janderson412(at)hotmail.c Guest
Posted: Mon Oct 02, 2006 12:50 pm Post subject: Guy -- 582 numbers |
After many hours of ag flying in heavy tail daggers, I found (and with my
Serries 5) ease the tail up just a little when it's ready then slight back
pressure and as soon as the tail doesn't lower with the back pressure it's
ready to fly. Once airbourne, hold it down until the speed builds to vy..
Subject: Re: Guy -- 582 numbers
Date: Sun, 01 Oct 2006 21:55:43 -0700
At 07:04 PM 10/1/2006, you wrote:
| Quote: | Were you able to get your off the ground better now ?
Right now I'm doing gross weight testing. My passenger is three bags of
Red-E-Crete, 180 pounds and a bit lumpy, but very quiet. I estimate I'm
between 1150 and 1200 pounds. At that my takeoffs are between 700-1000'.
(Hot day, no wind.) I'll know more about rate of climb tomorrow when I
reduce the data from the testing I did yesterday. I did find that my stall
speeds increased to 45mph indicated clean and 41 dirty. Power on was 40 and
31, respectively.
I've used two techniques to take-off. The way I was taught was to lift the
tail and hold it up to liftoff speed,in my case about 50 mph, (10 over
stall,) and then fly away. I also picked up, from where I can't remember,
the idea of flying away from a three point. The latter takeoff is much
shorter, but much more exciting, as it puts you in the air right at stall
speed and you can get some "interesting" results on a gusty day. What are
you doing, Dave, to get your short takeoffs?
Guy Buchanan
Find the coolest online games (at) http://xtramsn.co.nz/gaming
dave
Posted: Mon Oct 02, 2006 1:16 pm Post subject: Guy -- 582 numbers |
Guy,
I forgot to ask, is this a speedwing? If so that would explain a bit.
We got together 2 Kitofxes and an Avid today for some videos.
I will try to get a few clips together. That being said I thought about you
when i did takeoff today with zero wind and stick neutral and it flew off
the ground in about 200 to 250 feet. solo and by the time Iwas down the
runway 1000 feet i was over 200 AGL already. Plane was about 850 lb take
off weight with me solo.
Unforutnaly I will not be able to do it till next week unless i hit the
Midnight video centre tonight .
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Oct 02, 2006 1:52 pm Post subject: Guy -- 582 numbers |
Dave,
The models I through III had an undercambered wing. All models IV through
Series 7 use the same airfoil. I guess in Avid parlence, the latter wouild
be considered "Speedwings", although there is no designation as such in the
Kitfox vernacular.
I scanned past posts and can't determine what you are flying.
Lowell
dave
Posted: Mon Oct 02, 2006 2:06 pm Post subject: Guy -- 582 numbers |
Lowell,
Yes Mine is a 582 IV TO roll about 250 or less
We had a Kitfox 1 with 503 " " " "
and a Avid Heavy hauler 618 TO Roll about 400 feet.
The latter two have the undercambered wing bit I will say the Avid Take off
roll is about 400 feet BUT it climbs extremely well once it off the ground.
. He has no VSI and if I climb at 1200 to 1400 fpm he is going up faster
rate then me. But the Avid is a few feet narrow wingspan than a Kitfor and
the chord and wing area I am not sure.
Point is 3 planes all getting off the terra firma in decent time.
Dave
Malcolmbru(at)aol.com Guest
Posted: Mon Oct 02, 2006 4:54 pm Post subject: Guy -- 582 numbers |
roncarolnikko(at)hotmail. Guest
Posted: Mon Oct 02, 2006 7:23 pm Post subject: Guy -- 582 numbers |
Guy I hope you have your "passenger" seat belted in well. I had 5 50lb bags
in my Avid to get gross. Stalls were exciting with the load. Ron NB Ore
| Quote: | From: Guy Buchanan <bnn(at)nethere.com>
31, respectively.
Guy Buchanan
Get today's hot entertainment gossip http://movies.msn.com/movies/hotgossip
Posted: Mon Oct 02, 2006 7:34 pm Post subject: Guy -- 582 numbers |
Lowell I think I've heard the term Riblett airfoil for the latter style.
Ron NB Ore (Speedster)
[quote]From: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Date: Mon, 2 Oct 2006 14:51:06 -0700
Dave,
the Kitfox vernacular.
Lowell
Guy Buchanan
Posted: Tue Oct 03, 2006 7:18 am Post subject: Guy -- 582 numbers |
At 08:22 PM 10/2/2006, you wrote:
| Quote: | Guy I hope you have your "passenger" seat belted in well.
Not near well enough! I did stalls, but I won't do spins or accelerated
stalls with him in!
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Guy Buchanan
At 02:15 PM 10/2/2006, you wrote:
| Quote: | I forgot to ask, is this a speedwing? If so that would explain a bit.
Well, it's a IV, so it has the flat bottom wing. But it's not a Speedster
and so has the long wing, which should be good for take-off distance.
Yesterday I took off at 1175# at 1500' and 70F and it took about 600'.
