nuckollsr(at)cox.net Guest
Posted: Tue Oct 03, 2006 3:57 am Post subject: Relays 'G's" skunk stink |
At 08:07 AM 10/2/2006 -0700, you wrote:
I think it is time for someone with a little authority to clear this up.
My authority is so little that I have hidden it under one of the periods
in this posting. A prize awaits the one who finds it.
1) Relay mounting. Type 70 Stancor Rodgers White Emerson Tyco. See:
http://www.alliedelec.com/Images/Products/Datasheets/BM/STANCOR/Stancor_Industrial-Control_5760005.pdf
So the manufacturer says, "mount plunger vertical, cap down". I checked
into the engineering data on this part and of course the corporate
conglomeratization has destroyed the engineering knowledge that built the
part. The manufacturer PROMISED they'd get back to me.....It's not DO-160
bubela. And it's only 122 deg F max operating temp. Etc. etc.
Why would you suppose they would make this recommendation?
Is the engineering knowledge behind the recommendation
so esoteric that we cannot deduce it for ourselves?
| Quote: | Use the Kilovac EV200 part if you can.
Of course everyone CAN . . . it's a matter of trades.
What is the return on investment for the trade . . .
and is there more than one trade?
<snip>
| Quote: | "Everything you've learned in school as "obvious" becomes less and less
obvious as you begin to study the universe. For example, there are no
solids in the universe. There's not even a suggestion of a solid. There
are no absolute continuums. There are no surfaces. There are no straight
lines."
- R. Buckminster Fuller
Interesting quotation . . . I'm fond of quotations
that offer simple-ideas of easily discovered utility.
How would you propose we use the learned gentleman's
to guide our deliberations?
< You can never learn less, you can only learn more. >
< R. Buckminster Fuller >
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Tue Oct 03, 2006 12:37 pm Post subject: Re: Relays 'G's |
Eric said:
| Quote: | I think it is time for someone with a little authority to clear this up.
part. The manufacturer PROMISED they'd get back to me.....It's not DO-160 bubela. And it's only 122 deg F max operating temp. Etc. etc. |
Bob replied: | Quote: | | Why would you suppose they would make this recommendation? Is the engineering knowledge behind the recommendation so esoteric that we cannot deduce it for ourselves? |
I assume we can figure it out. My analysis is that the type-70 contactor has poor water-tightness (especially around the electrical terminals). This is a bit less of a problem with the cap down. Also, when energized the plunger contacts an iron stop that is part of the magnetic circuit when closed. There is no room in the space and the plunger MUST be allowed to contact the stop or the coil will draw excessive current, etc.--The cap-down orientation prevents accumulation of debris in the plunger-stop space. So my vote is that gravity is the lesser issue. On the other hand the contactor was designed for cars, not airplanes--so who knows what they considered.
lines."
- R. Buckminster Fuller |
| Quote: | Interesting quotation . . . I'm fond of quotations
Bob, I like this quotation because Fuller suggests casting out "learned" assumptions and looking at problems without preconceptions. This is more philosophical than practical of course, but I like the idea that what we should begin by assuming everything we know is wrong.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
N6030X(at)DaveMorris.com Guest
Posted: Tue Oct 03, 2006 1:08 pm Post subject: Relays 'G's" skunk stink |
At 03:37 PM 10/3/2006, you wrote:
| Quote: | Bob, I like this quotation because Fuller suggests casting out
we know is wrong.
Or at least more complicated than we were first taught. For instance
in that Physics 101 class when the teacher (foolishly) said "assume
this is done in a vacuum and there is no drag". Then you find out
the earth is not a perfect sphere, the adiabatic lapse rate is not
uniform, electrons do not flow from positive to negative, and so
on. It's really depressing
Dave Morris
Posted: Tue Oct 03, 2006 6:01 pm Post subject: Relays 'G's" skunk stink |
At 01:37 PM 10/3/2006 -0700, you wrote:
<snip>
| Quote: | > So the manufacturer says, "mount plunger vertical, cap down". I checked
Bob replied:
Agreed
| Quote: | Also, when energized the plunger contacts an iron stop that is part of
Plunger position or even the presence of a plunger
does not influence static coil current.
| Quote: | --The cap-down orientation prevents accumulation of debris in the
Having disassembled more than a dozen of these
devices over the years, I think we can make a pretty
good guess. The springs are not real strong so the
force of gravity would add a significant aiding
or opposing force depending on orientation. This
wouldn't be much of a concern for getting the critter
closed . . . but contact spreading velocity would
probably see a larger delta due to orientation than
for decay rates of the magnetic field in the coil.
