right-angle kit that someone
mentioned.
George
Posted: Mon Oct 02, 2006 5:55 am Post subject: right angle drill? |
I thought I would let the group know what I have discovered and keep
somebody else from making the same mistake...
The Dremel right angle adaptor will not work with a #20 drill bit.
The largest collet available is 1/8" and is too small. The Dremel
chuck that I got is also too small for a #20 bit. The Dremel flex
attachment would have the same limitation.
I bought a chuck-to-hex-drive accessory for $5 and have been using
that with a skinny cordless screwdriver and that works fine but it's
kind of slow.
I went over to Harbor Frieght and their "close quarters" drill is far
too large.
I think an order to Tightfit Tools is coming up...
Steve
Steve Look
Monticello, IL
601 XL - wing
Float Flyr
Posted: Mon Oct 02, 2006 2:37 pm Post subject: right angle drill? |
I'd try turning down the shank of the drill bit.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
cleonard52(at)comcast.net Guest
Posted: Mon Oct 02, 2006 2:39 pm Post subject: right angle drill? |
TRY AN AIR DRILL, MOST ARE VERY NARROW.
[quote]-------------- Original message --------------
[quote] --> Zenith-List message posted by: "Stephen R. Look"
kind of slow.
too l arge. much m [quote][b]
naumuk(at)alltel.net Guest
Posted: Mon Oct 02, 2006 2:47 pm Post subject: right angle drill? |
Depends on where the hole you need is located, but I couldn't find a
suitable right angle drill, either. Went with the HF version of a Whitney
punch. They had an extra deep throat (We won't even go there) on sale a
couple of weeks ago that wound up costing me $12.95 after all the coupons.
Bill Naumuk
HDS Fuselage
Townville, Pa
Malcolm.HUNT(at)networkra Guest
Posted: Tue Oct 03, 2006 2:45 am Post subject: right angle drill? |
Steve
I heated the top 1" of the stock of the #20 drill to remove the temper
and reduced it to 1/8" in the lathe - it now fits the Dremel, works a
treat for me!
Best regards
Malcolm Hunt
CH601XL plans builder England