Guy Buchanan
Deceased K-IV 1200
Guy Buchanan
Posted: Tue Oct 03, 2006 7:19 am Post subject: Guy -- 582 numbers |
At 01:49 PM 10/2/2006, you wrote:
| Quote: | After many hours of ag flying in heavy tail daggers, I found (and with my
Thanks John. I've tried this and the only problem I have with it is that
I'm airborne very close to stall speed. Once I had the aircraft settle back
to the runway after it lifted off during a gust. I basically had to
three-point a landing while taking off; very disconcerting. Am I holding
the tail too low?
Guy Buchanan
Deceased K-IV 1200
dave
Posted: Tue Oct 03, 2006 7:33 am Post subject: Guy -- 582 numbers |
Guy, Well 600 feet is better than your 900 feet results but you got
something seriously wrong to not be flying sooner.
I have got some vidoes I am working on for you to show you how it should
work.
I tried yesterday taking off with stick neutral and it flew off in 3 point
configuration at about 40 IAS in under 250 feet solo 955 ASL .
Have you tried it this way ? And what prop are you using and what static
RPM do you get ?
Dave
Guy Buchanan
Posted: Tue Oct 03, 2006 8:06 am Post subject: Guy -- 582 numbers |
At 08:33 AM 10/3/2006, you wrote:
| Quote: | Have you tried it this way ? And what prop are you using and what static
RPM do you get ?
Yes, the 600' was three-point, though at 1175# and 70F. I have a 70" Warp
three blade set to 12 degrees at the tip and get about 6350 static. (I get
about 6700 WOT level airborne at 6400' DA.) I am worried that the 70" is
too large and is reducing my top speed, but I have to find some propeller
software to evaluate the possibility of trimming it.
Guy Buchanan
Deceased K-IV 1200
dave
Posted: Tue Oct 03, 2006 8:55 am Post subject: Guy -- 582 numbers |
Sounds good Guy,
I have a 68 inch warp 3 blade --ratio is 3 to 1 and static i am about
6100 and 6800 wot
cruise 88- 89 mph via gps ( asi reads about 105 or so lol - no
external static port)
Check back soon, I just putting together some movie clips now ...........
and I will upload to a server soon
Dave
dave
Posted: Tue Oct 03, 2006 9:10 am Post subject: Guy -- 582 numbers |
OK first plane is a Kitfox IV 582
Second one is a Raven --aka Kitfox 1 clone 503 single carb
Third one is a Avid flyer 618
Sorry for the quality but it gives you an indication of the Take offs , we
did these for you so you can see that 600 foot take offs are not acceptable
< VERY BIG GRIN >
The blue avid take off gets cut out but I was standing at near the 200 foot
mark and he takes 400 feet + to get off but climbs well once off as you
will see in video.
The take off run on the first two is 200 feet to about the edge of the
taxiway. so you will see just past that is about the 250 feet and beyond
that is the windsock hanging vertical -- no wind but hard to see.
The White and blue Raven is a 84 year old man that he scratch built. .
Temp was about 60 F elevation 955 asl wind calm
Download it here http://www.cfisher.com/kitfox/coffeebreak.wmv
about 4.6 meg. about 30 seconds on my highspeed -on dialup i wouldguess
about 15 to 20 mins
Dave
Guy Buchanan
Posted: Tue Oct 03, 2006 12:35 pm Post subject: Guy -- 582 numbers |
At 09:55 AM 10/3/2006, you wrote:
| Quote: | cruise 88- 89 mph via gps ( asi reads about 105 or so lol - no
Sigh. I cruise right around 80 at 5800 rpm. That's one reason I was
wondering if the prop was too big. I wondered if I was having to flatten it
to keep the loading down because of the big disk, and if the result was
that I had low top end.
It also looks like you're a lot less draggy than I am. (Lower static,
higher WOT rpm.) I don't have the radiator cowled or a cowl flap on the
cowl exhaust. I also don't have fairings on the gas caps or on the strut
ends. Other than that I'm pretty fair.
Guy Buchanan
Deceased K-IV 1200
Posted: Tue Oct 03, 2006 2:06 pm Post subject: Guy -- 582 numbers |
Bearing in mind we are talking about short t/off? The idea in this case is
to get the a/c airborne as soon as possible. The acceleration rate is better
with wheels unstuck so the aim is to get them (wheels) just inches above
the ground and just hold it there. Yes try lifting the tail a tad more then
but not too much, the idea being to maintain a high angle of attack, when it
becomes airborne slowly lower the nose as the speed builds. Stick movements
must be very subtle when the aircraft is in the mode. Are you using flap at
all. ~j~
Date: Tue, 03 Oct 2006 08:18:06 -0700
Thanks John. I've tried this and the only problem I have with it is that I'm
airborne very close to stall speed. Once I had the aircraft settle back to
the runway after it lifted off during a gust. I basically had to three-point
a landing while taking off; very disconcerting. Am I holding the tail too
low?
Guy Buchanan
Become a fitness fanatic (at) http://xtramsn.co.nz/health