I'll see if I can figure out a way to go measure that
sometime. Also, the bore of the coil bobbin is plastic.
More than one solenoid has become erratic due to
erosion of bobbin interior due to a horizontal
sliding core.
In the case of contact spreading velocity for improved
contact life, cap-down helps. For bobbin erosion,
either vertical orientation would be okay. It MIGHT
be that they considered moisture effects . . . it's
NOT a sealed relay and a non-sealed housing hit with
cool splash WILL suck in water. Better that it's
pooled in the cap than allowed to drip down over
contacts, spring and plunger.
If we were using these devices in an industrial
control situation with hundreds of operations per day
(with expectation for achieving a HIGH percentage
of rated life), then religious observance of orientation
cap-down would probably yield an increase in service life.
Given that these devices in light aircraft operate perhaps
a couple hundred times per year (and at loads much
lighter than rated) the probability is that most
of us will experience a maintenance event on these
contactors due to environmental effects as opposed to
wearing effects.
| Quote: | >
> lines."
Agreed . . . and according to some demonstrably practical
folks like Dr. Virgil Elings, one should always proceed
forward with a fine attunement to actions that are not
helping or even worse, going in the wrong direction.
I made his one-sided and limited acquaintance when a reader
pointed me to this interview of Dr. Elings at:
http://webcast.ucsd.edu:8080/ramgen/UCSD_TV/11762.rm
the audio on this presentation was pretty poor. I've
done some post processing on it and placed a temporary
copy at:
http://www.aeroelectric.com/Temp/Virgil_Elings-Look_at_the_Big_Picture.mp3
I believe both Fuller and Elings would agree that
one of mankind's biggest impediments to progress
is the blind acceptance of preconceptions coupled
with equally blind obedience to those who would hand
out pre-conceptions be they in the form of bad
science or bad plans.
There is risk that some folks grab onto an idea
like the Fuller quotation with a liberal
dose of fundamental attribution error. Like:
"Nothing is real, nothing is what it seems to be.
Everything is irrelevant. Everything I do is
irrelevant. I am irrelevant. Mr. Fuller said so."
That's why I gravitate more toward folks like
Kettering, Kelvin, and most recently Elings.
Their ideas don't take much interpretation.
They really jump out at you. They encourage
healthy skepticism and stand up well to the
repeatable experiment.
glcasey(at)adelphia.net Guest
Posted: Wed Oct 04, 2006 4:26 am Post subject: Relays 'G's" skunk stink |
I have a suggestion for the reasons a manufacturer wants the relay
mounted in a certain orientation, based on experience doing similar
things. It has mostly to do with water: Generally, you want to
mount the part in a way that water has the least chance of getting
inside, so the cap is made like a roof so the water runs off. Also,
you want to have the internals arranged in a way that a drop of water
inside has the least chance of causing a corrosion failure. That
might be to have the electrical connections to the coil at the top -
or the contacts could be at the top if they are more vulnerable.
Reasons like this make far more sense than G-load resistance.
Gary Casey
Eric M. Jones
Posted: Wed Oct 04, 2006 11:02 am Post subject: Re: Relays 'G's |
Bob said:
| Quote: | Plunger position or even the presence of a plunger
does not influence static coil current. |
Oops...Yes you are right...
Re: Fuller Quote--
At least I have refrained from using as a signature:
"Concepts of space and time are certainly doomed." Dr. Edward Witten
113 Brentwood Drive
(508) 764-2072
