gommone7(at)bellsouth.net Guest
Posted: Wed Oct 04, 2006 7:21 am Post subject: hugo rv10 |
Hi all,still with antennas questions,
almost everybody suggest to use rg400u coaxial cable ,good, i ordered,now the choice in the usual catalogs have a very restricted choice of BNC connectors (only one tipe )will fit the RG 400,and can't be solder,ok order allready the 70 dol crimping tool.but still one part missing wich is a metal sleeve wich slide over the conection and allow to be crimped,if I'm rigth ,no body sale thats sleeve,can some one help me to understand or a place to order the part.
thanks ,and sorry for my lack of knoledge in electrical systems
Hugo
klehman(at)albedo.net Guest
Posted: Wed Oct 04, 2006 7:48 am Post subject: hugo rv10 |
Hi Hugo
The steinair website may help you.
http://steinair.com/connectors.htm
I believe that any connector that fits RG-58 will fit RG400 and I used a
$20. imported crimper that worked fine for me.
Ken L.
gommone7(at)bellsouth.net wrote:
Hugo
nuckollsr(at)cox.net Guest
Posted: Wed Oct 04, 2006 8:16 am Post subject: hugo rv10 |
Ken is correct. Dimensionally, RG-58 and RG400 are close enough
to use the same connectors and application tools. The only 'catch'
is to get your 'cheap' tool and connectors from the same supplier . . .
presumably, like me, they'll make sure that their connectors are
compatible with their tools. It's a rare problem but NOT zero risk.
Alternatively, one can purchase mil-spec connectors and tools from
anyone with a high expectation for mix-n-match between tools and
connectors.
At 11:48 AM 10/4/2006 -0400, you wrote:
Hi Hugo
Ken L.
>Hugo
-- incoming mail is certified Virus Free.
Checked by AVG Anti-Virus.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
frank.hinde(at)hp.com Guest
Posted: Wed Oct 04, 2006 8:19 am Post subject: hugo rv10 |
Radioshack also has one for 11 bucks
Frank
Posted: Wed Oct 04, 2006 9:36 am Post subject: hugo rv10 |
Thanka at all.
hugo
Thanka at all.
hugo
Posted: Wed Oct 04, 2006 3:07 pm Post subject: hugo rv10 |
Thanks again for the answer,but personaly never purchase cheap tools,use few times but allways do perfect job.
Now my next question.
ELT antenna,in a 180knots airplane I thinks a flexible spring antenna will be out of question ,I belive can't be mount inside an a aluminum plane,I found a spot under the vertical stabilizer ,the 10 use a thin fiberglass fairing,what you guys thinks will work?,.eventualy need to work only one time,in a shallow accidents probably don't needed but in a bad one ,the the antenna will be pointing up and almost at the highest point,(sorry for the humor)
here the pictures ,
thanks again ,Hugo
31.95 KB |
335 Time(s) |
28.33 KB |
373 Time(s) |
